swisnies256
Drawing a text string on the document
Feb 18, 2012 5:23 PM
I'm new to illustrator, how to I put a text string on a document.
    Feb 21, 2012 7:25 AM   in reply to swisnies256
    Take a look at the SnpText.cpp in samplecode/CodeSnippets/
    Feb 21, 2012 10:24 AM   in reply to swisnies256
    The snippet panel is kind of simplistic, and I suspect its dropping new version of text on top of one another so you're probably looking at a pile of text objects (you've probably figured that out though).
    To change the text of existing text, you'll need to the handle of the text you want to change. I don't reccommend hanging on to these handles outside of a 'session' -- there are things that cause handles to change, and the object might be deleted after all. Still, assumg you've got the handle, maybe by pulling it from the set of selected art. Then you'd do something like this:
    void SetText(AIArtHandle handle, const ASUnicode* text, int length)
    TextRangeRef ref = 0;
    sAITextFrame->GetATETextRange(handle, &ref);
    ATE::ITextRange range(ref);
    // clear it first
    range.Remove();
    // now set it
    range.InsertAfter(text, length);
