Setting new slide default to High 24 bit quality ?
Feb 17, 2012 7:01 AM
Captivate v5.5
I am adding some slides to an existing project that was originally created in v4.
I have now opened it in v5.5 and I am recording some new material to the project.
Currently I am adding slide by slide with images from our website - but each slide is appearing in the project with Quality setting "Low (8-Bit)" and all my other slides are Quality High 24 bit.
How can I ensure all new slides take the High 24 bit quality setting ? I have looked in preferences but cannt see anything.
Noel
    Feb 17, 2012 8:34 AM   in reply to Noel Griffiths
    Easiest way is to override the slide quality settings on publishing
    I do not really know a way to have all new slides set to High, and would not use it myself. Either I want everything to be 'High' and then use the described way. To have this setting while editing, I select all the slides in the Filmstip (CTRL-A) and adjust the quality in the Properties panel. But when filesize is important I tend to choose individually the slide quality, depending on the objects on the slide.
    Lilybiri
    Feb 17, 2012 11:19 AM   in reply to Noel Griffiths
    Depends on the type of the slides. Pure text slides do not need High quality, as do Question slides. But if you use quality images, or images with transparency you'll need High or Optmizied. And if you do not have to bother about bandwidth, filesize you are free to choose highest for everything, audio etc. But same for audio: voice overs do not need the same settings as does music.
    Lilybiri
    Feb 17, 2012 8:55 PM   in reply to Lilybiri
    Lilybiri is correct.  You usually set the video quality to the lowest setting that will still allow sufficient quality according to the content on each slide.  Using lower quality settings on as many slides as possible, and using high quality ONLY where necessary, can have a huge impact on your published filesize.
    Feb 19, 2012 11:30 PM   in reply to Noel Griffiths
    Noel, it's really quite simple:
    • If quality is all that matters, your end-user bandwidth is unlimited, and filesize / loading time is unimportant, by all means use the highest quality settings.
    • If on the other hand bandwidth is limited, and filesizes must be kept minimal to avoid excessive loading times, then use the lowest quality settings that still allow your content to look and sound acceptable.
    In practice, working out these settings is always a compromise between quality and filesize.  Since bandwidth for some users is almost always limited, download times for multimedia e-learning can be highly variable.  You can often halve the filesize and thus double the download speed of an e-learning module just by sensible experimentation with the quality settings for video and audio.
    It's just a matter of striking the right balance.
