I apologize if this is not the right place to post my crash info but Adobe's link to the "post your crash info here" only links to their blog which contains no content.
Anyway I am a new user to AE and am trying to render a movie. However, every time I attempt to render the video it gets to about 20 seconds into the clip and then the program crashes. I've attempted to remove the audio and uncheck the OpenGL boxes but neither seem to do the trick. I'm really not sure what to do or where to look because I'm not that familiar with the program and have not been able to get a successful render out of AE.
I am running an iMac with OSX 10.6.6, 3.06 GHz Intel Core 2 Duo with 4GB RAM. I have uninstalled and re-installed the software but still get the same results during render.
Here is my crash report (any ideas, suggestions, or advice would be greatly appreciated):
Process: After Effects [1575]
Path: /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
Identifier: com.adobe.AfterEffects
Version: 10.0 (10.0)
Code Type: X86-64 (Native)
Parent Process: launchd [128]
Date/Time: 2011-03-03 15:17:52.922 -0500
OS Version: Mac OS X 10.6.6 (10J567)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000adbdb2c3
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x00007fff881c9616 __kill + 10
1 libSystem.B.dylib 0x00007fff88269cca abort + 83
2 U.dylib 0x0000000102a88867 U_LoadFrameworkBundle + 695
3 libSystem.B.dylib 0x00007fff881db67a _sigtramp + 26
4 ??? 0x00007fff5fbfa3a0 0 + 140734799782816
5 com.apple.CoreText 0x00007fff8375c2dc TKerningEngine::KernLine(TCharStream const*) + 276
6 com.apple.CoreText 0x00007fff8375c1aa TTypesetter::FinishLayout(TLine&, TCharStream const&) const + 28
7 com.apple.CoreText 0x00007fff83756e01 TTypesetterAttrString::Initialize() + 335
8 com.apple.CoreText 0x00007fff83756a4a CTLineCreateWithAttributedString + 48
9 com.adobe.dvaui.framework 0x00000001031953f6 dvaui::drawbot::CoreTextStringDisplayInterface::MeasureStringWidth() const + 86
10 com.adobe.dvaui.framework 0x00000001031a2e75 dvaui::drawbot::CoreTextFontInterface::MeasureStringWidth(unsigned short const*, int) const + 197
11 com.adobe.dvaui.framework 0x000000010319793d dvaui::drawbot::OSSurfaceInterface::MeasureStringWidth(dvaui::drawbot ::FontInterface const&, unsigned short const*, int) + 109
12 ...e.AfterEffectsLib.framework 0x00000001006654e0 EDB_DrawString(dvaui::drawbot::Drawbot*, dvaui::drawbot::ColorRGBA const&, dvaui::drawbot::FontInterface const*, float, float, std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> > const&, dvaui::drawbot::TextAlignment, dvaui::drawbot::TextTruncation, float) + 384
13 ...e.AfterEffectsLib.framework 0x0000000100a717ed CRender::RegisterDestroyListener(boost::function0<void>) + 25613
14 ...e.AfterEffectsLib.framework 0x0000000100a8776a GetCRender(CProject*) + 88234
15 ...e.AfterEffectsLib.framework 0x0000000100a88084 GetCRender(CProject*) + 90564
16 ...e.AfterEffectsLib.framework 0x0000000100a83614 GetCRender(CProject*) + 71508
17 ...e.AfterEffectsLib.framework 0x0000000100a6dc92 CRender::RegisterDestroyListener(boost::function0<void>) + 10418
18 ...e.AfterEffectsLib.framework 0x0000000100693eac TerminateRenderTimeout() + 8844
19 ...e.AfterEffectsLib.framework 0x000000010060e16b CEggApp::HasWatchFolderDialog() + 107
20 BEE.dylib 0x0000000101204e3a BEE_NewFauxComp(BEE_CompItem**) + 15402
21 BEE.dylib 0x00000001013028c0 BEE_CmdMakeMovie(unsigned char, int*, BEE_MakeMovieParams*, unsigned char*) + 656
22 ...e.AfterEffectsLib.framework 0x0000000100a73a52 GetCRender(CProject*) + 7058
23 ...e.AfterEffectsLib.framework 0x0000000100a70fac CRender::RegisterDestroyListener(boost::function0<void>) + 23500
24 ...e.AfterEffectsLib.framework 0x0000000100a67983 GetCProject(unsigned char) + 34627
25 ...e.AfterEffectsLib.framework 0x0000000100a172c6 COutlineDir::GetOutlinePano() + 1222
26 ...e.AfterEffectsLib.framework 0x00000001004b00e6 unsigned short* std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> >::_S_construct<unsigned short*>(unsigned short*, unsigned short*, std::allocator<unsigned short> const&, std::forward_iterator_tag) + 27782
27 com.adobe.dvaui.framework 0x000000010305d05f void dvaui::ui::SendMessageT<boost::shared_ptr<boost::function<void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> >, dvaui::ui::MessageT<dvaui::ui::UI_Node> >(boost::shared_ptr<boost::function<void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > const&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 31
28 com.adobe.dvaui.framework 0x000000010305d09c void dvaui::ui::SendMessagesT<dvacore::utility::SharedFunctions<boost::sha red_ptr<boost::function<void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > >, dvaui::ui::MessageT<dvaui::ui::UI_Node> >(dvacore::utility::SharedFunctions<boost::shared_ptr<boost::function <void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > > const&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 44
29 com.adobe.dvaui.framework 0x000000010304e6ce dvaui::controls::UI_Button::SendButtonChangedMessage(dvacore::utility ::Flags<unsigned char>) + 78
30 com.adobe.dvaui.framework 0x000000010304e35d dvaui::controls::UI_Button::PerformAction(bool, dvacore::utility::Flags<unsigned char>, bool) + 125
31 com.adobe.dvaui.framework 0x000000010304f3cc dvaui::controls::ButtonInputCapture::End() + 76
32 com.adobe.dvaui.framework 0x00000001031d586f dvaui::ui::InputCapture::InvokeEnd(bool) + 239
33 com.adobe.dvaui.framework 0x00000001031d592c dvaui::ui::UI_NodeManager::EndInputCapture(bool) + 76
34 com.adobe.dvaui.framework 0x000000010305005f dvaui::controls::ButtonInputCapture::DoMouseEvent(dvaui::ui::MouseEve nt const&) + 335
35 com.adobe.dvaui.framework 0x00000001031e0b1d dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEve nt const&) + 605
36 com.adobe.dvaui.framework 0x00000001031e0da9 dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node* , dvaui::ui::MouseEvent const&, bool) + 121
37 com.adobe.dvaui.framework 0x00000001031e0eb4 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
38 com.adobe.dvaui.framework 0x0000000103254433 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEve nt const&, bool) + 595
39 com.adobe.dvaui.framework 0x0000000103250249 dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_ Event const&) + 313
40 com.adobe.dvaui.framework 0x00000001032568cc dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 492
41 com.adobe.dvaui.framework 0x000000010324138f dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
42 com.adobe.dvaui.framework 0x000000010324708b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
43 com.adobe.dvacore.framework 0x0000000102d4ce16 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0 <void>*, void*) + 38
44 ...e.AfterEffectsLib.framework 0x0000000100662946 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
45 ...e.AfterEffectsLib.framework 0x0000000100662a71 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
46 com.adobe.dvacore.framework 0x0000000102d4bcf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHa ndler<void>(boost::function0<void>, bool*) + 197
47 com.adobe.dvacore.framework 0x0000000102d4dc83 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void> , bool*) + 99
48 com.adobe.dvaui.framework 0x0000000103249cbd -[DVAMacContainerView mouseUp:] + 253
49 com.apple.AppKit 0x00007fff877143d9 -[NSWindow sendEvent:] + 5547
50 com.apple.AppKit 0x00007fff87649a86 -[NSApplication sendEvent:] + 4719
51 com.adobe.dvaui.framework 0x0000000103242d6f -[DVAMacApplication sendEvent:] + 223
52 ...e.AfterEffectsLib.framework 0x0000000100470ac3 0x10046a000 + 27331
53 com.apple.AppKit 0x00007fff875e04da -[NSApplication run] + 474
54 ...e.AfterEffectsLib.framework 0x00000001006b6a12 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 16386
55 ...e.AfterEffectsLib.framework 0x0000000100660dcc SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
56 ...e.AfterEffectsLib.framework 0x0000000100661494 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
57 com.adobe.AfterEffects 0x00000001000043b8 main + 1144
58 com.adobe.AfterEffects 0x0000000100003895 _start + 227
59 com.adobe.AfterEffects 0x00000001000037b1 start + 33
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff8819416a kevent + 10
1 libSystem.B.dylib 0x00007fff8819603d _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff88195d14 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff8819583e _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff88195168 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff88195005 start_wqthread + 13
Thread 2:
0 libSystem.B.dylib 0x00007fff881b5fca __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff881b9de1 _pthread_cond_wait + 1286
2 com.adobe.amt.services 0x000000010c68dc53 AMTConditionLock::LockWhenCondition(int) + 37
3 com.adobe.amt.services 0x000000010c686cce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
4 com.adobe.amt.services 0x000000010c68dcbe AMTThread::Worker(void*) + 28
5 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 3:
2 ...ple.CoreServices.CarbonCore 0x00007fff8181be27 TSWaitOnCondition + 118
3 ...ple.CoreServices.CarbonCore 0x00007fff8178b310 TSWaitOnConditionTimedRelative + 177
4 ...ple.CoreServices.CarbonCore 0x00007fff8178521b MPWaitOnQueue + 215
5 ...e.Frameworks.ASL.Foundation 0x0000000104dc2000 ASL::(anonymous namespace)::TaskProc(void*) + 96
6 ...ple.CoreServices.CarbonCore 0x00007fff8175d411 PrivateMPEntryPoint + 63
