AE CS5 crashing after 20 seconds (on EVERY render)
Mar 3, 2011 12:27 PM
I apologize if this is not the right place to post my crash info but Adobe's link to the "post your crash info here" only links to their blog which contains no content.
Anyway I am a new user to AE and am trying to render a movie.  However, every time I attempt to render the video it gets to about 20 seconds into the clip and then the program crashes.  I've attempted to remove the audio and uncheck the OpenGL boxes but neither seem to do the trick.  I'm really not sure what to do or where to look because I'm not that familiar with the program and have not been able to get a successful render out of AE.
I am running an iMac with OSX 10.6.6, 3.06 GHz Intel Core 2 Duo with 4GB RAM.  I have uninstalled and re-installed the software but still get the same results during render.
Here is my crash report (any ideas, suggestions, or advice would be greatly appreciated):
Process:         After Effects [1575]
Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
Identifier:      com.adobe.AfterEffects
Version:         10.0 (10.0)
Code Type:       X86-64 (Native)
Parent Process:  launchd [128]
Date/Time:       2011-03-03 15:17:52.922 -0500
OS Version:      Mac OS X 10.6.6 (10J567)
Report Version:  6
Exception Type:  EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000adbdb2c3
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   libSystem.B.dylib                 0x00007fff881c9616 __kill + 10
1   libSystem.B.dylib                 0x00007fff88269cca abort + 83
2   U.dylib                           0x0000000102a88867 U_LoadFrameworkBundle + 695
3   libSystem.B.dylib                 0x00007fff881db67a _sigtramp + 26
4   ???                               0x00007fff5fbfa3a0 0 + 140734799782816
5   com.apple.CoreText                0x00007fff8375c2dc TKerningEngine::KernLine(TCharStream const*) + 276
6   com.apple.CoreText                0x00007fff8375c1aa TTypesetter::FinishLayout(TLine&, TCharStream const&) const + 28
7   com.apple.CoreText                0x00007fff83756e01 TTypesetterAttrString::Initialize() + 335
8   com.apple.CoreText                0x00007fff83756a4a CTLineCreateWithAttributedString + 48
9   com.adobe.dvaui.framework         0x00000001031953f6 dvaui::drawbot::CoreTextStringDisplayInterface::MeasureStringWidth() const + 86
10  com.adobe.dvaui.framework         0x00000001031a2e75 dvaui::drawbot::CoreTextFontInterface::MeasureStringWidth(unsigned short const*, int) const + 197
11  com.adobe.dvaui.framework         0x000000010319793d dvaui::drawbot::OSSurfaceInterface::MeasureStringWidth(dvaui::drawbot ::FontInterface const&, unsigned short const*, int) + 109
12  ...e.AfterEffectsLib.framework    0x00000001006654e0 EDB_DrawString(dvaui::drawbot::Drawbot*, dvaui::drawbot::ColorRGBA const&, dvaui::drawbot::FontInterface const*, float, float, std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> > const&, dvaui::drawbot::TextAlignment, dvaui::drawbot::TextTruncation, float) + 384
13  ...e.AfterEffectsLib.framework    0x0000000100a717ed CRender::RegisterDestroyListener(boost::function0<void>) + 25613
14  ...e.AfterEffectsLib.framework    0x0000000100a8776a GetCRender(CProject*) + 88234
15  ...e.AfterEffectsLib.framework    0x0000000100a88084 GetCRender(CProject*) + 90564
16  ...e.AfterEffectsLib.framework    0x0000000100a83614 GetCRender(CProject*) + 71508
17  ...e.AfterEffectsLib.framework    0x0000000100a6dc92 CRender::RegisterDestroyListener(boost::function0<void>) + 10418
18  ...e.AfterEffectsLib.framework    0x0000000100693eac TerminateRenderTimeout() + 8844
19  ...e.AfterEffectsLib.framework    0x000000010060e16b CEggApp::HasWatchFolderDialog() + 107
20  BEE.dylib                         0x0000000101204e3a BEE_NewFauxComp(BEE_CompItem**) + 15402
21  BEE.dylib                         0x00000001013028c0 BEE_CmdMakeMovie(unsigned char, int*, BEE_MakeMovieParams*, unsigned char*) + 656
22  ...e.AfterEffectsLib.framework    0x0000000100a73a52 GetCRender(CProject*) + 7058
23  ...e.AfterEffectsLib.framework    0x0000000100a70fac CRender::RegisterDestroyListener(boost::function0<void>) + 23500
24  ...e.AfterEffectsLib.framework    0x0000000100a67983 GetCProject(unsigned char) + 34627
25  ...e.AfterEffectsLib.framework    0x0000000100a172c6 COutlineDir::GetOutlinePano() + 1222
26  ...e.AfterEffectsLib.framework    0x00000001004b00e6 unsigned short* std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> >::_S_construct<unsigned short*>(unsigned short*, unsigned short*, std::allocator<unsigned short> const&, std::forward_iterator_tag) + 27782
27  com.adobe.dvaui.framework         0x000000010305d05f void dvaui::ui::SendMessageT<boost::shared_ptr<boost::function<void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> >, dvaui::ui::MessageT<dvaui::ui::UI_Node> >(boost::shared_ptr<boost::function<void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > const&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 31
28  com.adobe.dvaui.framework         0x000000010305d09c void dvaui::ui::SendMessagesT<dvacore::utility::SharedFunctions<boost::sha red_ptr<boost::function<void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > >, dvaui::ui::MessageT<dvaui::ui::UI_Node> >(dvacore::utility::SharedFunctions<boost::shared_ptr<boost::function <void ()(dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > > const&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 44
29  com.adobe.dvaui.framework         0x000000010304e6ce dvaui::controls::UI_Button::SendButtonChangedMessage(dvacore::utility ::Flags<unsigned char>) + 78
30  com.adobe.dvaui.framework         0x000000010304e35d dvaui::controls::UI_Button::PerformAction(bool, dvacore::utility::Flags<unsigned char>, bool) + 125
31  com.adobe.dvaui.framework         0x000000010304f3cc dvaui::controls::ButtonInputCapture::End() + 76
32  com.adobe.dvaui.framework         0x00000001031d586f dvaui::ui::InputCapture::InvokeEnd(bool) + 239
33  com.adobe.dvaui.framework         0x00000001031d592c dvaui::ui::UI_NodeManager::EndInputCapture(bool) + 76
34  com.adobe.dvaui.framework         0x000000010305005f dvaui::controls::ButtonInputCapture::DoMouseEvent(dvaui::ui::MouseEve nt const&) + 335
35  com.adobe.dvaui.framework         0x00000001031e0b1d dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEve nt const&) + 605
36  com.adobe.dvaui.framework         0x00000001031e0da9 dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node* , dvaui::ui::MouseEvent const&, bool) + 121
37  com.adobe.dvaui.framework         0x00000001031e0eb4 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
38  com.adobe.dvaui.framework         0x0000000103254433 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEve nt const&, bool) + 595
39  com.adobe.dvaui.framework         0x0000000103250249 dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_ Event const&) + 313
40  com.adobe.dvaui.framework         0x00000001032568cc dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 492
41  com.adobe.dvaui.framework         0x000000010324138f dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
42  com.adobe.dvaui.framework         0x000000010324708b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
43  com.adobe.dvacore.framework       0x0000000102d4ce16 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0 <void>*, void*) + 38
44  ...e.AfterEffectsLib.framework    0x0000000100662946 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
45  ...e.AfterEffectsLib.framework    0x0000000100662a71 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
46  com.adobe.dvacore.framework       0x0000000102d4bcf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHa ndler<void>(boost::function0<void>, bool*) + 197
47  com.adobe.dvacore.framework       0x0000000102d4dc83 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void> , bool*) + 99
48  com.adobe.dvaui.framework         0x0000000103249cbd -[DVAMacContainerView mouseUp:] + 253
49  com.apple.AppKit                  0x00007fff877143d9 -[NSWindow sendEvent:] + 5547
50  com.apple.AppKit                  0x00007fff87649a86 -[NSApplication sendEvent:] + 4719
51  com.adobe.dvaui.framework         0x0000000103242d6f -[DVAMacApplication sendEvent:] + 223
52  ...e.AfterEffectsLib.framework    0x0000000100470ac3 0x10046a000 + 27331
53  com.apple.AppKit                  0x00007fff875e04da -[NSApplication run] + 474
54  ...e.AfterEffectsLib.framework    0x00000001006b6a12 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 16386
55  ...e.AfterEffectsLib.framework    0x0000000100660dcc SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
56  ...e.AfterEffectsLib.framework    0x0000000100661494 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
57  com.adobe.AfterEffects            0x00000001000043b8 main + 1144
58  com.adobe.AfterEffects            0x0000000100003895 _start + 227
59  com.adobe.AfterEffects            0x00000001000037b1 start + 33
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib                 0x00007fff8819416a kevent + 10
1   libSystem.B.dylib                 0x00007fff8819603d _dispatch_mgr_invoke + 154
2   libSystem.B.dylib                 0x00007fff88195d14 _dispatch_queue_invoke + 185
3   libSystem.B.dylib                 0x00007fff8819583e _dispatch_worker_thread2 + 252
4   libSystem.B.dylib                 0x00007fff88195168 _pthread_wqthread + 353
5   libSystem.B.dylib                 0x00007fff88195005 start_wqthread + 13
Thread 2:
0   libSystem.B.dylib                 0x00007fff881b5fca __semwait_signal + 10
1   libSystem.B.dylib                 0x00007fff881b9de1 _pthread_cond_wait + 1286
2   com.adobe.amt.services            0x000000010c68dc53 AMTConditionLock::LockWhenCondition(int) + 37
3   com.adobe.amt.services            0x000000010c686cce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
4   com.adobe.amt.services            0x000000010c68dcbe AMTThread::Worker(void*) + 28
5   libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
6   libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 3:
2   ...ple.CoreServices.CarbonCore    0x00007fff8181be27 TSWaitOnCondition + 118
3   ...ple.CoreServices.CarbonCore    0x00007fff8178b310 TSWaitOnConditionTimedRelative + 177
4   ...ple.CoreServices.CarbonCore    0x00007fff8178521b MPWaitOnQueue + 215
5   ...e.Frameworks.ASL.Foundation    0x0000000104dc2000 ASL::(anonymous namespace)::TaskProc(void*) + 96
