How to compare 2 Class Objects
Feb 16, 2012 12:05 AM
Hallo. I have 2 Objects of Type i_DomandaRisposte. This is the Object class:
package MyProg.vo
  import flash.utils.ByteArray;
  import mx.collections.ArrayCollection;
[Bindable]
[RemoteClass(alias="MyProg.i_DomandaRisposte")]
public class i_DomandaRisposte
  public function i_DomandaRisposte(){}
public var tip:String;
  public var tipologia_risposta:Number;
  public var numero_visualizzazioni:int;
  public var numero_selezioni:int;
  public var ordine:Number;
  public var img:Array;
  public var traduzioni:Array;
If i have 2 instances of this object, which is the best way to compare this 2 instances and to understand if, in each property, there is the same content??.. As you see there are strings, Int and Array. I need to check that the int values, string values and all Array contents are the same.. How can i do that??.. I hope you understand my request.
Thx
Max