7 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
8 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 4:
5 AdobeACE 0x0000000108eb723d 0x108e7d000 + 238141
6 AdobeACE 0x0000000108eb6bea 0x108e7d000 + 236522
7 ...ple.CoreServices.CarbonCore 0x00007fff8175d411 PrivateMPEntryPoint + 63
8 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
9 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 5:
5 com.adobe.dvacore.framework 0x0000000102db4a1f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
6 com.adobe.dvacore.framework 0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
7 com.adobe.dvacore.framework 0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
8 ...obe.boost_threads.framework 0x0000000107f8dac4 thread_proxy + 132
9 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
10 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
1 ...dobe.dvatransport.framework 0x0000000107ce7c4e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
2 ...dobe.dvatransport.framework 0x0000000107ce8d05 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reac tor<false> >::run(boost::system::error_code&) + 517
3 ...dobe.dvatransport.framework 0x0000000107cc68cc SkyConnectionEnv::MainLoop() + 76
4 ...dobe.dvatransport.framework 0x0000000107cc6939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
5 ...obe.boost_threads.framework 0x0000000107f8dac4 thread_proxy + 132
6 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 13:
2 ...dobe.dvatransport.framework 0x0000000107ce8e3f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reac tor<false> >::run(boost::system::error_code&) + 831
3 ...dobe.dvatransport.framework 0x0000000107ce9a35 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver _service<boost::asio::ip::tcp>::work_io_service_runner>::run() + 53
4 ...dobe.dvatransport.framework 0x0000000107ccec79 asio_detail_posix_thread_function + 25
Thread 14:
Thread 15:
Thread 16:
Thread 17:
2 com.adobe.AfterEffects.MThread 0x000000012049ba8f main + 20783
3 com.adobe.dvacore.framework 0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
4 com.adobe.dvacore.framework 0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
Thread 18:
Thread 19:
Thread 20:
2 com.adobe.AfterEffects.OpenEXR 0x0000000126dbf4c6 IlmThread::Semaphore::wait() + 70
3 com.adobe.AfterEffects.OpenEXR 0x0000000126dbe33c IlmThread::(anonymous namespace)::WorkerThread::run() + 188
4 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
5 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 21:
Thread 22:
1 libSystem.B.dylib 0x00007fff881b5e59 nanosleep + 148
2 ...dobe.AfterEffects.Scripting 0x0000000127739fbb zcfree + 197989
3 ...dobe.AfterEffects.Scripting 0x000000012771cfd3 zcfree + 79229
4 ...dobe.AfterEffects.Scripting 0x000000012773a0b6 zcfree + 198240
Thread 23:
2 com.adobe.adobeswfl 0x00000001280ea89d APXGetHostAPI + 2465805
3 com.adobe.adobeswfl 0x0000000127ea35e9 APXGetHostAPI + 77145
4 com.adobe.adobeswfl 0x00000001280ea9b1 APXGetHostAPI + 2466081
5 com.adobe.adobeswfl 0x00000001280ead1a APXGetHostAPI + 2466954
6 com.adobe.adobeswfl 0x00000001280eae49 APXGetHostAPI + 2467257
Thread 24:
Thread 25:
0 libSystem.B.dylib 0x00007fff8817b2da mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff8817b94d mach_msg + 59
2 com.apple.CoreFoundation 0x00007fff83cb5932 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff83cb4dbf CFRunLoopRunSpecific + 575
4 com.apple.CoreMediaIOServices 0x00007fff855ba62b MIO::DAL::RunLoop::OwnThread(void*) + 147
5 com.apple.CoreMediaIOServices 0x00007fff855bc1f6 CAPThread::Entry(CAPThread*) + 140
Thread 26:
0 libSystem.B.dylib 0x00007fff8817b33a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x00007fff881b9cd2 _pthread_cond_wait + 1015
2 com.adobe.adobeswfl 0x00000001280ea869 APXGetHostAPI + 2465753
3 com.adobe.adobeswfl 0x00000001281070ec APXGetHostAPI + 2582620
Thread 27:
3 com.adobe.adobeswfl 0x0000000128284ef3 APXGetHostAPI + 4146787
Thread 28:
2 libtbb.dylib 0x000000010001222c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
3 libtbb.dylib 0x000000010001cb84 tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>:: wait_for_all(tbb::task&, tbb::task*) + 1858
4 libtbb.dylib 0x0000000100014e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
Thread 29:
2 com.apple.audio.CoreAudio 0x00007fff86e5467c CAGuard::WaitFor(unsigned long long) + 168
3 com.apple.audio.CoreAudio 0x00007fff86e56c0b CAGuard::WaitUntil(unsigned long long) + 185
4 com.apple.audio.CoreAudio 0x00007fff86e54d75 HP_IOThread::WorkLoop() + 1369
5 com.apple.audio.CoreAudio 0x00007fff86e54817 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
6 com.apple.audio.CoreAudio 0x00007fff86e54745 CAPThread::Entry(CAPThread*) + 125
Thread 30:
0 libSystem.B.dylib 0x00007fff8817b32e semaphore_timedwait_trap + 10
1 ...ple.CoreServices.CarbonCore 0x00007fff817f21f2 MPWaitOnSemaphore + 96
2 MultiProcessor Support 0x00000001310ebbd1 ThreadFunction(void*) + 69
3 ...ple.CoreServices.CarbonCore 0x00007fff8175d411 PrivateMPEntryPoint + 63
Thread 31:
0 libSystem.B.dylib 0x00007fff88194f8a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff8819539c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff88195005 start_wqthread + 13
Thread 32:
Thread 33:
2 ...aCore.ExporterQuickTimeHost 0x0000000121eae3b5 dvacore::threads::Gate::PassThrough(int) const + 501
3 ...aCore.ExporterQuickTimeHost 0x0000000121ea8666 ExporterQuickTimeHost::DoExportRemote() + 390
4 ...aCore.ExporterQuickTimeHost 0x0000000121ea978f ExporterQuickTimeHost::DoExport() + 447
5 ...aCore.ExporterQuickTimeHost 0x0000000121ea4c31 PrExporterModule<ExporterQuickTimeHost>::ExportEntry(int, exportStdParms*, void*, void*) + 1329
6 ...aCore.ExporterQuickTimeHost 0x0000000121ea43db xSDKExport + 59
7 ...ore.Frameworks.ExporterHost 0x000000010b094009 ML::ExporterPluginModule::CallExportModule(int, void*, void*) + 121
8 ...ore.Frameworks.ExporterHost 0x000000010b028b8a ML::Exporter::MovieExport(std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> > const&, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&) + 794
9 ...ore.Frameworks.ExporterHost 0x000000010b029432 ML::Exporter::BeginThreadExport() + 1266
10 ...ore.Frameworks.ExporterHost 0x000000010b02b59a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, boost::_mfi::mf0<void, ML::Exporter>, boost::_bi::list1<boost::_bi::value<ASL::InterfaceRef<ML::Exporter, ML::IExporter> > > >, void>::invoke(boost::detail::function::function_buffer&) + 74
11 com.adobe.dvacore.framework 0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
12 com.adobe.dvacore.framework 0x0000000102db4a9b dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 267
13 com.adobe.dvacore.framework 0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
14 com.adobe.dvacore.framework 0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
15 ...obe.boost_threads.framework 0x0000000107f8dac4 thread_proxy + 132
16 libSystem.B.dylib 0x00007fff881b4536 _pthread_start + 331
17 libSystem.B.dylib 0x00007fff881b43e9 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fff5fbf9ee0 rcx: 0x00007fff5fbf9eb8 rdx: 0x0000000000000000
rdi: 0x0000000000000627 rsi: 0x0000000000000006 rbp: 0x00007fff5fbf9ed0 rsp: 0x00007fff5fbf9eb8
r8: 0x0000000102a95768 r9: 0x000000013700f530 r10: 0x00007fff881c5656 r11: 0x0000000000000202
r12: 0x00007fff5fbf9ef0 r13: 0x00000000adbdb2bf r14: 0x00000000003e0343 r15: 0x0000000000000001
rip: 0x00007fff881c9616 rfl: 0x0000000000000202 cr2: 0x000000010df60c00
Binary Images:
0x100000000 - 0x100004ff3 +com.adobe.AfterEffects 10.0 (10.0) <B62CE36E-00B7-40DC-AF97-9E7B36EEFA6E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
0x100009000 - 0x100022feb +libtbb.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbb.dylib
0x100033000 - 0x100039feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbbmalloc.dylib
0x100040000 - 0x10004cff5 +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.213330) <B3758C21-93F6-9D51-627E-048EAB1F910C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_ signals
0x10005e000 - 0x10005ffff +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.213330) <82B9A0E9-66BD-2DE0-E5B8-3388B845A8B0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_s ystem
0x100065000 - 0x10006cff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.213330) <3A6F2741-13E1-DBB5-BD25-B3E2CB12C76A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boos t_date_time
0x10007c000 - 0x100081ffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
0x100086000 - 0x1001c9fef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
0x100215000 - 0x100319fef +hydra_filters ??? (???) <1AD09F41-C78B-9165-22C1-47F60212929C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_ filters
0x10040e000 - 0x10042cfff +image_runtime ??? (???) <5342D969-98CB-14EE-FA4C-2252BACA7EE3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
0x100466000 - 0x100467fff +ALOG.dylib ??? (???) <4B83A1E3-4434-2FF3-BF5B-058071B8FD11> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
0x10046a000 - 0x100e3dfef +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0) <4F38252D-5225-1F2F-AB2D-87E378C374B5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLi b
0x101196000 - 0x101196ff7 +AEFX.dylib ??? (???) <968DD1F9-D953-8D56-7F8E-642C726D2074> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
0x101199000 - 0x101554fe7 +BEE.dylib ??? (???) <535F8287-BE3D-E4AE-D3E1-AA42556DB8AA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
