Movie star looks
Feb 20, 2012 8:11 PM
I want to create the movie star glow. Take lines out and make the face younger.  How can I do this without buying Portrait Professional.
Thank You, Penni
    Feb 20, 2012 7:51 PM   in reply to pennipeter
    There are lots of tutorials on the web for "removing wrinkles"  Here is one LINK from photoshop that might get you started.
    Hi Pennipeter
    Try onOne's free version of PhotoTools 2.6, there's an effect in there called "Model Skin," and that will get you started. This is, by the way, completely free and won't time out, plus you can upgrade to other products in the range at a discounted price.
    Good luck
    Paul
    Feb 20, 2012 9:04 PM   in reply to pennipeter
    It's called "retouching"....you can do that in Photoshop if you learn how. Is that what you are asking?
  • Noel Carboni
    Dec 23, 2006
    Feb 21, 2012 9:47 AM   in reply to pennipeter
    One effect is the "gauze softening filter" or "glamorous glow" look...
    http://upload.wikimedia.org/wikipedia/en/9/97/ChristineChapel.jpg
    This one's fairly easy - Make a new layer, Gaussian Blur, then mix it back with the original layer using partial opacity.
    -Noel
    Feb 21, 2012 10:45 AM   in reply to Noel Carboni
    You've got the technique a bit wrong, you don't just reduce the opacity at the final stage, you set the blend mode of the layer to either Soft Light or Overlay, here's with Overlay and ~90% opacity:
  • Noel Carboni
    Dec 23, 2006
    Feb 21, 2012 10:48 AM   in reply to Zeno Bokor
    Depends what you want to do (I like the softening), but yours is good too!  Thanks for the additional suggestion, Zeno.
    -Noel
    Feb 21, 2012 11:28 AM   in reply to Noel Carboni
    I'd never go with just Gaussian blur for softening because it's a dumb filter, it doesn't know the good details from the bad ones. If you want an easy way to soften skin then use Filter->Blur->Surface blur followed up by minor masking.
    Personally, for skin smoothing i prefer a more complex technique: duplicate layer, Invert, set blend mode to Vivid Light, use Gaussian Blur and raise until you start to see the pores and the like. You'll now have a ugly grayish image and what filter makes gray disappear? Filter->Other->High Pass which you set based on how smooth you want the skin to be. As the final adjustment mask out the effect in the essential details: eyes, mouth, etc.
    Feb 21, 2012 7:59 PM   in reply to pennipeter
    Noel,
    Thanks for the Majel Barrett photo!
    I'll never forget Nurse Chapel.
    Brings back memories. . .
    Feb 21, 2012 8:54 PM   in reply to Zeno Bokor
    For a soft focus look: Lighten or Screen, then dial back the opacity.
  • John Blaustein
    Aug 11, 2002
    Feb 21, 2012 9:46 PM   in reply to Chris Cox
    Chris,
    Would you mind elaborating a bit?  Do you do this on a separate layer, a duplicate of the background layer, after applying a blur filter?
    Also, in Lightroom, I can paint with the adjustment brush set to Clarity -100 for a nice soft skin look.  What would be the closest equivalent in PS?
    Thanks....
    John
    Feb 21, 2012 10:54 PM   in reply to John Blaustein
    Same as before: duplicate the layer, blur, set blend mode to Lighten or Screen, then dial back the opacity to taste.
    In Photoshop, Clarity -100 would be blurring a copy of the layer, adding a layer mask and painting in which parts you want blurry.
  • John Blaustein
    Aug 11, 2002
    Feb 22, 2012 7:51 AM   in reply to Chris Cox
    Thanks, Chris!
    John