6   ...ple.CoreServices.CarbonCore    0x00007fff8175d411 PrivateMPEntryPoint + 63
7   libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
8   libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 4:
5   AdobeACE                          0x0000000108eb723d 0x108e7d000 + 238141
6   AdobeACE                          0x0000000108eb6bea 0x108e7d000 + 236522
7   ...ple.CoreServices.CarbonCore    0x00007fff8175d411 PrivateMPEntryPoint + 63
8   libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
9   libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 5:
5   com.adobe.dvacore.framework       0x0000000102db4a1f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
6   com.adobe.dvacore.framework       0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
7   com.adobe.dvacore.framework       0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
8   ...obe.boost_threads.framework    0x0000000107f8dac4 thread_proxy + 132
9   libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
10  libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
1   ...dobe.dvatransport.framework    0x0000000107ce7c4e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
2   ...dobe.dvatransport.framework    0x0000000107ce8d05 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reac tor<false> >::run(boost::system::error_code&) + 517
3   ...dobe.dvatransport.framework    0x0000000107cc68cc SkyConnectionEnv::MainLoop() + 76
4   ...dobe.dvatransport.framework    0x0000000107cc6939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
5   ...obe.boost_threads.framework    0x0000000107f8dac4 thread_proxy + 132
6   libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
7   libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 13:
2   ...dobe.dvatransport.framework    0x0000000107ce8e3f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reac tor<false> >::run(boost::system::error_code&) + 831
3   ...dobe.dvatransport.framework    0x0000000107ce9a35 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver _service<boost::asio::ip::tcp>::work_io_service_runner>::run() + 53
4   ...dobe.dvatransport.framework    0x0000000107ccec79 asio_detail_posix_thread_function + 25
Thread 14:
Thread 15:
Thread 16:
Thread 17:
2   com.adobe.AfterEffects.MThread    0x000000012049ba8f main + 20783
3   com.adobe.dvacore.framework       0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
4   com.adobe.dvacore.framework       0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
Thread 18:
Thread 19:
Thread 20:
2   com.adobe.AfterEffects.OpenEXR    0x0000000126dbf4c6 IlmThread::Semaphore::wait() + 70
3   com.adobe.AfterEffects.OpenEXR    0x0000000126dbe33c IlmThread::(anonymous namespace)::WorkerThread::run() + 188
4   libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
5   libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 21:
Thread 22:
1   libSystem.B.dylib                 0x00007fff881b5e59 nanosleep + 148
2   ...dobe.AfterEffects.Scripting    0x0000000127739fbb zcfree + 197989
3   ...dobe.AfterEffects.Scripting    0x000000012771cfd3 zcfree + 79229
4   ...dobe.AfterEffects.Scripting    0x000000012773a0b6 zcfree + 198240
Thread 23:
2   com.adobe.adobeswfl               0x00000001280ea89d APXGetHostAPI + 2465805
3   com.adobe.adobeswfl               0x0000000127ea35e9 APXGetHostAPI + 77145
4   com.adobe.adobeswfl               0x00000001280ea9b1 APXGetHostAPI + 2466081
5   com.adobe.adobeswfl               0x00000001280ead1a APXGetHostAPI + 2466954
6   com.adobe.adobeswfl               0x00000001280eae49 APXGetHostAPI + 2467257
Thread 24:
Thread 25:
0   libSystem.B.dylib                 0x00007fff8817b2da mach_msg_trap + 10
1   libSystem.B.dylib                 0x00007fff8817b94d mach_msg + 59
2   com.apple.CoreFoundation          0x00007fff83cb5932 __CFRunLoopRun + 1698
3   com.apple.CoreFoundation          0x00007fff83cb4dbf CFRunLoopRunSpecific + 575
4   com.apple.CoreMediaIOServices     0x00007fff855ba62b MIO::DAL::RunLoop::OwnThread(void*) + 147
5   com.apple.CoreMediaIOServices     0x00007fff855bc1f6 CAPThread::Entry(CAPThread*) + 140
Thread 26:
0   libSystem.B.dylib                 0x00007fff8817b33a semaphore_timedwait_signal_trap + 10
1   libSystem.B.dylib                 0x00007fff881b9cd2 _pthread_cond_wait + 1015
2   com.adobe.adobeswfl               0x00000001280ea869 APXGetHostAPI + 2465753
3   com.adobe.adobeswfl               0x00000001281070ec APXGetHostAPI + 2582620
Thread 27:
3   com.adobe.adobeswfl               0x0000000128284ef3 APXGetHostAPI + 4146787
Thread 28:
2   libtbb.dylib                      0x000000010001222c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
3   libtbb.dylib                      0x000000010001cb84 tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>:: wait_for_all(tbb::task&, tbb::task*) + 1858
4   libtbb.dylib                      0x0000000100014e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
Thread 29:
2   com.apple.audio.CoreAudio         0x00007fff86e5467c CAGuard::WaitFor(unsigned long long) + 168
3   com.apple.audio.CoreAudio         0x00007fff86e56c0b CAGuard::WaitUntil(unsigned long long) + 185
4   com.apple.audio.CoreAudio         0x00007fff86e54d75 HP_IOThread::WorkLoop() + 1369
5   com.apple.audio.CoreAudio         0x00007fff86e54817 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
6   com.apple.audio.CoreAudio         0x00007fff86e54745 CAPThread::Entry(CAPThread*) + 125
Thread 30:
0   libSystem.B.dylib                 0x00007fff8817b32e semaphore_timedwait_trap + 10
1   ...ple.CoreServices.CarbonCore    0x00007fff817f21f2 MPWaitOnSemaphore + 96
2   MultiProcessor Support            0x00000001310ebbd1 ThreadFunction(void*) + 69
3   ...ple.CoreServices.CarbonCore    0x00007fff8175d411 PrivateMPEntryPoint + 63
Thread 31:
0   libSystem.B.dylib                 0x00007fff88194f8a __workq_kernreturn + 10
1   libSystem.B.dylib                 0x00007fff8819539c _pthread_wqthread + 917
2   libSystem.B.dylib                 0x00007fff88195005 start_wqthread + 13
Thread 32:
Thread 33:
2   ...aCore.ExporterQuickTimeHost    0x0000000121eae3b5 dvacore::threads::Gate::PassThrough(int) const + 501
3   ...aCore.ExporterQuickTimeHost    0x0000000121ea8666 ExporterQuickTimeHost::DoExportRemote() + 390
4   ...aCore.ExporterQuickTimeHost    0x0000000121ea978f ExporterQuickTimeHost::DoExport() + 447
5   ...aCore.ExporterQuickTimeHost    0x0000000121ea4c31 PrExporterModule<ExporterQuickTimeHost>::ExportEntry(int, exportStdParms*, void*, void*) + 1329
6   ...aCore.ExporterQuickTimeHost    0x0000000121ea43db xSDKExport + 59
7   ...ore.Frameworks.ExporterHost    0x000000010b094009 ML::ExporterPluginModule::CallExportModule(int, void*, void*) + 121
8   ...ore.Frameworks.ExporterHost    0x000000010b028b8a ML::Exporter::MovieExport(std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> > const&, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&) + 794
9   ...ore.Frameworks.ExporterHost    0x000000010b029432 ML::Exporter::BeginThreadExport() + 1266
10  ...ore.Frameworks.ExporterHost    0x000000010b02b59a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, boost::_mfi::mf0<void, ML::Exporter>, boost::_bi::list1<boost::_bi::value<ASL::InterfaceRef<ML::Exporter, ML::IExporter> > > >, void>::invoke(boost::detail::function::function_buffer&) + 74
11  com.adobe.dvacore.framework       0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
12  com.adobe.dvacore.framework       0x0000000102db4a9b dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 267
13  com.adobe.dvacore.framework       0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
14  com.adobe.dvacore.framework       0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
15  ...obe.boost_threads.framework    0x0000000107f8dac4 thread_proxy + 132
16  libSystem.B.dylib                 0x00007fff881b4536 _pthread_start + 331
17  libSystem.B.dylib                 0x00007fff881b43e9 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00007fff5fbf9ee0  rcx: 0x00007fff5fbf9eb8  rdx: 0x0000000000000000
  rdi: 0x0000000000000627  rsi: 0x0000000000000006  rbp: 0x00007fff5fbf9ed0  rsp: 0x00007fff5fbf9eb8
   r8: 0x0000000102a95768   r9: 0x000000013700f530  r10: 0x00007fff881c5656  r11: 0x0000000000000202
  r12: 0x00007fff5fbf9ef0  r13: 0x00000000adbdb2bf  r14: 0x00000000003e0343  r15: 0x0000000000000001
  rip: 0x00007fff881c9616  rfl: 0x0000000000000202  cr2: 0x000000010df60c00
Binary Images:
       0x100000000 -        0x100004ff3 +com.adobe.AfterEffects 10.0 (10.0) <B62CE36E-00B7-40DC-AF97-9E7B36EEFA6E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
       0x100009000 -        0x100022feb +libtbb.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbb.dylib
       0x100033000 -        0x100039feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbbmalloc.dylib
       0x100040000 -        0x10004cff5 +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.213330) <B3758C21-93F6-9D51-627E-048EAB1F910C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_ signals
       0x10005e000 -        0x10005ffff +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.213330) <82B9A0E9-66BD-2DE0-E5B8-3388B845A8B0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_s ystem
       0x100065000 -        0x10006cff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.213330) <3A6F2741-13E1-DBB5-BD25-B3E2CB12C76A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boos t_date_time
       0x10007c000 -        0x100081ffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
       0x100086000 -        0x1001c9fef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
       0x100215000 -        0x100319fef +hydra_filters ??? (???) <1AD09F41-C78B-9165-22C1-47F60212929C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_ filters
       0x10040e000 -        0x10042cfff +image_runtime ??? (???) <5342D969-98CB-14EE-FA4C-2252BACA7EE3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
       0x100466000 -        0x100467fff +ALOG.dylib ??? (???) <4B83A1E3-4434-2FF3-BF5B-058071B8FD11> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
       0x10046a000 -        0x100e3dfef +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0) <4F38252D-5225-1F2F-AB2D-87E378C374B5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLi b
       0x101196000 -        0x101196ff7 +AEFX.dylib ??? (???) <968DD1F9-D953-8D56-7F8E-642C726D2074> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