0x10179d000 - 0x1017acff3 +BEZ.dylib ??? (???) <238C2EC9-975E-AF5F-DF9F-F461CECF923A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
0x1017b0000 - 0x1017bbff3 +BM.dylib ??? (???) <11FD882B-A0B3-E8B8-C9CA-C7032CA77AC9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
0x1017c2000 - 0x1017fdfff +COR.dylib ??? (???) <C8ECFB66-6A1A-2347-7E3C-8435C453D054> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
0x101819000 - 0x101839ff7 +FILE.dylib ??? (???) <85DDDB02-4419-3CA9-2727-4C8108C9C5D9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
0x101847000 - 0x101874fff +FLO.dylib ??? (???) <973923DA-9557-6DC7-9E00-D68F02975BC3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
0x10187a000 - 0x10193dfff +FLT.dylib ??? (???) <F5DFA745-95FD-5CBD-CBC6-92A83EFB1F54> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
0x1019a0000 - 0x1019a7ff3 +LIST.dylib ??? (???) <6EE40DE3-CCB7-5F5A-C6CF-3E241F97D625> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
0x1019ab000 - 0x1019befff +M.dylib ??? (???) <ED7686CA-1D79-06E9-2410-F341B614EF7C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
0x1019c3000 - 0x1019ccff7 +MC.dylib ??? (???) <84B8D9F9-17F6-DBF4-E9C4-B8955D37ECE2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
0x1019d3000 - 0x101a33fff +MSK.dylib ??? (???) <AE2DB0DA-B97A-41BD-D708-BBC62C667E3A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
0x101a47000 - 0x101a5eff7 +OM.dylib ??? (???) <EB18BEA8-DA5D-4E14-BD54-C23E7B576014> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
0x101a66000 - 0x101a88ff7 +P.dylib ??? (???) <D8239475-F2D0-2445-C857-773E1D92B040> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
0x101a91000 - 0x101ddafff +PF.dylib ??? (???) <B321B849-7071-DCA6-878F-BB885D6C4D66> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
0x101e16000 - 0x10201ffff +PIN.dylib ??? (???) <DEE97322-EB9F-8D8C-4820-5ADCD5A426D0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
0x1020a0000 - 0x1020bafff +PLUG.dylib ??? (???) <F1B84FA7-F1C0-D8D2-0027-F398154E7F45> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
0x1020c5000 - 0x1020d8fff +PR.dylib ??? (???) <3E762A5F-F8F7-1430-1B05-37573C94A87C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
0x1020df000 - 0x1020e5fff +PREF.dylib ??? (???) <6BAF11D3-62C5-C8FD-A7FE-29EC7B7F295F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
0x1020e9000 - 0x102101fff +RG.dylib ??? (???) <B5C33D6F-B14C-1D0A-2D2B-F36E53F8ACCE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
0x10210a000 - 0x10210cff7 +RI.dylib ??? (???) <E160AB31-E857-F4E2-59F6-29AD71E58CAF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
0x10210f000 - 0x102110fff +RND.dylib ??? (???) <15050D6C-4BC4-E006-67D8-E3799A1A77FE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
0x102117000 - 0x102176ff7 +SLU.dylib ??? (???) <0FDE1877-43F4-1C28-6537-725004CFA0B5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
0x10219c000 - 0x1021b8ffd +SND.dylib ??? (???) <08CDA7D2-AB19-3B47-CC30-675FB9C19F1B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
0x1021c0000 - 0x1021c3ff1 +STR.dylib ??? (???) <404DF8FC-F56E-D1FB-69DA-E62CB2EAAD2D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
0x1021c7000 - 0x1021cafff +T.dylib ??? (???) <F139D7D3-1962-78FA-1341-4475161F59DF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
0x1021cd000 - 0x10220aff5 +TDB.dylib ??? (???) <63379742-F508-6083-3038-53BA87A9BAE5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
0x10221e000 - 0x1028c9fe5 +TXT.dylib ??? (???) <8D482B40-28CE-1FB7-7A6C-FF8463790AC6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
0x102a68000 - 0x102aa4ff1 +U.dylib ??? (???) <C07391C6-A4F7-A583-4AF9-B9C19171F45A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
0x102ab8000 - 0x102abcfff +VAL.dylib ??? (???) <DBB9A3A1-F0F3-14E8-C827-0BBDEC116E99> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
0x102abf000 - 0x102b6ffff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.213330) <CD3B7889-351C-AA13-69AF-27A7AA2DF2F4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x102c76000 - 0x102c9cffb +PREM.dylib ??? (???) <99093041-26A0-051D-9074-DEA7B00B923B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
0x102cb0000 - 0x102d09fff +FRP.dylib ??? (???) <AFBC28AA-C1BC-04A7-DA65-29A933DA4DB4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
0x102d26000 - 0x102e84ff7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.213330) <256DF884-9EC1-771E-6E84-7BB625046278> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x102ff8000 - 0x10333fff7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.213330) <8599321B-EE71-853E-EC77-B4A63FF400C9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x103701000 - 0x1037affff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.213330) <FF18DA57-0B63-FDF9-F909-63AF774D945A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
0x10388b000 - 0x1038abfef +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.213330) <268D30FC-BF51-4FDA-8854-770E8295D2A1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaun ittesting
0x1038d4000 - 0x1038e4ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x1038ef000 - 0x103967fef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_cap s
0x10397d000 - 0x1039e2fff +aif_core ??? (???) <4E7ADC1A-0D15-727F-9B79-1C74A8763FD8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x103a24000 - 0x103c53fff +aif_ogl ??? (???) <C97013B9-C1E5-EE50-F924-8ED11043B282> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x103e17000 - 0x103e2dfff +data_flow ??? (???) <C0E0AFA6-8D23-93FB-E5D7-8A2B49D2C268> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
0x103e60000 - 0x104355fef +image_compiler ??? (???) <C1061733-6169-14E9-37E6-7484293BEA8B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image _compiler
0x104895000 - 0x10492bfff +image_flow ??? (???) <3FBF0B87-2177-F53C-C3F3-11D51A45239D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
0x104a11000 - 0x104a50ff7 +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0 (5.0.0.213330) <0E169D79-9960-BCAF-D85B-103665E5678B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynami clinkui
0x104aa6000 - 0x104c6ffff +com.adobe.dynamiclink.framework dynamiclink version 5.0.0 (5.0.0.213330) <85707809-6236-4E00-285A-580DA81D0094> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamicl ink
0x104d8d000 - 0x104defff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <BAC830AC-F3F4-037A-6030-7773FA47076E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFou ndation
0x104ed6000 - 0x104eecfff +ASLMessaging ??? (???) <3E585488-16D5-E499-E089-09C7AA3C1E04> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMess aging
0x104f0b000 - 0x104f1cffe +ASLUnitTesting ??? (???) <6A743B23-67B8-3BBA-E5B9-E6A255BB40C0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUn itTesting
0x104f34000 - 0x104f4eff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <88358D58-D8F9-8DF8-8E19-6AB807D63674> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/Audi oFilterHost
0x104f76000 - 0x104faefff +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <A84B6B9C-CC01-C65D-FDBD-413358A34863> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFi lters
0x105019000 - 0x105091fe3 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <C561A37C-8C80-C731-F2D6-08F48AAFE579> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioR enderer
0x10512c000 - 0x10516afe1 +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <9F36FD9D-3708-BFDE-CE6C-D035561137F7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSu pport
0x1051b3000 - 0x105bfffff +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <F6E47C97-30B8-4EF6-1156-06DBA45672A9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x106915000 - 0x106ab7ff3 +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <32230B4B-6E75-4631-94C0-75DEE05314D8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageR enderer
0x106be7000 - 0x106d6dff7 +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <2DEA855A-CBE8-9C63-6EF7-72D528776B0F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/Importe rHost
0x106f2d000 - 0x106f61fff +com.adobe.MediaFoundation ??? (1.0) <78B9FE26-86C1-B44F-BB81-BA21428022FE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Medi aFoundation
0x106fa4000 - 0x106fa7fff +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <4F4A6550-2BA7-FA81-17C4-023452073551> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtil s
0x106fac000 - 0x106fadfff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <6D281021-C4AD-0F62-E784-86E6C745AA6D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x106fb2000 - 0x106febfff +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <1CEE4DAB-7AD1-6FC5-C001-A7AAECF05C7B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFound ation
0x107039000 - 0x10706afff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <55244E51-A1BC-A2E7-84EC-7F8829D94A0C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/Plugin Support
0x1070a9000 - 0x1070aafff +PRM ??? (???) <285F42C6-5D90-16F9-5650-377D71A935C6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x1070ae000 - 0x1070e6fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <70AD1ED5-A189-83D8-9B39-BAC35CB614AD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/Swee tPeaSupport
0x107137000 - 0x10717ffff +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <CB52E22B-BDC5-9CE2-392B-A673DA8253B6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFram e
