toshuu8
How to open a file with the same name?
Feb 14, 2012 5:57 AM
Hi, now I practicing making web pages where I put sample codes in one directory and I copy them to edit.
The probrem is, I couldn't open one file while I'm opening another file with the same name.
Is it possible to open  a file with the same name in Dreamweaver?
    Feb 14, 2012 6:00 AM   in reply to toshuu8
    I don't think you can open files with the same name in any application. Neither should you try it! you might overwrite the wrong file.
    Bad practice.
    Feb 15, 2012 5:40 AM   in reply to toshuu8
    That could be a very error prone practice.
    May I suggest you take advantage of DW "Snippets" feature instead.
    Simply save any blocks of code you will reuse regularly as snippets,
    and give each one a descriptive name you like.
    Then you can simply place your cursor in code view where you wish the code,
    and click insert on the selected item from the snippet panel.
    Feb 15, 2012 4:49 AM   in reply to toshuu8
    toshuu8 wrote:
    I was wrong! I COULD open a file with the same name in DW.
    Sorry to have bothered you..
    It's still not a good idea to do so.
