There is a problem here, but I haven't uncovered a solution.
I created a registration form is LiveCycle ES2 which works great in Acrobat X, but when I try to save it with usage rights enabled, I get an error message, something like,
"This document could not be saved with Reader rights enabled." Something like that. I Googled it and searched the forums without finding an answer to my problem.
At work, I have Acrobat X and Reader 9 (I'm pretty sure). That is where I get the error. So the form is useless.
Then I came home tonight, where I have Acrobat X but Reader 7.0. Bingo! When I saved the form in Acrobat as Reader Extended PDF, there was no problem! And then I could open the form in
Reader 7. I got some messages about the version, but I ignored them. I wanted to see if the email submit button worked. And it did! So now I'm very happy, after days of frustration.
But the situation at work still nags me. Why couldn't I enable Reader usage rights there? Is there some known bug between Acrobat X and Reader 9? I wonder if I upgraded to Reader X my problem
would be solved.The question, basically, is "What Adobe versions of Acrobat and Reader do I need in order to enable usage rights for forms that I've created in LiveCycle ES2?"
The fact that you were saving from AA X has nothing to do with a Reader being installed on the system. No reader is required for the enabling, other than for testing. Apparently you have something wrong with your AA X installation at work. I would suggest you try a repair. If you have never done updates, I would actually start there (from the help menu).
Thank you, Bill. I don't know AcroForms. I'll have to look into that. But I'm very happy with LiveCycle. I've actually used that forum quite frequently. The reason I used this forum is that my problem was with Acrobat and enabling usage rights. It really wasn't about LiveCycle, which had already done its job by the time I ran into trouble. Thank you for your help and advice!
I looked up AcroForms, which are simply forms created in Acrobat. I probably looked into that when I started creating interactive forms a few years ago and chose LiveCycle instead because of the Script Editor (and, later, the Action Builder), the various behaviors available, and its database connectivity. If there's anything significant that I've overlooked, I'd be eager to know what that is. Thank you, Bill.
Some of the items you mentioned are also available in AcroForms I think, but I was just making you aware of the alternative. I don't keep track of who is new here and many of the forms questions come from new folks who are not aware of the alternatives. I believe that at one time George posted a link to a comparison of the two methods, but then my brain may be dead right now, more concerned about the snow I will have to deal with later. Since you are aware and have used the other forum, then you are in great shape. Bill