0x1071cc000 - 0x1072e6fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <F5072641-CA96-EFEF-D30D-8A643021D71C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoR enderer
0x107450000 - 0x1074f8fe1 +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.213330) <03600AA1-484D-1796-7DD1-C0BA492D14E5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x1075f5000 - 0x107668ff7 +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <9D9CC149-3B1F-A889-334D-9B2BC90212E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHos t
0x107703000 - 0x1077d5fff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <00A438BC-AC9F-7057-3DA4-432095AD518B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/Vide oFilterHost
0x107898000 - 0x107902ff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x107935000 - 0x1079d3ff2 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <5651FB7C-24ED-8CC8-2ADE-A5CB7CA493C3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libic ucnv.dylib.36.0
0x1079f3000 - 0x107a0efff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <FEF83A1C-8D48-66B4-BED6-B91835D1AA68> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata .dylib.36.0
0x107a11000 - 0x107a6bfff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.213330) <2E79ABD7-FDFA-B909-7635-64D2B984C8BD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametad ata
0x107aed000 - 0x107b71fff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.213330) <91D6B7F4-A965-0036-BD98-DE8BF3CFB30C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvamet adataUI
0x107c08000 - 0x107c4cff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.213330) <5165B4D5-5AD0-F846-5586-235DDF01078D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvate mporalxmp
0x107c6c000 - 0x107c85fff +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.213330) <DC398F51-93E0-DB11-4A2B-8EA4C1CAE7CC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamed iatypes
0x107ca4000 - 0x107d1aff7 +com.adobe.dvatransport.framework dvatransport version 5.0.0 (5.0.0.213330) <4F4DB4F1-FBD8-E774-8C33-830B243C4BA3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatran sport
0x107d9d000 - 0x107dd9ff3 +com.adobe.dvamarshal.framework dvamarshal version 5.0.0 (5.0.0.213330) <EEF373F8-AB3B-609F-6A9D-832B4132DC90> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarsha l
0x107e45000 - 0x107e53fff +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <603AF6EE-8B98-6E0F-BFB9-1B48594EE6B4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/Proje ctSupport
0x107e67000 - 0x107eaafff +DynamicLinkMedia ??? (???) <0353ADA3-82A5-E934-42A0-3A983A7285EF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/Dyn amicLinkMedia
0x107f17000 - 0x107f17ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
0x107f1a000 - 0x107f45ff6 +AdobeAXE8SharedExpat ??? (???) <F5C1010B-CAFF-5290-8B55-6FEB3A287225> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
0x107f57000 - 0x107f5dff7 com.apple.agl 3.0.12 (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x107f64000 - 0x107f81fff +AdobeBIB ??? (???) <2F1CE9F9-0D9A-3914-C0FE-E20CC5F1F9F7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x107f8b000 - 0x107f93ff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.213330) <34EE0EBB-3B3C-B838-97DF-637B4BBA82D8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads
0x107fa2000 - 0x107ff8feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
0x10803d000 - 0x1080fbffb +filter_graph ??? (???) <86919362-6EB7-5FAA-20BF-490FF5D14215> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_ graph
0x108223000 - 0x108281ffd +AdobeXMP ??? (???) <29839F01-4A21-5B72-FF9A-E030D214F5E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x10828f000 - 0x10831bfe3 +AdobeXMPFiles ??? (???) <C4531436-CA4F-8A06-0481-CD1648C20C48> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
0x108353000 - 0x1083f3fef +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7519) <92F5EB27-ED64-CA91-62F1-19D29CAAFC56> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
0x108439000 - 0x1084ddffb +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7519) <783EA0CD-8A21-4568-A4CE-046AC65EBFFF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
0x10853f000 - 0x10861dfef +AdobeAXEDOMCore ??? (???) <8D4592B8-5DA1-D957-B1BA-FB20116514DD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
0x108695000 - 0x1089c6fe7 +AdobeCoolType ??? (???) <CB25F6CA-6CF3-94E8-918C-51A54936C0F4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
0x108a62000 - 0x108dabfe7 +AdobeAGM ??? (???) <BEEAAC1B-CC8F-1A91-C0A2-03BE0343A313> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x108e7d000 - 0x108f91fff +AdobeACE ??? (???) <D04AF21C-E216-D514-B310-AD865E7C3AA1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x108fb6000 - 0x108fd7fff +AdobeBIBUtils ??? (???) <E04C88F8-0FBF-8E68-C0C2-B34CD69BD330> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
0x108fe4000 - 0x1090b7ffb +AdobeJP2K ??? (???) <8571D9BA-44F9-92A3-0444-5FFAC2994B88> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x1090d7000 - 0x109118ff7 +AdobeARE ??? (???) <44AF62DE-EC7A-76F7-32A8-1106926B47BD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x109122000 - 0x10977afef +AdobePDFL ??? (???) <45AA7483-10A6-2DAB-1FF8-62C9E615039E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x1098c9000 - 0x109ddafff +AdobeMPS ??? (???) <10C4E979-45F3-A7C6-0438-262CE5F595B9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x109eb0000 - 0x109edbfef +AdobeAXE16SharedExpat ??? (???) <F5E56D3B-AE0E-245C-E706-DFA630D6771C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/ A/AdobeAXE16SharedExpat
0x109eed000 - 0x10acb0fff +com.adobe.psl AdobePSL 12.0.0.7667 (12.0.0.7667) <F1C9409D-033E-58D0-B902-6422BC488AA5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x10b020000 - 0x10b0cbfeb +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <5E91F6C8-5AFA-D4CF-D961-02E210F4074E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/Exporte rHost
0x10b1df000 - 0x10b1fffeb +SegMatServices.dylib ??? (???) <2A93EF53-075B-328A-5830-CAED59925AF4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SegMatServices.dylib
0x10b20c000 - 0x10b20cff7 +SAM.dylib ??? (???) <BCF43D01-C6A4-F35E-1518-8DFEFCF7094D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
0x10b20f000 - 0x10b2f5fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
0x10b34d000 - 0x10b625fe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x10b79f000 - 0x10b7b5ff6 +com.adobe.AMEAppFoundation.framework ??? (1.0) <07B45FFC-9E85-1348-BAA4-944EC05DD0D7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AME AppFoundation
0x10b7d6000 - 0x10b7f9ff1 +com.adobe.PostEncodeHost.framework ??? (1.0) <FDF0E743-0DB9-E7DF-BE05-22BFE397DB56> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostE ncodeHost
0x10b827000 - 0x10b8e3ff7 +AMEWrapper ??? (???) <E735459D-FB6C-284C-E7AE-EA493E521221> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrappe r
0x10b9a2000 - 0x10baa9fff +com.adobe.EncoderHost.framework ??? (1.0) <FBAAF460-E4D2-1374-F453-1A9C98E38207> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderH ost
0x10bbae000 - 0x10bd7bfff +com.adobe.SettingsUI.framework ??? (1.0) <D87F7385-06E0-E6F1-7C29-5F20E2A6F9D0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsU I
0x10bfd8000 - 0x10c036ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <6C9FA948-D19A-382D-1A3D-6AC921E4272A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Clien t
0x10c0a4000 - 0x10c0cffff com.apple.carbonframeworktemplate 1.0 (1.0) <377C4816-226E-3D48-AFDA-A40178588B15> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefou ndation
0x10c109000 - 0x10c132fff +ameproperties ??? (???) <538DD95D-86A8-3D74-A231-06F1584A954B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/amepro perties
0x10c175000 - 0x10c179ff2 +com.adobe.AppServices.framework ??? (1.0) <859AF026-319B-2120-C6EF-422964EFF52C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServi ces
0x10c3b6000 - 0x10c3b8fef com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x10c3e9000 - 0x10c3f1fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0x10c576000 - 0x10c57afff +com.adobe.AfterEffects.EasyEase ??? (???) <C9455FFC-A444-B363-D387-620C3314BDF0> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
0x10c57d000 - 0x10c580ff7 +com.adobe.AfterEffects.Durer ??? (???) <65299D99-E891-5DCD-A5D0-3E9DE237FF7B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
0x10c66a000 - 0x10c6daff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservi ces
0x10d6c5000 - 0x10d6c6fff +com.adobe.AfterEffects.ExpressionControls ??? (???) <B47E6943-EA7A-B3DB-FD30-B15A639783C4> /Applications/Adobe After Effects CS5/Plug-ins/Effects/ExpressionControls.plugin/Contents/MacOS/Express ionControls
0x10d755000 - 0x10d758ff7 +com.adobe.AfterEffects.Fill ??? (???) <6F84BAD1-1E3C-D890-AE3D-088BF69024E6> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Fill.plugin/Contents/MacOS/Fill
0x10d75b000 - 0x10d75efff +com.adobe.AfterEffects.Fast_Blur ??? (???) <43BDE79C-6F9A-413D-BFE9-F027DD52ACD7> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Fast_Blur.plugin/Contents/MacOS/Fast_Blur
0x10d761000 - 0x10d765fff +com.adobe.AfterEffects.Tint ??? (???) <BCFF3781-6E25-34DD-9817-9766F63A9AA7> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Tint.plugin/Contents/MacOS/Tint
0x10d79e000 - 0x10d7a2ff7 libFontRegistryUI.dylib ??? (???) <763B8E8F-8602-2096-7CC8-CEE1F4248028> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/A TS.framework/Resources/libFontRegistryUI.dylib
