nmcc16
Bridge CS5 Output to Web & PDF not appearing/ working
Feb 20, 2012 11:08 PM
Tags: #cs5 #macintosh #bridge #not_working #problems #adobe_bridge
Hi there, I'm using Bridge CS5 and the image processor and the output function has stopped working all of a sudden. All the appears is an empty panel in it's place.
I have done some reading through the discussions here and found my start up scripts folder is completely empty.
What can I do to fix this?
Can anyone help please???
Nat
  • Omke Oudeman
    Nov 27, 2004
    Feb 21, 2012 6:06 AM   in reply to nmcc16
    Quit Bridge and first use Apple Disk utility to check and repair the permissions for your start up disk. After this has been done restart Bridge holding down option (alt) key and choose reset preferences.
    When still in trouble also look at PS. Be sure to have all your customized settings, tools brushes and actions etc. saved as a back up so you can easily reload them if needed. The restart PS holding down shiftoptioncmd and also in here choose reset preferences. Again start Bridge holding down option key and again reset prefs. Try again. Could you report back if this worked?