       0x101199000 -        0x101554fe7 +BEE.dylib ??? (???) <535F8287-BE3D-E4AE-D3E1-AA42556DB8AA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
       0x10179d000 -        0x1017acff3 +BEZ.dylib ??? (???) <238C2EC9-975E-AF5F-DF9F-F461CECF923A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
       0x1017b0000 -        0x1017bbff3 +BM.dylib ??? (???) <11FD882B-A0B3-E8B8-C9CA-C7032CA77AC9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
       0x1017c2000 -        0x1017fdfff +COR.dylib ??? (???) <C8ECFB66-6A1A-2347-7E3C-8435C453D054> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
       0x101819000 -        0x101839ff7 +FILE.dylib ??? (???) <85DDDB02-4419-3CA9-2727-4C8108C9C5D9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
       0x101847000 -        0x101874fff +FLO.dylib ??? (???) <973923DA-9557-6DC7-9E00-D68F02975BC3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
       0x10187a000 -        0x10193dfff +FLT.dylib ??? (???) <F5DFA745-95FD-5CBD-CBC6-92A83EFB1F54> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
       0x1019a0000 -        0x1019a7ff3 +LIST.dylib ??? (???) <6EE40DE3-CCB7-5F5A-C6CF-3E241F97D625> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
       0x1019ab000 -        0x1019befff +M.dylib ??? (???) <ED7686CA-1D79-06E9-2410-F341B614EF7C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
       0x1019c3000 -        0x1019ccff7 +MC.dylib ??? (???) <84B8D9F9-17F6-DBF4-E9C4-B8955D37ECE2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
       0x1019d3000 -        0x101a33fff +MSK.dylib ??? (???) <AE2DB0DA-B97A-41BD-D708-BBC62C667E3A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
       0x101a47000 -        0x101a5eff7 +OM.dylib ??? (???) <EB18BEA8-DA5D-4E14-BD54-C23E7B576014> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
       0x101a66000 -        0x101a88ff7 +P.dylib ??? (???) <D8239475-F2D0-2445-C857-773E1D92B040> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
       0x101a91000 -        0x101ddafff +PF.dylib ??? (???) <B321B849-7071-DCA6-878F-BB885D6C4D66> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
       0x101e16000 -        0x10201ffff +PIN.dylib ??? (???) <DEE97322-EB9F-8D8C-4820-5ADCD5A426D0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
       0x1020a0000 -        0x1020bafff +PLUG.dylib ??? (???) <F1B84FA7-F1C0-D8D2-0027-F398154E7F45> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
       0x1020c5000 -        0x1020d8fff +PR.dylib ??? (???) <3E762A5F-F8F7-1430-1B05-37573C94A87C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
       0x1020df000 -        0x1020e5fff +PREF.dylib ??? (???) <6BAF11D3-62C5-C8FD-A7FE-29EC7B7F295F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
       0x1020e9000 -        0x102101fff +RG.dylib ??? (???) <B5C33D6F-B14C-1D0A-2D2B-F36E53F8ACCE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
       0x10210a000 -        0x10210cff7 +RI.dylib ??? (???) <E160AB31-E857-F4E2-59F6-29AD71E58CAF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
       0x10210f000 -        0x102110fff +RND.dylib ??? (???) <15050D6C-4BC4-E006-67D8-E3799A1A77FE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
       0x102117000 -        0x102176ff7 +SLU.dylib ??? (???) <0FDE1877-43F4-1C28-6537-725004CFA0B5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
       0x10219c000 -        0x1021b8ffd +SND.dylib ??? (???) <08CDA7D2-AB19-3B47-CC30-675FB9C19F1B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
       0x1021c0000 -        0x1021c3ff1 +STR.dylib ??? (???) <404DF8FC-F56E-D1FB-69DA-E62CB2EAAD2D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
       0x1021c7000 -        0x1021cafff +T.dylib ??? (???) <F139D7D3-1962-78FA-1341-4475161F59DF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
       0x1021cd000 -        0x10220aff5 +TDB.dylib ??? (???) <63379742-F508-6083-3038-53BA87A9BAE5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
       0x10221e000 -        0x1028c9fe5 +TXT.dylib ??? (???) <8D482B40-28CE-1FB7-7A6C-FF8463790AC6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
       0x102a68000 -        0x102aa4ff1 +U.dylib ??? (???) <C07391C6-A4F7-A583-4AF9-B9C19171F45A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
       0x102ab8000 -        0x102abcfff +VAL.dylib ??? (???) <DBB9A3A1-F0F3-14E8-C827-0BBDEC116E99> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
       0x102abf000 -        0x102b6ffff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.213330) <CD3B7889-351C-AA13-69AF-27A7AA2DF2F4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
       0x102c76000 -        0x102c9cffb +PREM.dylib ??? (???) <99093041-26A0-051D-9074-DEA7B00B923B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
       0x102cb0000 -        0x102d09fff +FRP.dylib ??? (???) <AFBC28AA-C1BC-04A7-DA65-29A933DA4DB4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
       0x102d26000 -        0x102e84ff7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.213330) <256DF884-9EC1-771E-6E84-7BB625046278> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
       0x102ff8000 -        0x10333fff7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.213330) <8599321B-EE71-853E-EC77-B4A63FF400C9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
       0x103701000 -        0x1037affff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.213330) <FF18DA57-0B63-FDF9-F909-63AF774D945A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
       0x10388b000 -        0x1038abfef +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.213330) <268D30FC-BF51-4FDA-8854-770E8295D2A1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaun ittesting
       0x1038d4000 -        0x1038e4ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x1038ef000 -        0x103967fef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_cap s
       0x10397d000 -        0x1039e2fff +aif_core ??? (???) <4E7ADC1A-0D15-727F-9B79-1C74A8763FD8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
       0x103a24000 -        0x103c53fff +aif_ogl ??? (???) <C97013B9-C1E5-EE50-F924-8ED11043B282> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
       0x103e17000 -        0x103e2dfff +data_flow ??? (???) <C0E0AFA6-8D23-93FB-E5D7-8A2B49D2C268> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
       0x103e60000 -        0x104355fef +image_compiler ??? (???) <C1061733-6169-14E9-37E6-7484293BEA8B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image _compiler
       0x104895000 -        0x10492bfff +image_flow ??? (???) <3FBF0B87-2177-F53C-C3F3-11D51A45239D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
       0x104a11000 -        0x104a50ff7 +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0 (5.0.0.213330) <0E169D79-9960-BCAF-D85B-103665E5678B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynami clinkui
       0x104aa6000 -        0x104c6ffff +com.adobe.dynamiclink.framework dynamiclink version 5.0.0 (5.0.0.213330) <85707809-6236-4E00-285A-580DA81D0094> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamicl ink
       0x104d8d000 -        0x104defff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <BAC830AC-F3F4-037A-6030-7773FA47076E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFou ndation
       0x104ed6000 -        0x104eecfff +ASLMessaging ??? (???) <3E585488-16D5-E499-E089-09C7AA3C1E04> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMess aging
       0x104f0b000 -        0x104f1cffe +ASLUnitTesting ??? (???) <6A743B23-67B8-3BBA-E5B9-E6A255BB40C0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUn itTesting
       0x104f34000 -        0x104f4eff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <88358D58-D8F9-8DF8-8E19-6AB807D63674> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/Audi oFilterHost
       0x104f76000 -        0x104faefff +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <A84B6B9C-CC01-C65D-FDBD-413358A34863> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFi lters
       0x105019000 -        0x105091fe3 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <C561A37C-8C80-C731-F2D6-08F48AAFE579> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioR enderer
       0x10512c000 -        0x10516afe1 +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <9F36FD9D-3708-BFDE-CE6C-D035561137F7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSu pport
       0x1051b3000 -        0x105bfffff +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <F6E47C97-30B8-4EF6-1156-06DBA45672A9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
       0x106915000 -        0x106ab7ff3 +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <32230B4B-6E75-4631-94C0-75DEE05314D8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageR enderer
       0x106be7000 -        0x106d6dff7 +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <2DEA855A-CBE8-9C63-6EF7-72D528776B0F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/Importe rHost
       0x106f2d000 -        0x106f61fff +com.adobe.MediaFoundation ??? (1.0) <78B9FE26-86C1-B44F-BB81-BA21428022FE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Medi aFoundation
       0x106fa4000 -        0x106fa7fff +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <4F4A6550-2BA7-FA81-17C4-023452073551> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtil s
       0x106fac000 -        0x106fadfff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <6D281021-C4AD-0F62-E784-86E6C745AA6D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
       0x106fb2000 -        0x106febfff +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <1CEE4DAB-7AD1-6FC5-C001-A7AAECF05C7B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFound ation
       0x107039000 -        0x10706afff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <55244E51-A1BC-A2E7-84EC-7F8829D94A0C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/Plugin Support
       0x1070a9000 -        0x1070aafff +PRM ??? (???) <285F42C6-5D90-16F9-5650-377D71A935C6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
       0x1070ae000 -        0x1070e6fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <70AD1ED5-A189-83D8-9B39-BAC35CB614AD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/Swee tPeaSupport
       0x107137000 -        0x10717ffff +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <CB52E22B-BDC5-9CE2-392B-A673DA8253B6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFram e