0x120139000 - 0x12013aff7 +com.adobe.AfterEffects.Paint ??? (???) <8C07B2F5-4B17-F5C1-C4AE-B0394226EEE2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
0x12013d000 - 0x120147ff7 +com.adobe.AfterEffects.Glow ??? (???) <15E80079-1DAE-78A8-1846-1ED8A7B9631F> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Glow.plugin/Contents/MacOS/Glow
0x120438000 - 0x120439fff ATSHI.dylib ??? (???) <F6C4F446-7AC4-7A17-9302-C38A016322B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x120442000 - 0x120443fff +com.adobe.AfterEffects.Set_Channels ??? (???) <9048AB74-23E8-00B4-3C08-922DE52B8A61> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Set_Channels.plugin/Contents/MacOS/Set_Channels
0x12044b000 - 0x12044ffff +com.adobe.AfterEffects.Wave_Warp ??? (???) <0AE499A9-A19F-A377-16C8-6CCE44F3C63D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Wave_Warp.plugin/Contents/MacOS/Wave_Warp
0x120452000 - 0x120453ff7 +com.adobe.AfterEffects.Mosaic ??? (???) <96E465FA-2AFC-F3E5-30D5-CF4D8324B6BC> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Mosaic.plugin/Contents/MacOS/Mosaic
0x120491000 - 0x12049dfff +com.adobe.AfterEffects.MThread ??? (???) <D1511466-1D57-532C-C82E-69A13A2BD6D9> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
0x1204a4000 - 0x1204bafe7 +com.adobe.AfterEffects.PS3Export ??? (???) <B5E53B3B-3F97-2735-3E20-A140EBC71960> /Applications/Adobe After Effects CS5/Plug-ins/Format/PS Layer Export.plugin/Contents/MacOS/PS3Export
0x1204c6000 - 0x1204e8ff3 +com.adobe.AfterEffects.PS3Import ??? (???) <7FDD1A1F-E72E-597A-5366-2AF4FBC29EC4> /Applications/Adobe After Effects CS5/Plug-ins/Format/PS Layer Import.plugin/Contents/MacOS/PS3Import
0x1204f9000 - 0x1204fdff7 +com.adobe.AfterEffects.ExpScale ??? (???) <060AABF0-117B-6C9B-6DEB-893396D31C33> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
0x120501000 - 0x120692fef GLEngine ??? (???) <AE898A2A-1C12-9FDB-455F-32601F030904> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
0x1206c3000 - 0x120acdfe7 com.apple.ATIRadeonX2000GLDriver 1.6.26 (6.2.6) <0F5B5F88-3244-C922-60D0-97917502AE2F> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
0x120b17000 - 0x120b3dfff GLRendererFloat ??? (???) <8256EA93-A236-8B55-F214-65896DDB7A0E> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
0x120bd5000 - 0x120bd9fff com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F99C2FBC-103D-DB2D-8D53-CFB8CEFA90F8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x120bde000 - 0x120be4fff com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <933CA4C6-F428-0E2E-DCBE-FA0284914092> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x120be9000 - 0x120beefff +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0) <67DF0EF9-B526-49AB-FBF1-A1A4DFE25ED4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Conten ts/MacOS/ExporterCoreAudio
0x12127e000 - 0x1212b0fe7 +com.cycoresystems.CCfx.ParticleWorld ??? (???) <C7D01C13-848A-8F66-2CD2-106B46674445> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/ParticleWorld.plugin/Contents/MacOS/Par ticleWorld
0x1212bf000 - 0x1212c4fff +com.adobe.AfterEffects.Invert ??? (???) <56D7872B-9FC9-EE2E-F42C-65A374D86EE6> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Invert.plugin/Contents/MacOS/Invert
0x1212c7000 - 0x1212d8fff +com.adobe.AfterEffects.Levels2 ??? (???) <DE0A361C-C122-0EEE-C449-4F14BEB44EE6> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Levels2.plugin/Contents/MacOS/Levels2
0x1212dd000 - 0x1212eefff +com.adobe.AfterEffects.Hue_Sat ??? (???) <F5888FEF-2551-FA1F-6F17-82E4387DCFF3> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Hue_Sat.plugin/Contents/MacOS/Hue_Sat
0x1212f3000 - 0x1212f9fff +com.adobe.AfterEffects.Ramp ??? (???) <F00CC9EC-615D-14A7-7EA9-45E5EF36CFBC> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Ramp.plugin/Contents/MacOS/Ramp
0x12138a000 - 0x12138cfff +com.adobe.AfterEffects.Venetian_Blinds ??? (???) <C88C6E57-CBFB-5691-C2C8-56A212D5A353> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Venetian_Blinds.plugin/Contents/MacOS/Venetian_B linds
0x1214a3000 - 0x1214b2fff +com.adobe.AfterEffects.FreePin ??? (???) <4D77B374-4B94-C30A-F0A8-758D82DC3114> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
0x1214c2000 - 0x1214c7ff7 +com.adobe.AfterEffects.SmartBlur ??? (???) <78CF69D6-3576-A8E7-E393-774670779E9F> /Applications/Adobe After Effects CS5/Plug-ins/Effects/SmartBlur.plugin/Contents/MacOS/SmartBlur
0x121bd6000 - 0x121c00ff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
0x121c19000 - 0x121c40ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
0x121e60000 - 0x121e6ffe7 +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0) <9DF434DF-0CB3-FF7B-B988-5EED3CA04BAB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/Audio Converter
0x121e9d000 - 0x121ec3ff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <F53CB51E-9301-5881-113E-72B7543661D9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Co ntents/MacOS/ExporterQuickTimeHost
0x122000000 - 0x1221eafef com.apple.audio.codecs.Components 2.0.2 (2.0.2) <CC28CC1B-ACD4-151F-BC5B-E842AC7F075F> /System/Library/Components/AudioCodecs.component/Contents/MacOS/Audio Codecs
0x12235c000 - 0x122362ff7 +com.adobe.AfterEffects.Sequence ??? (???) <F316A457-4D53-3F13-23C5-EB09AE43C971> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
0x122367000 - 0x12236bfff +com.adobe.AfterEffects.TRKeys ??? (???) <44353A63-F5BA-B648-204D-D3F3581E2E58> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
0x12236e000 - 0x122372ff7 +com.adobe.AfterEffects.RPFImport ??? (???) <415423D4-579B-BAE5-187C-9D436AFF6C6C> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
0x124e83000 - 0x124eb9fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <98B3F385-B34E-AB84-0944-316FF3EDF68D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Conten ts/MacOS/ImporterQuickTime
0x124eed000 - 0x124f04fff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <493EAF2C-1621-6D9E-0B64-F4BE9DDA694E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
0x124f18000 - 0x124f2eff7 +com.red.ImporterRED 1.01 (1.0) <3282FA19-8A94-DEFD-8BF6-EEA9132DE447> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/Mac OS/ImporterRED
0x12513a000 - 0x12514eff7 +com.adobe.AfterEffects.FractalNoise ??? (???) <26A7D78F-0291-F8B0-5167-7ECE77A85F79> /Applications/Adobe After Effects CS5/Plug-ins/Effects/FractalNoise.plugin/Contents/MacOS/FractalNoise
0x125159000 - 0x12515bfff +com.adobe.AfterEffects.Threshold ??? (???) <10A0518D-D7F2-5F24-7565-09E50B134D3D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Threshold.plugin/Contents/MacOS/Threshold
0x12515e000 - 0x125160fff +com.adobe.AfterEffects.SolidComposite ??? (???) <158D8BE5-76D8-F027-C17E-47C26B1BD161> /Applications/Adobe After Effects CS5/Plug-ins/Effects/SolidComposite.plugin/Contents/MacOS/SolidCompos ite
0x1251e7000 - 0x125268fff +com.adobe.AfterEffects.AEGPDriver ??? (???) <2D2AF512-181B-E931-22CF-112B5AE2973C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
0x1252a0000 - 0x125316fff +com.adobe.AfterEffects.Escher ??? (???) <E19FED0B-FD67-8E9D-4F68-067BB310E6F7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
0x125323000 - 0x1253a1ff3 +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???) <FDA9EAF4-1FC7-F670-D61F-38E2B44B3D25> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/A EDynamicLinkServer
0x12555e000 - 0x12557bfff +com.adobe.AfterEffects.AudioPal ??? (???) <B2EC3E6B-42AF-11BF-A0CD-FCA84B4A31E8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
0x12558d000 - 0x1255bcffb +com.adobe.AfterEffects.BrushPal ??? (???) <AA683EE7-32C0-66C5-414C-E2E7B9CC021E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
0x1255d4000 - 0x125614ff7 +com.adobe.AfterEffects.CharPal ??? (???) <25BBAB42-542A-C8A9-626D-3BC60D4727D6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
0x125635000 - 0x125657fff +com.adobe.AfterEffects.InfoPal ??? (???) <E301706B-7062-C4CB-0F67-42675992BB5D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
0x12566b000 - 0x125697ffb +com.adobe.AfterEffects.PaintPal ??? (???) <7CB211AF-3ED4-9DA0-A7C6-4F083F1EDE14> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
0x1256af000 - 0x1256d0ff7 +com.adobe.AfterEffects.ParaPal ??? (???) <4ADBA656-E5B9-527A-4F24-5E77032E1BC3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
0x1256e4000 - 0x12587bfff +com.adobe.AfterEffects.SnapCut ??? (???) <649B6CB7-E3AD-316F-9426-7CA65CF289BF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
0x1258aa000 - 0x1258ccfff +com.adobe.AfterEffects.TimePal ??? (???) <5C49CB19-EC49-8DD4-B742-C817EBB9F2AF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
0x1258e2000 - 0x125925fff +com.adobe.AfterEffects.ToolPal ??? (???) <44504F8D-AFD6-C9BC-F491-299B17D92B41> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
0x125946000 - 0x125966ffb +com.adobe.AfterEffects.TrackerPal ??? (???) <C1A62239-4F43-C20E-900D-B6FB2ABFF195> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
0x125978000 - 0x12674aff7 +com.ImagineerSystems.mochashapeconverter4ae 1 (1.0.0) <3C1F5D08-D515-9E24-35ED-CC76FCCA9675> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Imagineer/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
0x126917000 - 0x12697dfff +com.adobe.AfterEffects.AE_OpenGL ??? (???) <115A01DF-0FF9-B686-3C03-67C7C8BF05CA> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
0x126b91000 - 0x126b9dff7 +com.adobe.AfterEffects.LocalizePresets ??? (???) <6A10F872-ECD9-0BCC-6189-75010D491050> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/Localiz ePresets
