How to reveal folders that exist in computer>(OS:C)>users in Bridge CS5 Folders tab
Feb 10, 2012 4:46 PM
Tags: #bridge_cs5 #missing_folders
I have pictures and documents folders in C that won't show up in Bridge--or show as empty/ moved in the Bridge Folder tab. They do open in Explorer Libraries and in C>Users . How can I reconfigure/ fix the file tree in Bridge so I can view these folders/files in Bridge?
    Feb 10, 2012 6:46 PM   in reply to veranica
    I would select the folders and then click on Tools/cache/purge cache for xxxx folder.
    See if it works when cache is rebuilt.  Don't move off of the folder until the spinning wheel in lower corner is finished.
    Feb 10, 2012 8:09 PM   in reply to veranica
    "I saw after posting that you responded to a sim Q in 2009 for Pictures files. Should I follow your advice there about removing Bridge in the process tab of Task Manager before doing the above? I checked and it does look like Bridge is currently running in the background"
    You only have to do this if you need to download and install an update.
    You might have to select individual sub-folders rather than the folder that lists all the folders.  You can purge cache from edit/preferences/cache, but if you have selected "export cache to folders when possible" this option will not delete the folder cache.
    Feb 15, 2012 6:55 PM   in reply to veranica
    You probably have Bridge set to autoload on Startup.  If you any changes you make will not be reflected next time you start Bridge unless you shut program by clicking on File/Exit, do not just close window the the red X.
    To disable autoload go to edit/preferences/advananced.
    Feb 16, 2012 7:18 AM   in reply to veranica
    Great, glad you are back to normal.
    One error in you satement above.
    If you have "Start Bridge at Login" checked, you need to exit using File>Exit for any changes you made to be remembered next time you open program.  Otherwise if will open at  settings you had the last time it was closed with File>Exit..
    If you have "Start Bridge at Login" UNchecked it makes to difference how you close Bridge as Bridge will open how you left it.
