I'm using Flash builder 4.6 (and have used prior versions of flash builder as well) with a flex/actionscript project on a Windows 7, 64 bit box. Flash Builder itself (not the launched application) is horribly slow and unresponsive. I do not have the auto build turned on or design mode on
Here are some of the problems I regularly have:
- Opening the window, if it has been minimized, and clicking anywhere on it causes the window to be greyed out and have the "(not responding)" message added to its title bar. It starts working after 15 seconds.
- Using the arrow keys to move up and down in a .as or .mxml file is jerky. I.e., some keystrokes move at the rate I hit them, but others pause, wait a few seconds, and then move. This also occurs with mouse actions.
- Using code navigation like F3 or <CTRL>-<SHIFT>-G causes Flash Builder to pause while it thinks. In the case of <CTRL>-<SHIFT>-G, it pauses so long that one thinks there are no references (because the search starts with 0 results).
- Building code within flash builder takes minutes. Even the modification of a single file takes forever.
In general, I've found working with Flash Builder one of the worst development experiences (I've worked with Eclipse for the last 6 years, VIM, & Visual Studio too) I've had.
These are the installed components:
Adobe Data Modeling Core Components 4.5.304901.v20110217 com.adobe.model.feature.core.feature.group Adobe Systems Incorporated
Eclipse IDE for Java Developers 1.4.0.20110615-0550 epp.package.java null
org.eclipse.equinox.p2.operations NLS Support 3.7.0.v20110716043402 org.eclipse.equinox.p2.operations.nl1_3.7.0.v20110716043402 Adobe Systems Incorporated
org.eclipse.wst.internet.cache NLS Support 3.7.0.v20110716043402 org.eclipse.wst.internet.cache.nl1_3.7.0.v20110716043402 Adobe Systems Incorporated
RDS Core and Database Components 4.5.304901.v20110217 com.adobe.rds.feature.feature.group Adobe Systems Incorporated
No solution, but I get similar results. I use a new 27" imac with bootcamp Win7 x64, and the response time is appalling, although not as bad as you are having. When I boot into the OSX part and use FB4.6 there, it is absolutely fine. I am getting a second or two of non-response when adding variables and generally slow otherwise when using Windoze only.
I'm pretty critical, but when FB is working well, like in OSX, it is quite good for me.
Joe
I have similar problems with some .as files. The compiler/formatter/assistant seems to hang, consuming 100% cpu (or 25% on my quad-core) and blocking the UI. Each keystroke / click takes 10-15 seconds. The cursor flashes very slowly. Sometimes the window goes white with "not responding" in the title bar.
I have not yet been able to pinpoint the problem precisely or reproduce with a simple code sample, but it seems to happen when
a) your code contains inline (anonymous) functions and
b) you have typed an opening bracket but no closing bracket yet - ( ), { }, [ ].
The situation continues until the brackets are balanced.
Can either of you confirm that this is so in your case?