0x126ba6000 - 0x126bd6fff +com.adobe.AfterEffects.PNGIO ??? (???) <3E5936E0-0F00-4785-302F-388208B11628> /Applications/Adobe After Effects CS5/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
0x126be1000 - 0x126becfff +com.adobe.AfterEffects.Analyzer ??? (???) <322481EA-82CD-67AE-FB8B-2687E2FBFE81> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
0x126bf1000 - 0x126bf5ff8 +com.adobe.ape.shim adbeape version 3.1.64.7373 (3.1.64.7373) <B492C647-00DF-280F-47A0-EA78F1F9424A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x126d00000 - 0x126d82ff3 +com.adobe.AfterEffects.FlashExporter ??? (???) <762A17C7-F9E6-DB9F-3DD4-0E94CDB459E6> /Applications/Adobe After Effects CS5/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
0x126daf000 - 0x126f00feb +com.adobe.AfterEffects.OpenEXR ??? (???) <E570DDA8-8CD5-5C4B-A8EA-38B63E89231A> /Applications/Adobe After Effects CS5/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
0x127057000 - 0x12710bfff +com.adobe.AfterEffects.PremiereProImport ??? (???) <61E5AEBA-D4BA-E2C7-6D3A-798C9822CB35> /Applications/Adobe After Effects CS5/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Conten ts/MacOS/PremiereProImport
0x127138000 - 0x1271cafff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <C646F212-DD5F-242B-F7E9-5A767F980FB1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCor eUI
0x127254000 - 0x1272b0fff +com.adobe.AfterEffects.TIFFIO ??? (???) <BB070DC9-3710-E676-703C-9BBFA563DE12> /Applications/Adobe After Effects CS5/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
0x1272c0000 - 0x127384feb +com.adobe.AfterEffects.Vic ??? (???) <82DEAA73-D565-A6B0-E296-10BCF914B257> /Applications/Adobe After Effects CS5/Plug-ins/Format/Vector Output.plugin/Contents/MacOS/Vic
0x1273db000 - 0x1273f4ff3 +com.adobe.AfterEffects.Align ??? (???) <8925249E-BDFE-5773-5C8E-7678F4CF792E> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
0x127403000 - 0x127413fff +com.adobe.AfterEffects.MayaImport ??? (???) <3C2EE5DE-C841-A35D-DF51-EB125A8FC38D> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
0x127416000 - 0x12742dff7 +com.adobe.AfterEffects.MetaPal ??? (???) <3D1218BE-E450-ECDC-E1DA-8F81E6E2DB3A> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
0x12743e000 - 0x127468fff +com.adobe.AfterEffects.Moka ??? (???) <D9479AB2-EEF1-036A-7489-3F4E66893F81> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
0x127479000 - 0x12748dffb +com.adobe.AfterEffects.MotionSketch ??? (???) <5DB4467F-168A-9825-7232-9AA597F1D8E7> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
0x12749b000 - 0x1278effff +com.adobe.AfterEffects.Scripting ??? (???) <30DCC64F-3810-2CEB-CC73-C5C9A46A457F> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
0x127a7b000 - 0x127a9bffb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
0x127b23000 - 0x127b28ff7 +com.adobe.AfterEffects.Drop_Shadow ??? (???) <E88AF7BE-0C87-B609-188B-2978B3E98C1D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Drop_Shadow.plugin/Contents/MacOS/Drop_Shadow
0x127e63000 - 0x128ccbff3 +com.adobe.adobeswfl ??? (2.0.0.10053) <ADE7E8AA-80B6-7BAC-8205-13D7A0E89DF8> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundl e/Contents/MacOS/AdobeSWFL
0x12a013000 - 0x12a051ff7 com.apple.DP.ScreenInputDevice 13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevi ce
0x12a452000 - 0x12a47afff com.apple.mio.DAL.VDC_4 134.0 (1160) <B7B57FA5-1C74-149A-43D1-51DE9479B521> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/VDC.plugin/Contents/MacOS/VDC
0x12a788000 - 0x12a79ffe7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <5C25B45F-7A9E-3259-0532-E13B34B5398A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x12a7a3000 - 0x12a7b2fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <50541300-118F-BE28-86DB-0F42738A9338> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0x12a7b6000 - 0x12a7c8fff libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <CC30A563-5E4C-7ACE-3B73-90E8F582171A> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0x12a7cc000 - 0x12a7edfef libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <1CC25A05-9E4C-ACBE-546E-34063A4CEB09> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x12ac78000 - 0x12ac8cffb +com.adobe.AfterEffects.Smoother ??? (???) <AB6F9378-E6E5-4B64-FB32-B18F9A8F0E2E> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
0x12aca8000 - 0x12acaffff +com.adobe.AfterEffects.Tile ??? (???) <9868DBF5-E5C8-88F0-D7B1-FA416485206D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Tile.plugin/Contents/MacOS/Tile
0x12ae31000 - 0x12ae47ff3 +com.adobe.AfterEffects.Wiggler ??? (???) <B4CE3DCA-F16A-5ED9-B267-7C31A31B247D> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
0x12aefb000 - 0x12aefdff7 +com.adobe.AfterEffects.Block_Dissolve ??? (???) <CE684AF7-EFB3-7C91-2365-46C83A3DA0E5> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Block_Dissolve.plugin/Contents/MacOS/Block_Disso lve
0x12b365000 - 0x12b366fff libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <0739FD38-CF46-0ECC-517C-E187C5A3B8D6> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x12c3e6000 - 0x12c3ebfff +com.cycoresystems.CCfx.RadialFastBlur 1.0 (???) <99FEB5F5-6632-30F8-BF7A-0630727642E8> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/RadialFastBlur.plugin/Contents/MacOS/Ra dialFastBlur
0x12c3f8000 - 0x12c3fcfff +com.adobe.AfterEffects.Echo ??? (???) <280225F1-D20C-8AE2-38C0-E42CCF212279> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Echo.plugin/Contents/MacOS/Echo
0x12c6e7000 - 0x12c7e4fff +com.adobe.AfterEffects.RefineMatte ??? (???) <3F9C8C99-5344-DE94-76E1-A8948DAAB8BC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMat te
0x12cc0d000 - 0x12cc4afeb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A /UpdaterNotifications
0x12cc9c000 - 0x12ccbbfe3 +com.adobe.AfterEffects.Jpg ??? (???) <00BF1928-3BCE-599C-22AF-490689F3B369> /Applications/Adobe After Effects CS5/Plug-ins/Format/JPEG.plugin/Contents/MacOS/Jpg
0x12da00000 - 0x12da1dff3 +com.adobe.AfterEffects.TurbulentDisplace ??? (???) <21E77AAE-CCBE-11E0-CF16-850D9ECC56D9> /Applications/Adobe After Effects CS5/Plug-ins/Effects/TurbulentDisplace.plugin/Contents/MacOS/Turbulen tDisplace
0x12da4a000 - 0x12da68fff +com.adobe.MediaCore.ImporterMPEG 1.0 (1.0) <1C6582C0-8E67-11FB-9A1F-18B987DF7949> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/Ma cOS/ImporterMPEG
0x12daf6000 - 0x12dafcfff +com.cycoresystems.CCfx.RadialBlur 1.0 (???) <A18973A2-0422-7386-392C-C1CEF16F6503> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/RadialBlur.plugin/Contents/MacOS/Radial Blur
0x12e100000 - 0x12e161fef +com.mainconcept.mc_mfimport 8.5 (8.5.0.14572) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_mfimport.framework/Versions/8.5/mc_mfi mport
0x12e61a000 - 0x12e6eafff +com.mainconcept.mc_demux_mp4 8.5 (8.5.0.14572) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_demux_mp4.framework/mc_demux_mp4
0x12f6da000 - 0x12f6e0ff7 +com.cycoresystems.CCfx.Repetile 1.0 (???) <E0DA5C96-BBA4-DA99-42C6-6A53CB333CA4> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/Repetile.plugin/Contents/MacOS/Repetile
0x12f6e4000 - 0x12f6e9ff7 +com.cycoresystems.CCfx.LightSweep 1.0 (???) <AA190B8B-96BD-DA5C-43D3-54A2425A487E> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/LightSweep.plugin/Contents/MacOS/LightS weep
0x12f6ed000 - 0x12f6f8fff +com.cycoresystems.CCfx.Glass 1.0 (???) <6A5DA94E-7FB3-D3E3-E38D-52063D2622C0> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/Glass.plugin/Contents/MacOS/Glass
0x130462000 - 0x13046bfff +FastCore ??? (???) <4A676BFE-2C56-9651-EFF7-E804EC45C87F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/FastCore.plugin/Conte nts/MacOS/FastCore
0x131000000 - 0x13102eff3 +MMXCore ??? (???) <0E398A83-FEBA-9272-4A07-04055F56EF16> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MMXCore.plugin/Conten ts/MacOS/MMXCore
0x1310b6000 - 0x131121ff0 +MultiProcessor Support ??? (???) <101FF20A-2063-75D7-76FC-56974AFBAABE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
0x7fff80003000 - 0x7fff80019fe7 com.apple.MultitouchSupport.framework 207.10 (207.10) <1828C264-A54A-7FDD-FE1B-49DDE3F50779> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x7fff8001a000 - 0x7fff80061ff7 com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff80062000 - 0x7fff80219fef com.apple.ImageIO.framework 3.0.4 (3.0.4) <2CB9997A-A28D-80BC-5921-E7D50BBCACA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8021a000 - 0x7fff80230fef libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
0x7fff8023e000 - 0x7fff804c4fff com.apple.security 6.1.1 (37594) <1B4E1ABD-1BB3-DA49-F574-0EEB23E73C6A> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff80542000 - 0x7fff8057ffff com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff80580000 - 0x7fff80586ff7 IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff80587000 - 0x7fff8080aff7 com.apple.Foundation 6.6.4 (751.42) <9A99D378-E97A-8C0F-3857-D0FAA30FCDD5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8080b000 - 0x7fff8081afff com.apple.opengl 1.6.12 (1.6.12) <DE3F0528-7759-CDFD-A2CF-C51D3C9C8B39> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8081b000 - 0x7fff80820ff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x7fff80842000 - 0x7fff80842ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x7fff80843000 - 0x7fff8084cff7 com.apple.DisplayServicesFW 2.3.0 (283) <3D05929C-AB17-B8A4-DC81-87C27C59E664> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
