Jona@semcon
Sequencer settings lost after system upgrade
Feb 17, 2012 5:46 AM
Tags: #windows7 #midi #audition_3.0 #vsti
Hello,
we just updated or studio-pc from Windows XP (32bit) to Windows 7 (64bit). We reinstalled Audition 3 (and patch 3.0.1) and set up Native Instruments Comlete 6 VSTi plugins. We can still open our old Session files, but all Sequencer settings, as the chosen VSTi and effect are gone.  Has anyone an idea how to recover the sequencer settings?
Jona
    Feb 17, 2012 7:47 AM   in reply to Jona@semcon
    Audition's settings files are stored in different places in Win XP and Win 7. So it depends how you did the update as to whether your XP settings still exist. They were in C:\Documents and Settings\User\Application Data\Adobe\Audition\3.0 where User is your user name. Check to see if Win 7 install backed up your Documents somewhere. If you can find the Audition 3 folder just copy the contents to the Win 7 folder C:\Users\User\AppData\Roaming\Adobe\Audition\3.0, which is the new one.
    Feb 20, 2012 3:23 AM   in reply to Jona@semcon
    it is quite possible that the actual VST settings were actually somewhere in the Windows registry rather than Audition's settings folder. The vstpluginmgr_settings.xml only holds the actually list of installed VST plugins, I suspect, not their individual settings. SteveG probably knows the answer but he is away at the moment.
    Feb 20, 2012 9:17 AM   in reply to Jona@semcon
    Siute Spot on his AA Translator site has a lot of info on moving sessions between DAWs. Not sure whether that includes MIDI tracks as well.
    Feb 21, 2012 5:22 AM   in reply to Jona@semcon
    Jona did send me some files to look at but unfortunately I have spent no time at all looking at Midi so I haven't been too much help at all.
    My guess also is that the ses file contains an ID to link to the VSTi but have no evidence as yet.
    Possibly if one of the devs jump in to throw some light it might point us in the right direction.
  • SteveG(AudioMasters)
    Oct 26, 2006
    Mar 3, 2012 11:37 AM   in reply to ryclark
    Well I've come back, but I'm not sure that I can tell you definitively, although I suspect that the answer is a horrible combination of several things. If the session file points to a specific location where settings are saved, and anything at all about that alters in a new installation, then they simply won't be found because the OS simply isn't intelligent. It wouldn't be, though - bloody Microsoft wrote it! So basically Suite Spot is, I'm sure, quite correct, even though he hasn't found it yet. If anybody can though, I suspect it's him.
    The only other thing to add is that there's definitely a difference between saving presets as Audition presets using plugins, and using the preset mechanism in the plugin itself. I would have expected that the Audition settings would be quite discoverable, but if they were stored as Native presets, that wouldn't necessarily apply at all.
