redsunshine
was getting 3322 error on ubuntu, now 3323
Feb 19, 2012 12:13 AM
Tags: #error #player #linux #flash_access #drm #ubuntu #3322 #3323 #device_binding_failed #corrupt_global_state_store
I was trying to watch a video and I got an error telling me I needed to update my flash player, but I just installed a bunch of updates. I made sure my flash player was up to date and even tried installing chromium web browser to see if it would run in that.
Eventually I ended up at the adobe support pages, trying to test out why the drm might be failing, and I got this message in the test player.
Starts to get video metadata at Sat Feb 18 22:58:01 GMT-0800 2012
DRMContentData received on Sat Feb 18 22:58:01 GMT-0800 2012
authenticationMethod = anonymous
ServerURL = http://drmtest2.adobe.com:8080
license ID = 43345AEF-52FF-3F20-90FF-ABDC98A2E3E4
DRMErrorEvent dispatched by DRMManger received on Sat Feb 18 22:58:04 GMT-0800 2012
event type = drmError
Error Code = 3322 [DeviceBindingFailed]
Sub Error Code = 1107296263
Error Details =
drmUpdateNeeded = false
systemUpdateNeeded = false
after looking around a bit, I deleted the folders in ./adobe/FlashPlayer
tarts to get video metadata at Sat Feb 18 23:36:21 GMT-0800 2012
DRMContentData received on Sat Feb 18 23:36:21 GMT-0800 2012
Local voucher...
Load local voucher complete event received on Sat Feb 18 23:36:21 GMT-0800 2012
voucher not found in local voucher store.
DownloadVoucherComplete event received on Sat Feb 18 23:36:22 GMT-0800 2012
customPolicies :
policies.Giant = SuperDuperPanda
policies.playbackMode = all
policies.Sound of one hand clapping =
policies.DRMTEST2 =
policies.Slippery = Slope_Let's_Fall_Down_It
startDate = Sat Feb 18 23:36:22 GMT-0800 2012
endDate = Fri Aug 31 16:59:46 GMT-0700 2012
offlineLeaseStartDate = Sat Feb 18 23:36:22 GMT-0800 2012
offlineLeaseEndDate = Sun Feb 19 00:36:22 GMT-0800 2012
playbackTimeWindow = null
Start to play content on Sat Feb 18 23:36:22 GMT-0800 2012
DRMError event dispatched by NetStream received on Sat Feb 18 23:36:22 GMT-0800 2012
Error Code = 3323 [CorruptGlobalStateStore]
Sub Error Code = 1090519053
Error Details =
All I could find about this was
"Remedy is to retry the operation atleast once and if that gives the same error, then factory reset, [AdobeCP] will auto re-indiv"
I tried reinstalling flash, but still get the same CorruptGlobalStateStore error.
What do I do now?
    Feb 20, 2012 6:33 AM   in reply to redsunshine
    This should work - even with Chromium if you put the plugin in the right place (I assume you mean Chromium browser and not the Google Chrome which is different).
    What user are you logged in as?    I wonder if there's a problem writing the global store that Flash uses.   I have several Ubuntu installs (9.x and up) and they all work in this config (64 and 32 bit).
    The 'Device Binding' error was probably due to not having the Hardware Abstraction Layer (HAL).    There is a technote about this but I assume you got by that problem if you now get the new error (3323).   I think you may have to delete ./.adobe/Flash_Player one more time and look at permissions.
    You may want to stay on Firefox for the moment until you get this running.
    Stephen