0x7fff808b4000 - 0x7fff8096afff libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F206BE6D-8777-AE6C-B367-7BEA76C14241> /usr/lib/libobjc.A.dylib
0x7fff8096b000 - 0x7fff80991fe7 libJPEG.dylib ??? (???) <6690F15D-E970-2678-430E-590A94F5C8E9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff80992000 - 0x7fff809a6fff libGL.dylib ??? (???) <1EB1BD0F-C17F-55DF-B8B4-8E9CF99359D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x7fff809a7000 - 0x7fff809aaff7 com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x7fff80a56000 - 0x7fff80a56ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff80a57000 - 0x7fff80b95fff com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff80b96000 - 0x7fff80b9dfff com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x7fff80b9e000 - 0x7fff80bd9fff com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x7fff80ca5000 - 0x7fff80cf1fff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff80cf2000 - 0x7fff80d41fef libTIFF.dylib ??? (???) <AE9DC484-1382-F7AD-FE25-C28082FCB5D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff810d3000 - 0x7fff8113bfff com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x7fff8113c000 - 0x7fff81167ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
0x7fff811a7000 - 0x7fff81264ff7 com.apple.CoreServices.OSServices 357 (357) <718F0719-DC9F-E392-7C64-9D7DFE3D02E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x7fff81265000 - 0x7fff81297fff libTrueTypeScaler.dylib ??? (???) <B9ECE1BD-A716-9F65-6466-4444D641F584> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff81298000 - 0x7fff812d1fef libcups.2.dylib 2.8.0 (compatibility 2.0.0) <561D0DCB-47AD-A12C-9066-70E4CBAD331C> /usr/lib/libcups.2.dylib
0x7fff812d2000 - 0x7fff812d3ff7 com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <14F14B5E-9287-BC36-0C3F-6592E6696CD4> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8131f000 - 0x7fff8132aff7 com.apple.HelpData 2.0.4 (34) <B44D2E2A-BC1E-CD63-F8A1-C9465491693A> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
0x7fff8132b000 - 0x7fff81350ff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff81461000 - 0x7fff8153bff7 com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x7fff81544000 - 0x7fff81555fff com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x7fff81755000 - 0x7fff81755ff7 com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff81756000 - 0x7fff81a8afff com.apple.CoreServices.CarbonCore 861.23 (861.23) <08F360FA-1771-4F0B-F356-BEF68BB9D421> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff81a8b000 - 0x7fff81b40fe7 com.apple.ColorSync 4.6.3 (4.6.3) <AA93AD96-6974-9104-BF55-AF7A813C8A1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff81b41000 - 0x7fff81c5afef libGLProgrammability.dylib ??? (???) <4F2DC233-7DD2-1204-CAA5-3E6524F0AB75> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x7fff81c5b000 - 0x7fff81c95fff libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <C7153747-50E3-32DA-426F-CC4C505D1D6C> /usr/lib/libssl.0.9.8.dylib
0x7fff81c96000 - 0x7fff81d57fe7 libFontParser.dylib ??? (???) <8B12D37E-3A95-5A73-509C-3AA991E0C546> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff81d58000 - 0x7fff81dbafe7 com.apple.datadetectorscore 2.0 (80.7) <04093091-088D-79D9-0B86-E551E5833E7F> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x7fff81eb4000 - 0x7fff81edcfff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff81edd000 - 0x7fff823e1fe7 com.apple.VideoToolbox 0.484.20 (484.20) <8B6B82D2-350B-E9D3-5433-51453CDA65B4> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
0x7fff823e2000 - 0x7fff8242cff7 com.apple.Metadata 10.6.3 (507.15) <5170FCE0-ED6C-2E3E-AB28-1DDE3F628FC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x7fff8246f000 - 0x7fff8265efe7 com.apple.JavaScriptCore 6533.19 (6533.19.1) <233B3E34-CDC4-668A-529A-7E61D510D991> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
0x7fff8265f000 - 0x7fff82680fff libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
0x7fff82681000 - 0x7fff8269afff com.apple.CFOpenDirectory 10.6 (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff826db000 - 0x7fff82ab5fff com.apple.RawCamera.bundle 3.4.1 (546) <F7865FD2-4869-AB19-10AA-EFF1B3BC4178> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x7fff82aec000 - 0x7fff82bd1fef com.apple.DesktopServices 1.5.9 (1.5.9) <27890B2C-0CD2-7C27-9D0C-D5952C5E8438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x7fff82c08000 - 0x7fff82c51fef libGLU.dylib ??? (???) <CCE779A9-2467-A5AA-A558-691E43A1105F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x7fff83056000 - 0x7fff8309fff7 com.apple.securityinterface 4.0.1 (40418) <E2DC796D-84EC-48F5-34A9-DF614573BE74> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
0x7fff830a0000 - 0x7fff8343dfe7 com.apple.QuartzCore 1.6.3 (227.34) <215222AF-B30A-7CE5-C46C-1A766C1D1D2E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff835d3000 - 0x7fff8369efe7 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <3C223A94-EF14-28C5-844B-C25DFC87FB42> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/C olorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x7fff8369f000 - 0x7fff836fffe7 com.apple.framework.IOKit 2.0 (???) <D107CB8A-5182-3AC4-35D0-07068A695C05> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff83751000 - 0x7fff837cffff com.apple.CoreText 3.5.0 (???) <4D5C7932-293B-17FF-7309-B580BB1953EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x7fff837d0000 - 0x7fff83818ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x7fff83820000 - 0x7fff83867fff com.apple.QuickLookFramework 2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff83884000 - 0x7fff83939fe7 com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x7fff8393a000 - 0x7fff83a60fff com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <B51023BB-A5C9-3C65-268B-6B86B901BB2C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x7fff83b32000 - 0x7fff83b34fff libRadiance.dylib ??? (???) <76438F90-DD4B-9941-9367-F2DFDF927876> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff83b35000 - 0x7fff83bd5fff com.apple.LaunchServices 362.2 (362.2) <A8EDC37C-1D40-5ED0-49BE-90EF110A6B3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff83c4e000 - 0x7fff83c5cff7 libkxld.dylib ??? (???) <4016E9E6-0645-5384-A697-2775B5228113> /usr/lib/system/libkxld.dylib
0x7fff83c69000 - 0x7fff83de0fe7 com.apple.CoreFoundation 6.6.4 (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x7fff83de1000 - 0x7fff83de2fff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff83de3000 - 0x7fff83df9fff com.apple.ImageCapture 6.0.1 (6.0.1) <09ABF2E9-D110-71A9-4A6F-8A61B683E936> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x7fff83dfa000 - 0x7fff83e36fe7 libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A> /usr/lib/libcurl.4.dylib
0x7fff83e37000 - 0x7fff840a1fef com.apple.QuartzComposer 4.2 ({156.28}) <7586E7BD-D3BD-0EAC-5AC9-0BFA3679017C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
0x7fff84d16000 - 0x7fff84d18fff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x7fff84d19000 - 0x7fff84d85ff7 com.apple.CorePDF 1.3 (1.3) <6770FFB0-DEA0-61E0-3520-4B95CCF5D1CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
0x7fff84d86000 - 0x7fff84d8aff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff84d8b000 - 0x7fff84fc6fef com.apple.imageKit 2.0.3 (1.0) <5D18C246-303A-6580-9DC9-79BE79467C95> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
0x7fff84fc7000 - 0x7fff85185fff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <781E7B63-2AD0-E9BA-927C-4521DB616D02> /usr/lib/libicucore.A.dylib
0x7fff852a7000 - 0x7fff852acfff libGFXShared.dylib ??? (???) <991F8197-FD06-2AF1-F99B-E448ED4FB2AC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x7fff852ad000 - 0x7fff855abfe7 com.apple.HIToolbox 1.6.4 (???) <263AD497-F4CC-9610-E7D3-B95CF6F02030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x7fff855ac000 - 0x7fff855f1fff com.apple.CoreMediaIOServices 134.0 (1160) <033C41A6-EB9B-6B3B-781A-AF001A945C7A> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
0x7fff855f2000 - 0x7fff85615fff com.apple.opencl 12.3 (12.3) <D30A45FC-4520-45AF-3CA5-092313DB5D54> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff85616000 - 0x7fff85636ff7 com.apple.DirectoryService.Framework 3.6 (621.9) <FF6567B5-56BD-F3EC-E59D-1EC583C3CF73> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x7fff85637000 - 0x7fff85758fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <48AEAFE1-21F4-B3C8-4199-35AD5E8D0613> /usr/lib/libcrypto.0.9.8.dylib
0x7fff857a4000 - 0x7fff857a7fff com.apple.help 1.3.1 (41) <E311A81E-9870-A430-1E16-AFF6C92CE6E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x7fff857c0000 - 0x7fff858e8ff7 com.apple.MediaToolbox 0.484.20 (484.20) <628A7245-7ADE-AD47-3368-CF8EDCA6CC1C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
0x7fff858f5000 - 0x7fff85936ff7 com.apple.CoreMedia 0.484.20 (484.20) <42F3B74A-F886-33A0-40EE-8399B12BD32A> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
0x7fff859b5000 - 0x7fff860b206f com.apple.CoreGraphics 1.545.0 (???) <356D59D6-1DD1-8BFF-F9B3-1CE51D2F1EC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff860b3000 - 0x7fff860ceff7 com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x7fff860cf000 - 0x7fff860d5ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x7fff860d6000 - 0x7fff861e0ff7 com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