       0x1071cc000 -        0x1072e6fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <F5072641-CA96-EFEF-D30D-8A643021D71C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoR enderer
       0x107450000 -        0x1074f8fe1 +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.213330) <03600AA1-484D-1796-7DD1-C0BA492D14E5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
       0x1075f5000 -        0x107668ff7 +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <9D9CC149-3B1F-A889-334D-9B2BC90212E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHos t
       0x107703000 -        0x1077d5fff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <00A438BC-AC9F-7057-3DA4-432095AD518B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/Vide oFilterHost
       0x107898000 -        0x107902ff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x107935000 -        0x1079d3ff2 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <5651FB7C-24ED-8CC8-2ADE-A5CB7CA493C3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libic ucnv.dylib.36.0
       0x1079f3000 -        0x107a0efff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <FEF83A1C-8D48-66B4-BED6-B91835D1AA68> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata .dylib.36.0
       0x107a11000 -        0x107a6bfff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.213330) <2E79ABD7-FDFA-B909-7635-64D2B984C8BD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametad ata
       0x107aed000 -        0x107b71fff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.213330) <91D6B7F4-A965-0036-BD98-DE8BF3CFB30C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvamet adataUI
       0x107c08000 -        0x107c4cff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.213330) <5165B4D5-5AD0-F846-5586-235DDF01078D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvate mporalxmp
       0x107c6c000 -        0x107c85fff +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.213330) <DC398F51-93E0-DB11-4A2B-8EA4C1CAE7CC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamed iatypes
       0x107ca4000 -        0x107d1aff7 +com.adobe.dvatransport.framework dvatransport version 5.0.0 (5.0.0.213330) <4F4DB4F1-FBD8-E774-8C33-830B243C4BA3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatran sport
       0x107d9d000 -        0x107dd9ff3 +com.adobe.dvamarshal.framework dvamarshal version 5.0.0 (5.0.0.213330) <EEF373F8-AB3B-609F-6A9D-832B4132DC90> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarsha l
       0x107e45000 -        0x107e53fff +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <603AF6EE-8B98-6E0F-BFB9-1B48594EE6B4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/Proje ctSupport
       0x107e67000 -        0x107eaafff +DynamicLinkMedia ??? (???) <0353ADA3-82A5-E934-42A0-3A983A7285EF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/Dyn amicLinkMedia
       0x107f17000 -        0x107f17ff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
       0x107f1a000 -        0x107f45ff6 +AdobeAXE8SharedExpat ??? (???) <F5C1010B-CAFF-5290-8B55-6FEB3A287225> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
       0x107f57000 -        0x107f5dff7  com.apple.agl 3.0.12 (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x107f64000 -        0x107f81fff +AdobeBIB ??? (???) <2F1CE9F9-0D9A-3914-C0FE-E20CC5F1F9F7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x107f8b000 -        0x107f93ff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.213330) <34EE0EBB-3B3C-B838-97DF-637B4BBA82D8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads
       0x107fa2000 -        0x107ff8feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
       0x10803d000 -        0x1080fbffb +filter_graph ??? (???) <86919362-6EB7-5FAA-20BF-490FF5D14215> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_ graph
       0x108223000 -        0x108281ffd +AdobeXMP ??? (???) <29839F01-4A21-5B72-FF9A-E030D214F5E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x10828f000 -        0x10831bfe3 +AdobeXMPFiles ??? (???) <C4531436-CA4F-8A06-0481-CD1648C20C48> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
       0x108353000 -        0x1083f3fef +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7519) <92F5EB27-ED64-CA91-62F1-19D29CAAFC56> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
       0x108439000 -        0x1084ddffb +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7519) <783EA0CD-8A21-4568-A4CE-046AC65EBFFF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
       0x10853f000 -        0x10861dfef +AdobeAXEDOMCore ??? (???) <8D4592B8-5DA1-D957-B1BA-FB20116514DD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
       0x108695000 -        0x1089c6fe7 +AdobeCoolType ??? (???) <CB25F6CA-6CF3-94E8-918C-51A54936C0F4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
       0x108a62000 -        0x108dabfe7 +AdobeAGM ??? (???) <BEEAAC1B-CC8F-1A91-C0A2-03BE0343A313> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x108e7d000 -        0x108f91fff +AdobeACE ??? (???) <D04AF21C-E216-D514-B310-AD865E7C3AA1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x108fb6000 -        0x108fd7fff +AdobeBIBUtils ??? (???) <E04C88F8-0FBF-8E68-C0C2-B34CD69BD330> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
       0x108fe4000 -        0x1090b7ffb +AdobeJP2K ??? (???) <8571D9BA-44F9-92A3-0444-5FFAC2994B88> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x1090d7000 -        0x109118ff7 +AdobeARE ??? (???) <44AF62DE-EC7A-76F7-32A8-1106926B47BD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
       0x109122000 -        0x10977afef +AdobePDFL ??? (???) <45AA7483-10A6-2DAB-1FF8-62C9E615039E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
       0x1098c9000 -        0x109ddafff +AdobeMPS ??? (???) <10C4E979-45F3-A7C6-0438-262CE5F595B9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x109eb0000 -        0x109edbfef +AdobeAXE16SharedExpat ??? (???) <F5E56D3B-AE0E-245C-E706-DFA630D6771C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/ A/AdobeAXE16SharedExpat
       0x109eed000 -        0x10acb0fff +com.adobe.psl AdobePSL 12.0.0.7667 (12.0.0.7667) <F1C9409D-033E-58D0-B902-6422BC488AA5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
       0x10b020000 -        0x10b0cbfeb +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <5E91F6C8-5AFA-D4CF-D961-02E210F4074E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/Exporte rHost
       0x10b1df000 -        0x10b1fffeb +SegMatServices.dylib ??? (???) <2A93EF53-075B-328A-5830-CAED59925AF4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SegMatServices.dylib
       0x10b20c000 -        0x10b20cff7 +SAM.dylib ??? (???) <BCF43D01-C6A4-F35E-1518-8DFEFCF7094D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
       0x10b20f000 -        0x10b2f5fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
       0x10b34d000 -        0x10b625fe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
       0x10b79f000 -        0x10b7b5ff6 +com.adobe.AMEAppFoundation.framework ??? (1.0) <07B45FFC-9E85-1348-BAA4-944EC05DD0D7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AME AppFoundation
       0x10b7d6000 -        0x10b7f9ff1 +com.adobe.PostEncodeHost.framework ??? (1.0) <FDF0E743-0DB9-E7DF-BE05-22BFE397DB56> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostE ncodeHost
       0x10b827000 -        0x10b8e3ff7 +AMEWrapper ??? (???) <E735459D-FB6C-284C-E7AE-EA493E521221> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrappe r
       0x10b9a2000 -        0x10baa9fff +com.adobe.EncoderHost.framework ??? (1.0) <FBAAF460-E4D2-1374-F453-1A9C98E38207> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderH ost
       0x10bbae000 -        0x10bd7bfff +com.adobe.SettingsUI.framework ??? (1.0) <D87F7385-06E0-E6F1-7C29-5F20E2A6F9D0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsU I
       0x10bfd8000 -        0x10c036ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <6C9FA948-D19A-382D-1A3D-6AC921E4272A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Clien t
       0x10c0a4000 -        0x10c0cffff  com.apple.carbonframeworktemplate 1.0 (1.0) <377C4816-226E-3D48-AFDA-A40178588B15> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefou ndation
       0x10c109000 -        0x10c132fff +ameproperties ??? (???) <538DD95D-86A8-3D74-A231-06F1584A954B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/amepro perties
       0x10c175000 -        0x10c179ff2 +com.adobe.AppServices.framework ??? (1.0) <859AF026-319B-2120-C6EF-422964EFF52C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServi ces
       0x10c3b6000 -        0x10c3b8fef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x10c3e9000 -        0x10c3f1fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
       0x10c576000 -        0x10c57afff +com.adobe.AfterEffects.EasyEase ??? (???) <C9455FFC-A444-B363-D387-620C3314BDF0> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
       0x10c57d000 -        0x10c580ff7 +com.adobe.AfterEffects.Durer ??? (???) <65299D99-E891-5DCD-A5D0-3E9DE237FF7B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
       0x10c66a000 -        0x10c6daff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservi ces
       0x10d6c5000 -        0x10d6c6fff +com.adobe.AfterEffects.ExpressionControls ??? (???) <B47E6943-EA7A-B3DB-FD30-B15A639783C4> /Applications/Adobe After Effects CS5/Plug-ins/Effects/ExpressionControls.plugin/Contents/MacOS/Express ionControls
       0x10d755000 -        0x10d758ff7 +com.adobe.AfterEffects.Fill ??? (???) <6F84BAD1-1E3C-D890-AE3D-088BF69024E6> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Fill.plugin/Contents/MacOS/Fill
       0x10d75b000 -        0x10d75efff +com.adobe.AfterEffects.Fast_Blur ??? (???) <43BDE79C-6F9A-413D-BFE9-F027DD52ACD7> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Fast_Blur.plugin/Contents/MacOS/Fast_Blur
       0x10d761000 -        0x10d765fff +com.adobe.AfterEffects.Tint ??? (???) <BCFF3781-6E25-34DD-9817-9766F63A9AA7> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Tint.plugin/Contents/MacOS/Tint
       0x10d79e000 -        0x10d7a2ff7  libFontRegistryUI.dylib ??? (???) <763B8E8F-8602-2096-7CC8-CEE1F4248028> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/A TS.framework/Resources/libFontRegistryUI.dylib
