Mark0 31 posts
Feb 14, 2012
Link to a particular page of a PDF?
Feb 21, 2012 7:31 AM
Tags: #pdf #dps #ipad #page #digital_publishing_suite #htmlresources
After importing PDFs using the HTMLResources.zip method, is it possible to link to a particular page of a PDF? I tried doing it like you would link to a page in a folio ("filename.pdf#2") but no luck. I'm assuming using a navto won't work because the folio won't find the PDF in the HTMLResources that way.
Has anyone else been able to do this? If not, it should definitely be an added feature in the future.
Thank you.
    Feb 21, 2012 9:31 AM   in reply to Mark0
    Hi Mark
    Sorry I don't have the answer but I would be interesting by know how did you do to open a PDF from a folio? Do you have an exmple in indesign you can sended me?
    And also, does the PDF opens in the app? or does it bring the reader out of the app?
    Many thanks
    Feb 21, 2012 12:56 PM   in reply to Mark0
    Hi Mark
    THank you for the link
    I have make a test but it doesnt work, I am quite sure I didn't do it well
    I have imported my HTMLResources.zip successfully but the button with the GO to URL doesnt work
    does the entire pathe is:
    http://HTMLResources/Test.pdf
    I have tried also with navto:// but same think
    Because I have tried other path but it is still "in progress3 icon but the PDF doesnt show. Sorry It might be obvious but I am not familiar with that
    Maybe I didnt put the zip file in the good place
  • Bob Bringhurst
    May 29, 2007
    Feb 21, 2012 1:15 PM   in reply to minia92
    Here are the general steps:
    1. Select the contents of the HTMLResources folder and create a .zip file. Do not create your .zip file from the HTMLResources folder, or it won't work. In your example, you would select the Test.pdf file, compress it to a .zip file, and rename it HTMLResources.zip.
    2. Import the HTMLResources.zip file.
    3. Create a button with a Go To URL action. In your example, you would specify HTMLResources/Test.pdf. Upload article.
    4. Test on iPad. (The PDFs don't appear in the desktop viewer.)
    Feb 21, 2012 1:52 PM   in reply to minia92
    Do NOT use http:// or navto://, just HTMLResources/name.pdf
    But I guess the original question was to go to a specific page in the PDF (like navto#), as far as I have tested that is not possible. Inn that case make several seperate PDF files of pages and link to that PDF.
    Feb 21, 2012 2:00 PM   in reply to Bob Bringhurst
    Works perfectly (I was just testing in the desktop viewer)
    Thank U
    Feb 21, 2012 2:00 PM   in reply to Frans van der Geest
    Yes It was the first question of this topic.... Thanks for your answer
    SO I guess if we want to target a specific page, we should use a workaround like putting the PDF pages in a MSO... It would also allow us to customize the navigation with buttons....
    THank you F
    Oct 4, 2012 12:18 PM   in reply to Bob Bringhurst
    I was wondering if you could make a pdf file contained in the HTMLResources folder open up directly in Adobe Reader on the iPad, assuming the app is installed?