0x7fff861e1000 - 0x7fff869ebfe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x7fff869ec000 - 0x7fff86a3bfef com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BD71B20B-C530-6D10-47A4-9838CF292911> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0x7fff86a3c000 - 0x7fff86a3cff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff86a3d000 - 0x7fff86a4eff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
0x7fff86a4f000 - 0x7fff86ae9fff com.apple.ApplicationServices.ATS 4.4 (???) <395849EE-244A-7323-6CBA-E71E3B722984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x7fff86b0a000 - 0x7fff86b96fef SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x7fff86ba3000 - 0x7fff86ba3ff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x7fff86ba4000 - 0x7fff86bb6fe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff86bb7000 - 0x7fff86bbcfff libGIF.dylib ??? (???) <9A2723D8-61F9-6D65-D254-4F9273CDA54A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff86bbd000 - 0x7fff86bedfef com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
0x7fff86c3e000 - 0x7fff86c6ffff libGLImage.dylib ??? (???) <1A8E58CF-FA2F-14F7-A097-D34EEA8A7D03> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x7fff86da4000 - 0x7fff86da5fff com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
0x7fff86da6000 - 0x7fff86e35fff com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
0x7fff86e36000 - 0x7fff86eb5fe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <1DD64A62-0DE4-223F-F781-B272FECF80F0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff86eb6000 - 0x7fff86f08ff7 com.apple.HIServices 1.8.2 (???) <7C91D07D-FA20-0882-632F-0CAE4FAC2B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x7fff8707b000 - 0x7fff870beff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <7E30B5F6-99FD-C716-8670-5DD4B4BAED72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff870bf000 - 0x7fff87144ff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff87145000 - 0x7fff8717eff7 com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
0x7fff8717f000 - 0x7fff871c3fe7 com.apple.ImageCaptureCore 1.0.3 (1.0.3) <913FFA89-0AC8-0A8D-CC2A-364CB0F303BA> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
0x7fff871c4000 - 0x7fff87296fe7 com.apple.CFNetwork 454.11.5 (454.11.5) <B3E2BE12-D7AA-5940-632A-1E5E7BF8E6E3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff87297000 - 0x7fff87327fff com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x7fff87328000 - 0x7fff8732eff7 com.apple.CommerceCore 1.0 (6) <E8A1144C-5666-9840-4729-256FE69CDBDB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8732f000 - 0x7fff8732fff7 com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff87330000 - 0x7fff87344ff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff875d7000 - 0x7fff87fcdfff com.apple.AppKit 6.6.7 (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff87fce000 - 0x7fff8800ffff com.apple.SystemConfiguration 1.10.5 (1.10.2) <FB39F09C-57BB-D8CC-348D-93E00C602F7D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x7fff88010000 - 0x7fff88014ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <63F77AC8-84CB-0C2F-8D2B-190EE5CCDB45> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x7fff88015000 - 0x7fff8802aff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff88041000 - 0x7fff8804cff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x7fff8804d000 - 0x7fff8804dff7 com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff88072000 - 0x7fff880afff7 libFontRegistry.dylib ??? (???) <8C69F685-3507-1B8F-51AD-6183D5E88979> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff880b0000 - 0x7fff88169fff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff8816a000 - 0x7fff88179fff com.apple.NetFS 3.2.1 (3.2.1) <FF21DB1E-F425-1005-FB70-BC19CAF4006E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8817a000 - 0x7fff8833bfff libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
0x7fff8837c000 - 0x7fff883bffef libtidy.A.dylib ??? (???) <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
0x7fff883c2000 - 0x7fff88531fe7 com.apple.QTKit 7.6.6 (1756) <250AB242-816D-9F5D-94FB-18BF2AE9AAE7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8854d000 - 0x7fff885a2ff7 com.apple.framework.familycontrols 2.0.2 (2020) <A3CFF697-B9DB-A7E5-3B39-9DA9B34F0595> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x7fff885a3000 - 0x7fff885b0fe7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <397B9057-5CDF-3B19-4E61-9DFD49369375> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff885ba000 - 0x7fff88637fef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff88638000 - 0x7fff8874ffef libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <EE067D7E-15B3-F043-6FBD-10BA31FE76C7> /usr/lib/libxml2.2.dylib
0x7fff8875f000 - 0x7fff8880efff edu.mit.Kerberos 6.5.10 (6.5.10) <F3F76EDF-5660-78F0-FE6E-33B6174F55A4> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8880f000 - 0x7fff88879fe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8887a000 - 0x7fff888ebff7 com.apple.AppleVAFramework 4.10.12 (4.10.12) <1B68BE43-4C54-87F5-0723-0B0A14CD21E8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
0x7fff888ec000 - 0x7fff888edff7 com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x7fff888ee000 - 0x7fff8890bff7 libPng.dylib ??? (???) <14043CBC-329F-4009-299E-DEE411E16134> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff88964000 - 0x7fff88964ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x7fff8898a000 - 0x7fff88b6dfff libType1Scaler.dylib ??? (???) <3A1AFBA4-958E-DD07-297E-DF1FB2C96D7C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x7fff88c3d000 - 0x7fff88c6cff7 com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
0x7fff88c6d000 - 0x7fff88ceffff com.apple.QuickLookUIFramework 2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
0x7fff88cf0000 - 0x7fff88d31fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x7fff88d32000 - 0x7fff88d35ff7 libCoreVMClient.dylib ??? (???) <609598E6-195D-E5D4-3B92-AE8D9768829C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x7fff88d36000 - 0x7fff8917afef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
RAM: 4096MB
Machine: i386
Model: iMac10,1
CPU * Core count: 2
CPU Frequency: 3060MHz
Bus Frequency: 1064MHz
Open GL Renderer: ATI Radeon HD 4850 OpenGL Engine
Open GL Version: 2.1 ATI-1.6.26
Open GL Vendor: ATI Technologies Inc.
Open GL Extensions: L_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_vertex_blend, GL_ARB_window_pos, GL_ARB_shader_objects, GL_ARB_vertex_shader, GL_ARB_shading_language_100, GL_EXT_multi_draw_arrays, GL_EXT_clip_volume_hint, GL_EXT_rescale_normal, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_gpu_program_parameters, GL_EXT_geometry_shader4, GL_EXT_transform_feedback, GL_APPLE_client_storage, GL_APPLE_specular_vector, GL_APPLE_transform_hint, GL_APPLE_packed_pixels, GL_APPLE_fence, GL_APPLE_vertex_array_object, GL_APPLE_vertex_program_evaluators, GL_APPLE_element_array, GL_APPLE_flush_render, GL_APPLE_aux_depth_stencil, GL_NV_texgen_reflection, GL_NV_light_max_exponent, GL_IBM_rasterpos_clip, GL_SGIS_generate_mipmap, GL_ARB_imaging, GL_ARB_point_parameters, GL_ARB_texture_env_crossbar, GL_ARB_texture_border_clamp, GL_ARB_multitexture, GL_ARB_texture_env_add, GL_ARB_texture_cube_map, GL_ARB_texture_env_dot3, GL_ARB_multisample, GL_ARB_texture_env_combine, GL_ARB_texture_compression, GL_ARB_texture_mirrored_repeat, GL_ARB_shadow, GL_ARB_depth_texture, GL_ARB_shadow_ambient, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_occlusion_query, GL_ARB_point_sprite, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object, GL_ARB_pixel_buffer_object, GL_ARB_draw_buffers, GL_ARB_shader_texture_lod, GL_ARB_color_buffer_float, GL_ARB_half_float_vertex, GL_ARB_texture_rg, GL_ARB_texture_compression_rgtc, GL_ARB_framebuffer_object, GL_EXT_compiled_vertex_array, GL_EXT_draw_buffers2, GL_EXT_framebuffer_object, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample, GL_EXT_texture_rectangle, GL_ARB_texture_rectangle, GL_EXT_texture_env_add, GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_lod_bias, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_stencil_wrap, GL_EXT_texture_filter_anisotropic, GL_EXT_separate_specular_color, GL_EXT_secondary_color, GL_EXT_blend_func_separate, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_dxt1, GL_EXT_texture_sRGB, GL_EXT_blend_equation_separate, GL_EXT_texture_mirror_clamp, GL_EXT_packed_depth_stencil, GL_EXT_bindable_uniform, GL_EXT_texture_integer, GL_EXT_gpu_shader4, GL_EXT_framebuffer_sRGB, GL_EXT_provoking_vertex, GL_APPLE_flush_buffer_range, GL_APPLE_ycbcr_422, GL_APPLE_rgb_422, GL_APPLE_vertex_array_range, GL_APPLE_texture_range, GL_APPLE_float_pixels, GL_ATI_texture_float, GL_ARB_texture_float, GL_ARB_half_float_pixel, GL_APPLE_pixel_buffer, GL_APPLE_object_purgeable, GL_NV_blend_square, GL_NV_fog_distance, GL_NV_conditional_render, GL_ATI_texture_mirror_once, GL_ATI_blend_equation_separate, GL_ATI_blend_weighted_minmax, GL_ATI_texture_env_combine3, GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGI_color_matrix, GL_EXT_texture_array, GL_EXT_vertex_array_bgra, GL_ARB_instanced_arrays, GL_ARB_depth_buffer_float, GL_EXT_packed_float, GL_EXT_texture_shared_exponent
Reproduction Steps: Please provide a detailed description, including all of the steps required to reproduce the crash.
User GUID: 9017ED05-771E-45BA-9A73-ACE05EEA114E
Crash GUID: 673145D4-2E8D-4AA7-B4A7-3FEC3F0B7067