       0x120139000 -        0x12013aff7 +com.adobe.AfterEffects.Paint ??? (???) <8C07B2F5-4B17-F5C1-C4AE-B0394226EEE2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
       0x12013d000 -        0x120147ff7 +com.adobe.AfterEffects.Glow ??? (???) <15E80079-1DAE-78A8-1846-1ED8A7B9631F> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Glow.plugin/Contents/MacOS/Glow
       0x120438000 -        0x120439fff  ATSHI.dylib ??? (???) <F6C4F446-7AC4-7A17-9302-C38A016322B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
       0x120442000 -        0x120443fff +com.adobe.AfterEffects.Set_Channels ??? (???) <9048AB74-23E8-00B4-3C08-922DE52B8A61> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Set_Channels.plugin/Contents/MacOS/Set_Channels
       0x12044b000 -        0x12044ffff +com.adobe.AfterEffects.Wave_Warp ??? (???) <0AE499A9-A19F-A377-16C8-6CCE44F3C63D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Wave_Warp.plugin/Contents/MacOS/Wave_Warp
       0x120452000 -        0x120453ff7 +com.adobe.AfterEffects.Mosaic ??? (???) <96E465FA-2AFC-F3E5-30D5-CF4D8324B6BC> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Mosaic.plugin/Contents/MacOS/Mosaic
       0x120491000 -        0x12049dfff +com.adobe.AfterEffects.MThread ??? (???) <D1511466-1D57-532C-C82E-69A13A2BD6D9> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
       0x1204a4000 -        0x1204bafe7 +com.adobe.AfterEffects.PS3Export ??? (???) <B5E53B3B-3F97-2735-3E20-A140EBC71960> /Applications/Adobe After Effects CS5/Plug-ins/Format/PS Layer Export.plugin/Contents/MacOS/PS3Export
       0x1204c6000 -        0x1204e8ff3 +com.adobe.AfterEffects.PS3Import ??? (???) <7FDD1A1F-E72E-597A-5366-2AF4FBC29EC4> /Applications/Adobe After Effects CS5/Plug-ins/Format/PS Layer Import.plugin/Contents/MacOS/PS3Import
       0x1204f9000 -        0x1204fdff7 +com.adobe.AfterEffects.ExpScale ??? (???) <060AABF0-117B-6C9B-6DEB-893396D31C33> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
       0x120501000 -        0x120692fef  GLEngine ??? (???) <AE898A2A-1C12-9FDB-455F-32601F030904> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
       0x1206c3000 -        0x120acdfe7  com.apple.ATIRadeonX2000GLDriver 1.6.26 (6.2.6) <0F5B5F88-3244-C922-60D0-97917502AE2F> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
       0x120b17000 -        0x120b3dfff  GLRendererFloat ??? (???) <8256EA93-A236-8B55-F214-65896DDB7A0E> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
       0x120bd5000 -        0x120bd9fff  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F99C2FBC-103D-DB2D-8D53-CFB8CEFA90F8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
       0x120bde000 -        0x120be4fff  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <933CA4C6-F428-0E2E-DCBE-FA0284914092> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x120be9000 -        0x120beefff +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0) <67DF0EF9-B526-49AB-FBF1-A1A4DFE25ED4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Conten ts/MacOS/ExporterCoreAudio
       0x12127e000 -        0x1212b0fe7 +com.cycoresystems.CCfx.ParticleWorld ??? (???) <C7D01C13-848A-8F66-2CD2-106B46674445> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/ParticleWorld.plugin/Contents/MacOS/Par ticleWorld
       0x1212bf000 -        0x1212c4fff +com.adobe.AfterEffects.Invert ??? (???) <56D7872B-9FC9-EE2E-F42C-65A374D86EE6> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Invert.plugin/Contents/MacOS/Invert
       0x1212c7000 -        0x1212d8fff +com.adobe.AfterEffects.Levels2 ??? (???) <DE0A361C-C122-0EEE-C449-4F14BEB44EE6> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Levels2.plugin/Contents/MacOS/Levels2
       0x1212dd000 -        0x1212eefff +com.adobe.AfterEffects.Hue_Sat ??? (???) <F5888FEF-2551-FA1F-6F17-82E4387DCFF3> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Hue_Sat.plugin/Contents/MacOS/Hue_Sat
       0x1212f3000 -        0x1212f9fff +com.adobe.AfterEffects.Ramp ??? (???) <F00CC9EC-615D-14A7-7EA9-45E5EF36CFBC> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Ramp.plugin/Contents/MacOS/Ramp
       0x12138a000 -        0x12138cfff +com.adobe.AfterEffects.Venetian_Blinds ??? (???) <C88C6E57-CBFB-5691-C2C8-56A212D5A353> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Venetian_Blinds.plugin/Contents/MacOS/Venetian_B linds
       0x1214a3000 -        0x1214b2fff +com.adobe.AfterEffects.FreePin ??? (???) <4D77B374-4B94-C30A-F0A8-758D82DC3114> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
       0x1214c2000 -        0x1214c7ff7 +com.adobe.AfterEffects.SmartBlur ??? (???) <78CF69D6-3576-A8E7-E393-774670779E9F> /Applications/Adobe After Effects CS5/Plug-ins/Effects/SmartBlur.plugin/Contents/MacOS/SmartBlur
       0x121bd6000 -        0x121c00ff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
       0x121c19000 -        0x121c40ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
       0x121e60000 -        0x121e6ffe7 +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0) <9DF434DF-0CB3-FF7B-B988-5EED3CA04BAB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/Audio Converter
       0x121e9d000 -        0x121ec3ff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <F53CB51E-9301-5881-113E-72B7543661D9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Co ntents/MacOS/ExporterQuickTimeHost
       0x122000000 -        0x1221eafef  com.apple.audio.codecs.Components 2.0.2 (2.0.2) <CC28CC1B-ACD4-151F-BC5B-E842AC7F075F> /System/Library/Components/AudioCodecs.component/Contents/MacOS/Audio Codecs
       0x12235c000 -        0x122362ff7 +com.adobe.AfterEffects.Sequence ??? (???) <F316A457-4D53-3F13-23C5-EB09AE43C971> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
       0x122367000 -        0x12236bfff +com.adobe.AfterEffects.TRKeys ??? (???) <44353A63-F5BA-B648-204D-D3F3581E2E58> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
       0x12236e000 -        0x122372ff7 +com.adobe.AfterEffects.RPFImport ??? (???) <415423D4-579B-BAE5-187C-9D436AFF6C6C> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
       0x124e83000 -        0x124eb9fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <98B3F385-B34E-AB84-0944-316FF3EDF68D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Conten ts/MacOS/ImporterQuickTime
       0x124eed000 -        0x124f04fff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <493EAF2C-1621-6D9E-0B64-F4BE9DDA694E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
       0x124f18000 -        0x124f2eff7 +com.red.ImporterRED 1.01 (1.0) <3282FA19-8A94-DEFD-8BF6-EEA9132DE447> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/Mac OS/ImporterRED
       0x12513a000 -        0x12514eff7 +com.adobe.AfterEffects.FractalNoise ??? (???) <26A7D78F-0291-F8B0-5167-7ECE77A85F79> /Applications/Adobe After Effects CS5/Plug-ins/Effects/FractalNoise.plugin/Contents/MacOS/FractalNoise
       0x125159000 -        0x12515bfff +com.adobe.AfterEffects.Threshold ??? (???) <10A0518D-D7F2-5F24-7565-09E50B134D3D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Threshold.plugin/Contents/MacOS/Threshold
       0x12515e000 -        0x125160fff +com.adobe.AfterEffects.SolidComposite ??? (???) <158D8BE5-76D8-F027-C17E-47C26B1BD161> /Applications/Adobe After Effects CS5/Plug-ins/Effects/SolidComposite.plugin/Contents/MacOS/SolidCompos ite
       0x1251e7000 -        0x125268fff +com.adobe.AfterEffects.AEGPDriver ??? (???) <2D2AF512-181B-E931-22CF-112B5AE2973C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
       0x1252a0000 -        0x125316fff +com.adobe.AfterEffects.Escher ??? (???) <E19FED0B-FD67-8E9D-4F68-067BB310E6F7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
       0x125323000 -        0x1253a1ff3 +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???) <FDA9EAF4-1FC7-F670-D61F-38E2B44B3D25> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/A EDynamicLinkServer
       0x12555e000 -        0x12557bfff +com.adobe.AfterEffects.AudioPal ??? (???) <B2EC3E6B-42AF-11BF-A0CD-FCA84B4A31E8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
       0x12558d000 -        0x1255bcffb +com.adobe.AfterEffects.BrushPal ??? (???) <AA683EE7-32C0-66C5-414C-E2E7B9CC021E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
       0x1255d4000 -        0x125614ff7 +com.adobe.AfterEffects.CharPal ??? (???) <25BBAB42-542A-C8A9-626D-3BC60D4727D6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
       0x125635000 -        0x125657fff +com.adobe.AfterEffects.InfoPal ??? (???) <E301706B-7062-C4CB-0F67-42675992BB5D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
       0x12566b000 -        0x125697ffb +com.adobe.AfterEffects.PaintPal ??? (???) <7CB211AF-3ED4-9DA0-A7C6-4F083F1EDE14> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
       0x1256af000 -        0x1256d0ff7 +com.adobe.AfterEffects.ParaPal ??? (???) <4ADBA656-E5B9-527A-4F24-5E77032E1BC3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
       0x1256e4000 -        0x12587bfff +com.adobe.AfterEffects.SnapCut ??? (???) <649B6CB7-E3AD-316F-9426-7CA65CF289BF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
       0x1258aa000 -        0x1258ccfff +com.adobe.AfterEffects.TimePal ??? (???) <5C49CB19-EC49-8DD4-B742-C817EBB9F2AF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
       0x1258e2000 -        0x125925fff +com.adobe.AfterEffects.ToolPal ??? (???) <44504F8D-AFD6-C9BC-F491-299B17D92B41> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
       0x125946000 -        0x125966ffb +com.adobe.AfterEffects.TrackerPal ??? (???) <C1A62239-4F43-C20E-900D-B6FB2ABFF195> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
       0x125978000 -        0x12674aff7 +com.ImagineerSystems.mochashapeconverter4ae 1 (1.0.0) <3C1F5D08-D515-9E24-35ED-CC76FCCA9675> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Imagineer/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
       0x126917000 -        0x12697dfff +com.adobe.AfterEffects.AE_OpenGL ??? (???) <115A01DF-0FF9-B686-3C03-67C7C8BF05CA> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
       0x126b91000 -        0x126b9dff7 +com.adobe.AfterEffects.LocalizePresets ??? (???) <6A10F872-ECD9-0BCC-6189-75010D491050> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/Localiz ePresets
       0x126ba6000 -        0x126bd6fff +com.adobe.AfterEffects.PNGIO ??? (???) <3E5936E0-0F00-4785-302F-388208B11628> /Applications/Adobe After Effects CS5/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
