Anthonymcp
Resolution of screenshots in PDF
Feb 17, 2012 12:07 PM
Tags: #cs5 #export #interactive
I am creating an 8.5x11 PDF document that contains a screenshot. My workflow is take screen caputure > paste in Photoshop (resize/sharpen/trialerror) > save .png > drag .png into InDesign and set it to 100%. I cannot get the screen shot to not look blurry or pixelated no matter what I try. I understand when you zoom in on the PDF the screenshot will become blurry since it is not vector. However, I have the PDF set to 100% zoom and the screenshot is still blurry.
I have tried resizing in Photoshop, changing the resolution, etc. I can't get it to a point where the screenshot looks decent. Can anyone offer some advice? I am using Photoshop CS5 and InDesign CS5. I also have Illustrator CS5.
Thanks in advance,
Anthony
    Feb 17, 2012 12:14 PM   in reply to Anthonymcp
    Have you tried going to View > Display Performance > High Quality Display?
    Feb 17, 2012 12:27 PM   in reply to Anthonymcp
    I suppose it would depend on your export PDF settings. Are you exporting as lowest quality, highest quality etc? Also, within each setting, it shows the image resolution. make sure these are where you would like them to be.
    Edit:// I noticed your tag in there for 'interactive'. Same applies for the Interactive PDF setting as you will need to change the jpeg quality and ppi setting at the bottom of that dialogue.
    Feb 17, 2012 12:26 PM   in reply to Anthonymcp
    What are you doing to the screen cap in Photoshop? The correct answer should be NOTHING but saving in your format of choice. You cannot improve the quality of a screen shot by manipulation. Place as-is in ID, then scale if you must, and set your downsample threshold in the export dialog sufficiently hight that the screen caps are not resampled. YOu might want to swith to Zip compression, or none at all, too.
  • Rob Day
    Oct 16, 2007
    Feb 17, 2012 4:49 PM   in reply to Anthonymcp
    Any resampling (up or down), sharpening, or compression will degrade a screen capture.
    So if you export for print, do as Peter suggests: set sampling to Do Not Downsample and Compression to None.
    If you have to export for interactive, make sure the capture's Effective Res (see Info panel) doesn't exceed 300ppi and set Compression to JPEG 2000 Lossless with Resolution at 300ppi. There's no point to setting resolution to 144 because you never want a downsample to occur.
    Jul 21, 2012 5:17 AM   in reply to Rob Day
    This has been really helpful for when using Png's etc within indeign. How about pdf settings when I have a PSD placed within the indesign file?
    I am getting really poor quality still when using the above settings for files with PSD's in. The PSD files have bitmaps in but have layer styles applied such as a drop shadow, is this where the problem lies?
    Thanks in advance
    Ali
    Jul 21, 2012 8:57 AM   in reply to amgallop
    There shouldn't be any difference based on the file format. Can you give us some more details about what your images are? Are they being scaled? Perhaps some screen shots would help...
