Andy 2012
Size of OS disc - Does anything speak against a 1TB OS-Disc opposed to a 500GB one?
Feb 18, 2012 7:59 AM
Tags: #size #disc #i7 #os #2600k
Dear All
Thanks to your answers here I think I was able to improve my build for cs5 editing. I chose a better PSU and a (hopefully) better case:
CPU  i7 2600k
Motherboard Asus P8Z68-V Pro
GPU Onboard, later nvidia 550 or 560
RAM 16 GB, made of 4 times DDR3 4GB/1600 CL9 Kingston KHX
HARD DRIVE (see question below)
OS Windows Premium 64 bit
Cooler Coolermaster Hyper 212 Plus
PSU Corsair TX750W M Modular 80+ Bronce
Case cooler-master-cm690-ii-advanced (yes, I know it could be bigger...;-)
I know they are not the "optimum" but I think they will perform "fine", won´t you think?
(As a side note, being a complete novice to all this, I am still asking myself how is it that brands like Asus and HP sell PC´s with i7 2600 processors
in my local shopping center with small cases and no extra fans/fan openings at all, and probably really low-level PSUs - I mean, will these explode after a few weeks, or won´t they just work fine for a few years if one doesn´t overclock
and of course accepts all disadvantages that come with such a "package" opposed to a on-purpose-built PC? These have warranties, too after all. In doubt, I´ll go with the above configuration, but the thought that I could a "cheesy" i7 from the mall,
still be able to do "okay" video editing, and buy almost a Samsung Note or a budget camcorder for the difference, that thought is kind of depressing.)
Now my question regarding the OS drive: General wisdom over here has it than one should choose a "fast, smaller disc" for the OS.
Okay, so I decided NOT to use an SSD at the moment and NOT to go for some extra-speedy and more expensive expensive small drive.
I "just" wanted to use an "inexpensive" Seagate 500GB drive with 7200 rpm and 16 mb of cache.
It might not be the perfect way but it´s the way I´ve chosen for the moment. Now, I wonder if, from this perspective, the "make the OS disc small" maxime still counts here, or in other words,
i can as well take the 1 TB version of this disc and get more space for my money, even if I use it for storage or whatever - my thinking is that independently from the other discs I´ll add to my
system, I could still benefit from that extra space and the better GB per Euro-ratio.
In one sentence: Does anything speak against a 1TB OS-Disc opposed to a 500GB one?
Here are some disks I can choose from, maybe you recommend one? (don´t know how much 16mb, 32 mb or 64 mb of cache matters here)
1TB Hitachi SATA2 32MB 7200RPM
1TB Seagate SATA3 32MB 7200RPM
1TB Seagate SATA3 64MB 7200RPM
Thanks in advance and have a good day!
    Feb 18, 2012 9:16 AM   in reply to Andy 2012
    You will never use more than say 50 GB on the OS disk, unless you really mess up your system, so what is the benefit of having 900+ GB of space laying waste instead of 400+ GB?
    Feb 18, 2012 9:54 AM   in reply to Andy 2012
    I agree with Harm.  Ideally you don't want to be using your edit rig for anything but editing, and anything you need to store for a project should be going on a dedicated drive, not the System drive.  So a 1TB will be largely a waste of space.
    Feb 18, 2012 11:25 AM   in reply to Andy 2012
    Maybe I get your sentence wrong, Harm, but do you mean that "using more than 50 GB on the OS disk" equals to "messing up my system"?
    Correct. The OS disk is for the OS & programs, nothing more. Data go on other disks. Pagefile goes on another disk. Media cache goes on another disk. Etc.
    considering the fact that still most PCs out there do only have one disc
    That is OK for gamers and office applications, but not for editing. For editing the absolute minimum is two disks, but to avoid slow response times, stickyness, freezing and the like, three different disks are the practical minimum.
    Feb 18, 2012 11:58 AM   in reply to Andy 2012
    Andy,
    I would say it depends...
    What is your plan for your "video drives / array(s)"?
    For example, if you were going to have only a 2x1TB RAID 0 for all of your video work, then a 1TB (or even larger / faster 2TB or 3TB) could double-duty as your render output drive, media cache, and media cache DB drive.
    However, if you have a full complement of video drives for Premiere Pro (as Jim and Harm both have), then a smaller boot drive would suffice.
    Jim
    Feb 18, 2012 12:06 PM   in reply to JEShort01
    could double-duty
    A lot of things "could" work, even a single drive.  But it's far from ideal.  If you're building from scratch, better to do it right from the beginning.  That means at least three drives as a practical minimum, with little or nothing more than the OS and Programs on the System drive.
    Does it have to be that way?  No.  But it is better that way.
    Feb 18, 2012 2:25 PM   in reply to Andy 2012
    My 3 hard drives are configured as...
    1 - 320Gig Boot for Win7 64bit Pro and all program installs
    2 - 320Gig data for Win7 swap file and video project files
    When I create a project on #2 drive, the various work files follow,
    so my boot drive is not used for the media cache folder and files
    3 - 1Terabyte data for all video files... input & output files (*)
    (*) for 4 drives, drive 3 all source files & drive 4 all output files
    Search Microsoft to find out how to redirect your Windows swap file
    http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US
    Feb 19, 2012 9:24 AM   in reply to Andy 2012
    I usually limit my OS drive to 320Gb... That give plenty of room for OS and PGMs...
    If the drive is larger, I split it to a second drive called: DOWNLOAD...
    This drive becomes the dumping ground for all downloads...
    This way, your OS Drive doesn't get filled with downloads you will forget about in 30 minutes.... Organizes your downloads in a way that you know it is not part of OS,
    and in general.... makes backups of the OS less 'crap-free'.  It also makes me look more organized than I really am! !
    On Laptop my drives are:
    C: Boot OS
    D: Optical DVD/R
    E: Media
    F: Download
    G: External ESATA Raid0  (optional)
    H: Exterenal BluRay Burner (optional)
    On my Desktop (server)
    C: 146Gb Boot OS (SCSI 320)
    D: DVD/R
    E: Media Backup SATA (Download here, too)
    F: Raid 0  Media drive (SATA)
    G: External BluRay Burner
    H: Preview Files (SATA)
    J: USBV3  (experiments being done with this... Considering using as Preview Files)
    Feb 19, 2012 9:27 AM   in reply to Jan Janowski
    Making a STATIC partition for file storage is not bad, just do not try and use that partition for video files you will use during editing... that is worse than having a single drive for software and video files, since the one set of read/write heads not only has to jump to a new place, your OS has to keep track of a separate 'room' in the warehouse that is your hard drive
    Feb 19, 2012 10:21 AM   in reply to John T Smith
    Agreed.... Download is labeled that way for that very reason.. Just to keep a convienent location for download of program  files only... which makes it easier to clean up aftereward... as opposed to on the C: drive.
    Media is a different physical drive in the laptop (as well as Desktop)....
    With the external Raid (Laptop) taking over these duties when it is connected.... and the internal Raid doing that on Desktop.
    But since the external raid is not always availble, that's why the 2nd physical media drive.