       0x126be1000 -        0x126becfff +com.adobe.AfterEffects.Analyzer ??? (???) <322481EA-82CD-67AE-FB8B-2687E2FBFE81> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
       0x126bf1000 -        0x126bf5ff8 +com.adobe.ape.shim adbeape version 3.1.64.7373 (3.1.64.7373) <B492C647-00DF-280F-47A0-EA78F1F9424A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
       0x126d00000 -        0x126d82ff3 +com.adobe.AfterEffects.FlashExporter ??? (???) <762A17C7-F9E6-DB9F-3DD4-0E94CDB459E6> /Applications/Adobe After Effects CS5/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
       0x126daf000 -        0x126f00feb +com.adobe.AfterEffects.OpenEXR ??? (???) <E570DDA8-8CD5-5C4B-A8EA-38B63E89231A> /Applications/Adobe After Effects CS5/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
       0x127057000 -        0x12710bfff +com.adobe.AfterEffects.PremiereProImport ??? (???) <61E5AEBA-D4BA-E2C7-6D3A-798C9822CB35> /Applications/Adobe After Effects CS5/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Conten ts/MacOS/PremiereProImport
       0x127138000 -        0x1271cafff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <C646F212-DD5F-242B-F7E9-5A767F980FB1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCor eUI
       0x127254000 -        0x1272b0fff +com.adobe.AfterEffects.TIFFIO ??? (???) <BB070DC9-3710-E676-703C-9BBFA563DE12> /Applications/Adobe After Effects CS5/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
       0x1272c0000 -        0x127384feb +com.adobe.AfterEffects.Vic ??? (???) <82DEAA73-D565-A6B0-E296-10BCF914B257> /Applications/Adobe After Effects CS5/Plug-ins/Format/Vector Output.plugin/Contents/MacOS/Vic
       0x1273db000 -        0x1273f4ff3 +com.adobe.AfterEffects.Align ??? (???) <8925249E-BDFE-5773-5C8E-7678F4CF792E> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
       0x127403000 -        0x127413fff +com.adobe.AfterEffects.MayaImport ??? (???) <3C2EE5DE-C841-A35D-DF51-EB125A8FC38D> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
       0x127416000 -        0x12742dff7 +com.adobe.AfterEffects.MetaPal ??? (???) <3D1218BE-E450-ECDC-E1DA-8F81E6E2DB3A> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
       0x12743e000 -        0x127468fff +com.adobe.AfterEffects.Moka ??? (???) <D9479AB2-EEF1-036A-7489-3F4E66893F81> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
       0x127479000 -        0x12748dffb +com.adobe.AfterEffects.MotionSketch ??? (???) <5DB4467F-168A-9825-7232-9AA597F1D8E7> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
       0x12749b000 -        0x1278effff +com.adobe.AfterEffects.Scripting ??? (???) <30DCC64F-3810-2CEB-CC73-C5C9A46A457F> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
       0x127a7b000 -        0x127a9bffb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
       0x127b23000 -        0x127b28ff7 +com.adobe.AfterEffects.Drop_Shadow ??? (???) <E88AF7BE-0C87-B609-188B-2978B3E98C1D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Drop_Shadow.plugin/Contents/MacOS/Drop_Shadow
       0x127e63000 -        0x128ccbff3 +com.adobe.adobeswfl ??? (2.0.0.10053) <ADE7E8AA-80B6-7BAC-8205-13D7A0E89DF8> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundl e/Contents/MacOS/AdobeSWFL
       0x12a013000 -        0x12a051ff7  com.apple.DP.ScreenInputDevice 13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevi ce
       0x12a452000 -        0x12a47afff  com.apple.mio.DAL.VDC_4 134.0 (1160) <B7B57FA5-1C74-149A-43D1-51DE9479B521> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/VDC.plugin/Contents/MacOS/VDC
       0x12a788000 -        0x12a79ffe7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <5C25B45F-7A9E-3259-0532-E13B34B5398A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x12a7a3000 -        0x12a7b2fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <50541300-118F-BE28-86DB-0F42738A9338> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
       0x12a7b6000 -        0x12a7c8fff  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <CC30A563-5E4C-7ACE-3B73-90E8F582171A> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
       0x12a7cc000 -        0x12a7edfef  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <1CC25A05-9E4C-ACBE-546E-34063A4CEB09> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x12ac78000 -        0x12ac8cffb +com.adobe.AfterEffects.Smoother ??? (???) <AB6F9378-E6E5-4B64-FB32-B18F9A8F0E2E> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
       0x12aca8000 -        0x12acaffff +com.adobe.AfterEffects.Tile ??? (???) <9868DBF5-E5C8-88F0-D7B1-FA416485206D> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Tile.plugin/Contents/MacOS/Tile
       0x12ae31000 -        0x12ae47ff3 +com.adobe.AfterEffects.Wiggler ??? (???) <B4CE3DCA-F16A-5ED9-B267-7C31A31B247D> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
       0x12aefb000 -        0x12aefdff7 +com.adobe.AfterEffects.Block_Dissolve ??? (???) <CE684AF7-EFB3-7C91-2365-46C83A3DA0E5> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Block_Dissolve.plugin/Contents/MacOS/Block_Disso lve
       0x12b365000 -        0x12b366fff  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <0739FD38-CF46-0ECC-517C-E187C5A3B8D6> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x12c3e6000 -        0x12c3ebfff +com.cycoresystems.CCfx.RadialFastBlur 1.0 (???) <99FEB5F5-6632-30F8-BF7A-0630727642E8> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/RadialFastBlur.plugin/Contents/MacOS/Ra dialFastBlur
       0x12c3f8000 -        0x12c3fcfff +com.adobe.AfterEffects.Echo ??? (???) <280225F1-D20C-8AE2-38C0-E42CCF212279> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Echo.plugin/Contents/MacOS/Echo
       0x12c6e7000 -        0x12c7e4fff +com.adobe.AfterEffects.RefineMatte ??? (???) <3F9C8C99-5344-DE94-76E1-A8948DAAB8BC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMat te
       0x12cc0d000 -        0x12cc4afeb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A /UpdaterNotifications
       0x12cc9c000 -        0x12ccbbfe3 +com.adobe.AfterEffects.Jpg ??? (???) <00BF1928-3BCE-599C-22AF-490689F3B369> /Applications/Adobe After Effects CS5/Plug-ins/Format/JPEG.plugin/Contents/MacOS/Jpg
       0x12da00000 -        0x12da1dff3 +com.adobe.AfterEffects.TurbulentDisplace ??? (???) <21E77AAE-CCBE-11E0-CF16-850D9ECC56D9> /Applications/Adobe After Effects CS5/Plug-ins/Effects/TurbulentDisplace.plugin/Contents/MacOS/Turbulen tDisplace
       0x12da4a000 -        0x12da68fff +com.adobe.MediaCore.ImporterMPEG 1.0 (1.0) <1C6582C0-8E67-11FB-9A1F-18B987DF7949> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/Ma cOS/ImporterMPEG
       0x12daf6000 -        0x12dafcfff +com.cycoresystems.CCfx.RadialBlur 1.0 (???) <A18973A2-0422-7386-392C-C1CEF16F6503> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/RadialBlur.plugin/Contents/MacOS/Radial Blur
       0x12e100000 -        0x12e161fef +com.mainconcept.mc_mfimport 8.5 (8.5.0.14572) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_mfimport.framework/Versions/8.5/mc_mfi mport
       0x12e61a000 -        0x12e6eafff +com.mainconcept.mc_demux_mp4 8.5 (8.5.0.14572) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_demux_mp4.framework/mc_demux_mp4
       0x12f6da000 -        0x12f6e0ff7 +com.cycoresystems.CCfx.Repetile 1.0 (???) <E0DA5C96-BBA4-DA99-42C6-6A53CB333CA4> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/Repetile.plugin/Contents/MacOS/Repetile
       0x12f6e4000 -        0x12f6e9ff7 +com.cycoresystems.CCfx.LightSweep 1.0 (???) <AA190B8B-96BD-DA5C-43D3-54A2425A487E> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/LightSweep.plugin/Contents/MacOS/LightS weep
       0x12f6ed000 -        0x12f6f8fff +com.cycoresystems.CCfx.Glass 1.0 (???) <6A5DA94E-7FB3-D3E3-E38D-52063D2622C0> /Applications/Adobe After Effects CS5/Plug-ins/Effects/CycoreFX/Glass.plugin/Contents/MacOS/Glass
       0x130462000 -        0x13046bfff +FastCore ??? (???) <4A676BFE-2C56-9651-EFF7-E804EC45C87F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/FastCore.plugin/Conte nts/MacOS/FastCore
       0x131000000 -        0x13102eff3 +MMXCore ??? (???) <0E398A83-FEBA-9272-4A07-04055F56EF16> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MMXCore.plugin/Conten ts/MacOS/MMXCore
       0x1310b6000 -        0x131121ff0 +MultiProcessor Support ??? (???) <101FF20A-2063-75D7-76FC-56974AFBAABE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
    0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
    0x7fff80003000 -     0x7fff80019fe7  com.apple.MultitouchSupport.framework 207.10 (207.10) <1828C264-A54A-7FDD-FE1B-49DDE3F50779> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x7fff8001a000 -     0x7fff80061ff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff80062000 -     0x7fff80219fef  com.apple.ImageIO.framework 3.0.4 (3.0.4) <2CB9997A-A28D-80BC-5921-E7D50BBCACA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff8021a000 -     0x7fff80230fef  libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
    0x7fff8023e000 -     0x7fff804c4fff  com.apple.security 6.1.1 (37594) <1B4E1ABD-1BB3-DA49-F574-0EEB23E73C6A> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff80542000 -     0x7fff8057ffff  com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff80580000 -     0x7fff80586ff7  IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff80587000 -     0x7fff8080aff7  com.apple.Foundation 6.6.4 (751.42) <9A99D378-E97A-8C0F-3857-D0FAA30FCDD5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff8080b000 -     0x7fff8081afff  com.apple.opengl 1.6.12 (1.6.12) <DE3F0528-7759-CDFD-A2CF-C51D3C9C8B39> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8081b000 -     0x7fff80820ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x7fff80842000 -     0x7fff80842ff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x7fff80843000 -     0x7fff8084cff7  com.apple.DisplayServicesFW 2.3.0 (283) <3D05929C-AB17-B8A4-DC81-87C27C59E664> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
    0x7fff808b4000 -     0x7fff8096afff  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F206BE6D-8777-AE6C-B367-7BEA76C14241> /usr/lib/libobjc.A.dylib
