Set the appearance of a tool pointer
Feb 20, 2012 6:48 PM
    Feb 20, 2012 6:48 PM   in reply to Community Help
    The curser tip is crosshairs and reseting or changing preferenceswill not change it back to standard circle. What can fix this problem?
    Feb 20, 2012 6:59 PM   in reply to sls22
    I have had this problem many times with PSE 9.  PSE seems to sometimes ignore my preferences and chooses to do what it wants.  Even if I make no changes sometimes suddenly the appearance will change.  No matter what I do it won't change back to what I want.  I can exit PSE and restart and that also doesn't fix it.  I can reboot Win7 64-bits and that doesn't fix it.  Then just as suddenly as it stopped working correctly it will later appear correctly again.
    Feb 21, 2012 2:23 AM   in reply to Community Help
    Have you checked your Caps Lock - that can change the cursor.
    Also, if the brush size is too small it can change to cross hairs - try increasing the brush size.
    Brian
    Oct 17, 2012 12:00 AM   in reply to sls22
    You can set the tool pointer preferences from "Edit Menu>Preferences>Display & Cursors". For more help refer to
    http://helpx.adobe.com/photoshop-elements/using/tools.html#set_the_app earance_of_a_tool_pointer
    Also want to let you know that shortcut Capslock is used to "toggle between standard and precise cursors in some tool pointers".So if you only seeing the cross hair as your tool pointer , then this is because your caps lock key is pressed.