    0x7fff8096b000 -     0x7fff80991fe7  libJPEG.dylib ??? (???) <6690F15D-E970-2678-430E-590A94F5C8E9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff80992000 -     0x7fff809a6fff  libGL.dylib ??? (???) <1EB1BD0F-C17F-55DF-B8B4-8E9CF99359D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x7fff809a7000 -     0x7fff809aaff7  com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x7fff80a56000 -     0x7fff80a56ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff80a57000 -     0x7fff80b95fff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff80b96000 -     0x7fff80b9dfff  com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x7fff80b9e000 -     0x7fff80bd9fff  com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x7fff80ca5000 -     0x7fff80cf1fff  libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
    0x7fff80cf2000 -     0x7fff80d41fef  libTIFF.dylib ??? (???) <AE9DC484-1382-F7AD-FE25-C28082FCB5D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff810d3000 -     0x7fff8113bfff  com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
    0x7fff8113c000 -     0x7fff81167ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
    0x7fff811a7000 -     0x7fff81264ff7  com.apple.CoreServices.OSServices 357 (357) <718F0719-DC9F-E392-7C64-9D7DFE3D02E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x7fff81265000 -     0x7fff81297fff  libTrueTypeScaler.dylib ??? (???) <B9ECE1BD-A716-9F65-6466-4444D641F584> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff81298000 -     0x7fff812d1fef  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <561D0DCB-47AD-A12C-9066-70E4CBAD331C> /usr/lib/libcups.2.dylib
    0x7fff812d2000 -     0x7fff812d3ff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <14F14B5E-9287-BC36-0C3F-6592E6696CD4> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff8131f000 -     0x7fff8132aff7  com.apple.HelpData 2.0.4 (34) <B44D2E2A-BC1E-CD63-F8A1-C9465491693A> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
    0x7fff8132b000 -     0x7fff81350ff7  com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff81461000 -     0x7fff8153bff7  com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x7fff81544000 -     0x7fff81555fff  com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
    0x7fff81755000 -     0x7fff81755ff7  com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff81756000 -     0x7fff81a8afff  com.apple.CoreServices.CarbonCore 861.23 (861.23) <08F360FA-1771-4F0B-F356-BEF68BB9D421> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff81a8b000 -     0x7fff81b40fe7  com.apple.ColorSync 4.6.3 (4.6.3) <AA93AD96-6974-9104-BF55-AF7A813C8A1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff81b41000 -     0x7fff81c5afef  libGLProgrammability.dylib ??? (???) <4F2DC233-7DD2-1204-CAA5-3E6524F0AB75> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x7fff81c5b000 -     0x7fff81c95fff  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <C7153747-50E3-32DA-426F-CC4C505D1D6C> /usr/lib/libssl.0.9.8.dylib
    0x7fff81c96000 -     0x7fff81d57fe7  libFontParser.dylib ??? (???) <8B12D37E-3A95-5A73-509C-3AA991E0C546> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff81d58000 -     0x7fff81dbafe7  com.apple.datadetectorscore 2.0 (80.7) <04093091-088D-79D9-0B86-E551E5833E7F> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
    0x7fff81eb4000 -     0x7fff81edcfff  com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff81edd000 -     0x7fff823e1fe7  com.apple.VideoToolbox 0.484.20 (484.20) <8B6B82D2-350B-E9D3-5433-51453CDA65B4> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
    0x7fff823e2000 -     0x7fff8242cff7  com.apple.Metadata 10.6.3 (507.15) <5170FCE0-ED6C-2E3E-AB28-1DDE3F628FC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x7fff8246f000 -     0x7fff8265efe7  com.apple.JavaScriptCore 6533.19 (6533.19.1) <233B3E34-CDC4-668A-529A-7E61D510D991> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x7fff8265f000 -     0x7fff82680fff  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
    0x7fff82681000 -     0x7fff8269afff  com.apple.CFOpenDirectory 10.6 (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff826db000 -     0x7fff82ab5fff  com.apple.RawCamera.bundle 3.4.1 (546) <F7865FD2-4869-AB19-10AA-EFF1B3BC4178> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
    0x7fff82aec000 -     0x7fff82bd1fef  com.apple.DesktopServices 1.5.9 (1.5.9) <27890B2C-0CD2-7C27-9D0C-D5952C5E8438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x7fff82c08000 -     0x7fff82c51fef  libGLU.dylib ??? (???) <CCE779A9-2467-A5AA-A558-691E43A1105F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x7fff83056000 -     0x7fff8309fff7  com.apple.securityinterface 4.0.1 (40418) <E2DC796D-84EC-48F5-34A9-DF614573BE74> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
    0x7fff830a0000 -     0x7fff8343dfe7  com.apple.QuartzCore 1.6.3 (227.34) <215222AF-B30A-7CE5-C46C-1A766C1D1D2E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff835d3000 -     0x7fff8369efe7  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <3C223A94-EF14-28C5-844B-C25DFC87FB42> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/C olorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x7fff8369f000 -     0x7fff836fffe7  com.apple.framework.IOKit 2.0 (???) <D107CB8A-5182-3AC4-35D0-07068A695C05> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff83751000 -     0x7fff837cffff  com.apple.CoreText 3.5.0 (???) <4D5C7932-293B-17FF-7309-B580BB1953EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x7fff837d0000 -     0x7fff83818ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff83820000 -     0x7fff83867fff  com.apple.QuickLookFramework 2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff83884000 -     0x7fff83939fe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x7fff8393a000 -     0x7fff83a60fff  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <B51023BB-A5C9-3C65-268B-6B86B901BB2C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x7fff83b32000 -     0x7fff83b34fff  libRadiance.dylib ??? (???) <76438F90-DD4B-9941-9367-F2DFDF927876> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff83b35000 -     0x7fff83bd5fff  com.apple.LaunchServices 362.2 (362.2) <A8EDC37C-1D40-5ED0-49BE-90EF110A6B3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff83c4e000 -     0x7fff83c5cff7  libkxld.dylib ??? (???) <4016E9E6-0645-5384-A697-2775B5228113> /usr/lib/system/libkxld.dylib
    0x7fff83c69000 -     0x7fff83de0fe7  com.apple.CoreFoundation 6.6.4 (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x7fff83de1000 -     0x7fff83de2fff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
    0x7fff83de3000 -     0x7fff83df9fff  com.apple.ImageCapture 6.0.1 (6.0.1) <09ABF2E9-D110-71A9-4A6F-8A61B683E936> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x7fff83dfa000 -     0x7fff83e36fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A> /usr/lib/libcurl.4.dylib
    0x7fff83e37000 -     0x7fff840a1fef  com.apple.QuartzComposer 4.2 ({156.28}) <7586E7BD-D3BD-0EAC-5AC9-0BFA3679017C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
    0x7fff84d16000 -     0x7fff84d18fff  com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x7fff84d19000 -     0x7fff84d85ff7  com.apple.CorePDF 1.3 (1.3) <6770FFB0-DEA0-61E0-3520-4B95CCF5D1CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
    0x7fff84d86000 -     0x7fff84d8aff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
    0x7fff84d8b000 -     0x7fff84fc6fef  com.apple.imageKit 2.0.3 (1.0) <5D18C246-303A-6580-9DC9-79BE79467C95> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
    0x7fff84fc7000 -     0x7fff85185fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <781E7B63-2AD0-E9BA-927C-4521DB616D02> /usr/lib/libicucore.A.dylib
    0x7fff852a7000 -     0x7fff852acfff  libGFXShared.dylib ??? (???) <991F8197-FD06-2AF1-F99B-E448ED4FB2AC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x7fff852ad000 -     0x7fff855abfe7  com.apple.HIToolbox 1.6.4 (???) <263AD497-F4CC-9610-E7D3-B95CF6F02030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x7fff855ac000 -     0x7fff855f1fff  com.apple.CoreMediaIOServices 134.0 (1160) <033C41A6-EB9B-6B3B-781A-AF001A945C7A> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
    0x7fff855f2000 -     0x7fff85615fff  com.apple.opencl 12.3 (12.3) <D30A45FC-4520-45AF-3CA5-092313DB5D54> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff85616000 -     0x7fff85636ff7  com.apple.DirectoryService.Framework 3.6 (621.9) <FF6567B5-56BD-F3EC-E59D-1EC583C3CF73> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
    0x7fff85637000 -     0x7fff85758fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <48AEAFE1-21F4-B3C8-4199-35AD5E8D0613> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff857a4000 -     0x7fff857a7fff  com.apple.help 1.3.1 (41) <E311A81E-9870-A430-1E16-AFF6C92CE6E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x7fff857c0000 -     0x7fff858e8ff7  com.apple.MediaToolbox 0.484.20 (484.20) <628A7245-7ADE-AD47-3368-CF8EDCA6CC1C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
    0x7fff858f5000 -     0x7fff85936ff7  com.apple.CoreMedia 0.484.20 (484.20) <42F3B74A-F886-33A0-40EE-8399B12BD32A> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
    0x7fff859b5000 -     0x7fff860b206f  com.apple.CoreGraphics 1.545.0 (???) <356D59D6-1DD1-8BFF-F9B3-1CE51D2F1EC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff860b3000 -     0x7fff860ceff7  com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x7fff860cf000 -     0x7fff860d5ff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x7fff860d6000 -     0x7fff861e0ff7  com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x7fff861e1000 -     0x7fff869ebfe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff869ec000 -     0x7fff86a3bfef  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BD71B20B-C530-6D10-47A4-9838CF292911> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
    0x7fff86a3c000 -     0x7fff86a3cff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff86a3d000 -     0x7fff86a4eff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
    0x7fff86a4f000 -     0x7fff86ae9fff  com.apple.ApplicationServices.ATS 4.4 (???) <395849EE-244A-7323-6CBA-E71E3B722984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x7fff86b0a000 -     0x7fff86b96fef  SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x7fff86ba3000 -     0x7fff86ba3ff7  com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x7fff86ba4000 -     0x7fff86bb6fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
    0x7fff86bb7000 -     0x7fff86bbcfff  libGIF.dylib ??? (???) <9A2723D8-61F9-6D65-D254-4F9273CDA54A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff86bbd000 -     0x7fff86bedfef  com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
    0x7fff86c3e000 -     0x7fff86c6ffff  libGLImage.dylib ??? (???) <1A8E58CF-FA2F-14F7-A097-D34EEA8A7D03> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x7fff86da4000 -     0x7fff86da5fff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
    0x7fff86da6000 -     0x7fff86e35fff  com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
    0x7fff86e36000 -     0x7fff86eb5fe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <1DD64A62-0DE4-223F-F781-B272FECF80F0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff86eb6000 -     0x7fff86f08ff7  com.apple.HIServices 1.8.2 (???) <7C91D07D-FA20-0882-632F-0CAE4FAC2B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x7fff8707b000 -     0x7fff870beff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <7E30B5F6-99FD-C716-8670-5DD4B4BAED72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff870bf000 -     0x7fff87144ff7  com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff87145000 -     0x7fff8717eff7  com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
    0x7fff8717f000 -     0x7fff871c3fe7  com.apple.ImageCaptureCore 1.0.3 (1.0.3) <913FFA89-0AC8-0A8D-CC2A-364CB0F303BA> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
    0x7fff871c4000 -     0x7fff87296fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <B3E2BE12-D7AA-5940-632A-1E5E7BF8E6E3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff87297000 -     0x7fff87327fff  com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x7fff87328000 -     0x7fff8732eff7  com.apple.CommerceCore 1.0 (6) <E8A1144C-5666-9840-4729-256FE69CDBDB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x7fff8732f000 -     0x7fff8732fff7  com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff87330000 -     0x7fff87344ff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff875d7000 -     0x7fff87fcdfff  com.apple.AppKit 6.6.7 (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff87fce000 -     0x7fff8800ffff  com.apple.SystemConfiguration 1.10.5 (1.10.2) <FB39F09C-57BB-D8CC-348D-93E00C602F7D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x7fff88010000 -     0x7fff88014ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <63F77AC8-84CB-0C2F-8D2B-190EE5CCDB45> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
    0x7fff88015000 -     0x7fff8802aff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff88041000 -     0x7fff8804cff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x7fff8804d000 -     0x7fff8804dff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff88072000 -     0x7fff880afff7  libFontRegistry.dylib ??? (???) <8C69F685-3507-1B8F-51AD-6183D5E88979> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff880b0000 -     0x7fff88169fff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
    0x7fff8816a000 -     0x7fff88179fff  com.apple.NetFS 3.2.1 (3.2.1) <FF21DB1E-F425-1005-FB70-BC19CAF4006E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff8817a000 -     0x7fff8833bfff  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
    0x7fff8837c000 -     0x7fff883bffef  libtidy.A.dylib ??? (???) <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
    0x7fff883c2000 -     0x7fff88531fe7  com.apple.QTKit 7.6.6 (1756) <250AB242-816D-9F5D-94FB-18BF2AE9AAE7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff8854d000 -     0x7fff885a2ff7  com.apple.framework.familycontrols 2.0.2 (2020) <A3CFF697-B9DB-A7E5-3B39-9DA9B34F0595> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x7fff885a3000 -     0x7fff885b0fe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <397B9057-5CDF-3B19-4E61-9DFD49369375> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x7fff885ba000 -     0x7fff88637fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
    0x7fff88638000 -     0x7fff8874ffef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <EE067D7E-15B3-F043-6FBD-10BA31FE76C7> /usr/lib/libxml2.2.dylib
    0x7fff8875f000 -     0x7fff8880efff  edu.mit.Kerberos 6.5.10 (6.5.10) <F3F76EDF-5660-78F0-FE6E-33B6174F55A4> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff8880f000 -     0x7fff88879fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff8887a000 -     0x7fff888ebff7  com.apple.AppleVAFramework 4.10.12 (4.10.12) <1B68BE43-4C54-87F5-0723-0B0A14CD21E8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
    0x7fff888ec000 -     0x7fff888edff7  com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x7fff888ee000 -     0x7fff8890bff7  libPng.dylib ??? (???) <14043CBC-329F-4009-299E-DEE411E16134> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff88964000 -     0x7fff88964ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x7fff8898a000 -     0x7fff88b6dfff  libType1Scaler.dylib ??? (???) <3A1AFBA4-958E-DD07-297E-DF1FB2C96D7C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
    0x7fff88c3d000 -     0x7fff88c6cff7  com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
    0x7fff88c6d000 -     0x7fff88ceffff  com.apple.QuickLookUIFramework 2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
    0x7fff88cf0000 -     0x7fff88d31fef  com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x7fff88d32000 -     0x7fff88d35ff7  libCoreVMClient.dylib ??? (???) <609598E6-195D-E5D4-3B92-AE8D9768829C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x7fff88d36000 -     0x7fff8917afef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
RAM: 4096MB
Machine: i386
Model: iMac10,1
CPU * Core count: 2
CPU Frequency: 3060MHz
Bus Frequency: 1064MHz
Open GL Renderer: ATI Radeon HD 4850 OpenGL Engine
Open GL Version: 2.1 ATI-1.6.26
Open GL Vendor: ATI Technologies Inc.
Open GL Extensions: L_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_vertex_blend, GL_ARB_window_pos, GL_ARB_shader_objects, GL_ARB_vertex_shader, GL_ARB_shading_language_100, GL_EXT_multi_draw_arrays, GL_EXT_clip_volume_hint, GL_EXT_rescale_normal, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_gpu_program_parameters, GL_EXT_geometry_shader4, GL_EXT_transform_feedback, GL_APPLE_client_storage, GL_APPLE_specular_vector, GL_APPLE_transform_hint, GL_APPLE_packed_pixels, GL_APPLE_fence, GL_APPLE_vertex_array_object, GL_APPLE_vertex_program_evaluators, GL_APPLE_element_array, GL_APPLE_flush_render, GL_APPLE_aux_depth_stencil, GL_NV_texgen_reflection, GL_NV_light_max_exponent, GL_IBM_rasterpos_clip, GL_SGIS_generate_mipmap, GL_ARB_imaging, GL_ARB_point_parameters, GL_ARB_texture_env_crossbar, GL_ARB_texture_border_clamp, GL_ARB_multitexture, GL_ARB_texture_env_add, GL_ARB_texture_cube_map, GL_ARB_texture_env_dot3, GL_ARB_multisample, GL_ARB_texture_env_combine, GL_ARB_texture_compression, GL_ARB_texture_mirrored_repeat, GL_ARB_shadow, GL_ARB_depth_texture, GL_ARB_shadow_ambient, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_occlusion_query, GL_ARB_point_sprite, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object, GL_ARB_pixel_buffer_object, GL_ARB_draw_buffers, GL_ARB_shader_texture_lod, GL_ARB_color_buffer_float, GL_ARB_half_float_vertex, GL_ARB_texture_rg, GL_ARB_texture_compression_rgtc, GL_ARB_framebuffer_object, GL_EXT_compiled_vertex_array, GL_EXT_draw_buffers2, GL_EXT_framebuffer_object, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample, GL_EXT_texture_rectangle, GL_ARB_texture_rectangle, GL_EXT_texture_env_add, GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_lod_bias, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_stencil_wrap, GL_EXT_texture_filter_anisotropic, GL_EXT_separate_specular_color, GL_EXT_secondary_color, GL_EXT_blend_func_separate, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_dxt1, GL_EXT_texture_sRGB, GL_EXT_blend_equation_separate, GL_EXT_texture_mirror_clamp, GL_EXT_packed_depth_stencil, GL_EXT_bindable_uniform, GL_EXT_texture_integer, GL_EXT_gpu_shader4, GL_EXT_framebuffer_sRGB, GL_EXT_provoking_vertex, GL_APPLE_flush_buffer_range, GL_APPLE_ycbcr_422, GL_APPLE_rgb_422, GL_APPLE_vertex_array_range, GL_APPLE_texture_range, GL_APPLE_float_pixels, GL_ATI_texture_float, GL_ARB_texture_float, GL_ARB_half_float_pixel, GL_APPLE_pixel_buffer, GL_APPLE_object_purgeable, GL_NV_blend_square, GL_NV_fog_distance, GL_NV_conditional_render, GL_ATI_texture_mirror_once, GL_ATI_blend_equation_separate, GL_ATI_blend_weighted_minmax, GL_ATI_texture_env_combine3, GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGI_color_matrix, GL_EXT_texture_array, GL_EXT_vertex_array_bgra, GL_ARB_instanced_arrays, GL_ARB_depth_buffer_float, GL_EXT_packed_float, GL_EXT_texture_shared_exponent
Reproduction Steps: Please provide a detailed description, including all of the steps required to reproduce the crash.
User GUID: 9017ED05-771E-45BA-9A73-ACE05EEA114E
Crash GUID: 673145D4-2E8D-4AA7-B4A7-3FEC3F0B7067
    Mar 3, 2011 7:18 PM   in reply to jeffdyson
    Update to 10.0.1. Oh yeah, and buy mor RAM, or disable multiprocessing in the prefs.
    Mar 4, 2011 2:13 AM   in reply to jeffdyson
    As the Vulcans on "Star Trek" say: Simple logic works best. If it always crashes at the same point, it stands to reason that it is always the same cause. Very likely  one of your source files is damaged at that point. Otthr than trhat you could run out of disk space on the target file or temporary files as wel las simply filling up your RAM. Since you didn't provide info on what's involved in your project like comp size and footage used it is however pure speculation at this point. Providing more details would help...
    Mylenium
    Feb 15, 2012 6:05 AM   in reply to jeffdyson
    I have the same problem ....   and have 16 gigs ram ....   I rendered a hi def 1 hour show last week no problem
    This one is 53 minutes and 7 crashes.....   I cut the show in half now 25 miuntes and it crashed again .....
    I have over 500 gig free on the target drive ....... still searching! for answer
    Feb 15, 2012 8:16 AM   in reply to mr dawg
    mr dawg wrote:
    I have the same problem ....    still searching! for answer
    Please allow me to quote Mylenium's post from this very thread:
    "Since you didn't provide info on what's involved in your project like comp size and footage used it is however pure speculation at this point. Providing more details would help..."
    Details like the ones you will find described in this FAQ Entry.
    No good info... no good help.  It's the old computer programmer's mantra: Garbage In, Garbage Out.
