rodniels
Installing trouble
Feb 10, 2012 12:09 AM
I can´t install CS5.5 Master Collection. I´ve allready tried to un/install .NET framework but nothing happened.
What the log says is:
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 140 error(s), 136 warning(s)
----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
ERROR: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80070005.
ERROR: Install MSI payload failed with error: 1603 - Error irrecuperable durante la instalación.
MSI Error message: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80070005.
WARNING: DW036: Payload cannot be installed due to dependent operation failure
WARNING: DW036: Payload cannot be installed due to dependent operation failure... and so on
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050:  - Adobe Buzzword CS5.5: Install failed
ERROR: DW050:  - Adobe Dreamweaver CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Microsoft_VC90_ATL_x86: Install failed
ERROR: DW050:  - Adobe Linguistics CS5 x64: Install failed
ERROR: DW050:  - AIR for Apple iOS support (FB): Install failed
ERROR: DW050:  - Digital Publishing: Failed due to Language Pack installation failure
ERROR: DW050:  - Microsoft_VC90_CRT_x86: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Core: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Premiere Pro CS5.5 Support: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS5.5_AdobePremierePro5.5es_ESLanguagePack: Install failed
ERROR: DW050:  - Microsoft_VC80_ATL_x86: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050:  - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050:  - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050:  - AdobePDFL x64 CS5: Install failed
ERROR: DW050:  - DynamiclinkSupport: Install failed
ERROR: DW050:  - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: DW050:  - Adobe Audition_AdobeAudition4es_ESLanguagePack: Install failed
ERROR: DW050:  - IE Plugin CS5.1: Install failed
ERROR: DW050:  - Adobe Illustrator CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe XMP Panels CS5: Install failed
ERROR: DW050:  - Pixel Bender Toolkit: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5.5: Install failed
ERROR: DW050:  - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
ERROR: DW050:  - Adobe Hunspell Linguistics Plugin CS5.5: Install failed
ERROR: DW050:  - CSXS Story Extension: Install failed
ERROR: DW050:  - Photoshop Camera Raw: Install failed
ERROR: DW050:  - Camera Profiles Installer: Install failed
ERROR: DW050:  - Adobe Flash CS5.5_AdobeFlash11.5-es_ESLanguagePack: Install failed
ERROR: DW050:  - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050:  - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050:  - Adobe Flash Player 10 Plugin: Install failed
ERROR: DW050:  - AdobeColorCommonSetRGB: Install failed
ERROR: DW050:  - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: DW050:  - AdobeColorPhotoshop CS5.5: Install failed
ERROR: DW050:  - Firefox Plugin CS5.1: Install failed
ERROR: DW050:  - Adobe Linguistics CS5.5: Install failed
ERROR: DW050:  - Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-es_ES: Install failed
ERROR: DW050:  - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Office Plugin CS5.1: Install failed
ERROR: DW050:  - Adobe Mini Bridge CS5.1: Install failed
ERROR: DW050:  - Adobe Contribute CS5.1_AdobeContribute6.1es_ESLanguagePack: Install failed
ERROR: DW050:  - AdobeMotionPicture CS5.5: Install failed
ERROR: DW050:  - Adobe Dreamweaver CS5.5_AdobeDreamweaver11.5es_ESLanguagePack: Install failed
ERROR: DW050:  - Adobe SING CS5: Install failed
ERROR: DW050:  - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050:  - Adobe OnLocation CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-es_ES: Install failed
ERROR: DW050:  - Adobe Illustrator CS5.1_AdobeIllustrator15_1es_ESLanguagePack: Install failed
ERROR: DW050:  - Adobe InDesign CS5.5 Application Feature Set Files: Install failed
ERROR: DW050:  - Photoshop Camera Raw (64 bit): Install failed
ERROR: DW050:  - Microsoft_VC90_MFC_x86: Install failed
ERROR: DW050:  - Adobe Flash Builder 4.5: Install failed
ERROR: DW050:  - Adobe Media Encoder CS5.5 X64: Install failed
ERROR: DW050:  - Adobe Encore CS5.1_AdobeEncore5.1es_ESLanguagePack: Install failed
ERROR: DW050:  - AIR for APPLE IOS Support (FP): Install failed
ERROR: DW050:  - Adobe Linguistics CS5: Install failed
ERROR: DW050:  - PDF Settings CS5: Install failed
ERROR: DW050:  - AdobeTypeSupport CS5: Install failed
ERROR: DW050:  - Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-es_ES: Install failed
ERROR: DW050:  - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050:  - Adobe Flash Player 10 ActiveX: Install failed
ERROR: DW050:  - Adobe InDesign CS5.5 Common Base Files: Install failed
ERROR: DW050:  - Adobe Flash Fonts1: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Spanish Language Pack_AdobePhotoshop12-es_ES: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Support: Install failed
ERROR: DW050:  - Adobe OnLocation CS5.1 Third Party Content Wrapper: Install failed
ERROR: DW050:  - AdobeColorEU CS5.5: Install failed
ERROR: DW050:  - AdobeHelp: Install failed
ERROR: DW050:  - Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-es_ES: Install failed
ERROR: DW050:  - Required Common Fonts Installation x64: Install failed
ERROR: DW050:  - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: DW050:  - Adobe InDesign CS5.5 Application Base Files: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe InDesign CS5.5 Icon Handler: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5_AdobeAfterEffects10.5es_ESLanguagePack: Install failed
ERROR: DW050:  - Adobe Fireworks CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Story: Install failed
ERROR: DW050:  - Microsoft_VC90_MFCLOC_x86_x64: Install failed
ERROR: DW050:  - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: DW050:  - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: DW050:  - Microsoft_VC80_CRT_x86: Install failed
ERROR: DW050:  - Adobe Device Central CS5.5_DeviceCentral3.5LP-es_ES: Install failed
ERROR: DW050:  - AdobeCMaps x64 CS5: Install failed
ERROR: DW050:  - AdobeTypeSupport x64 CS5: Install failed
ERROR: DW050:  - Adobe InDesign CS5.5 Icon Handler x64: Install failed
ERROR: DW050:  - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
ERROR: DW050:  - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: DW050:  - AdobeColorJA CS5.5: Install failed
ERROR: DW050:  - Adobe OnLocation CS5.1_AdobeOnLocation5.1es_ESLanguagePack: Install failed
ERROR: DW050:  - AdobeOutputModule: Install failed
ERROR: DW050:  - Acrobat Professional: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: DW050:  - Adobe Fireworks CS5.1_AdobeFireworks11.1.0es_ESLanguagePack: Install failed
ERROR: DW050:  - Microsoft_VC90_MFCLOC_x86: Install failed
ERROR: DW050:  - AIR for APPLE IOS Support Wrapper: Install failed
ERROR: DW050:  - AdobePDFL CS5: Install failed
ERROR: DW050:  - AdobeCMaps CS5: Install failed
ERROR: DW050:  - Adobe Toolhints CS5.5: Install failed
ERROR: DW050:  - Adobe CSXS Extensions CS5.5: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Presets: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
ERROR: DW050:  - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: DW050:  - ph: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Spanish Language Pack_x64_AdobePhotoshop12-es_ES_x64: Install failed
ERROR: DW050:  - Adobe ReviewPanel CS5.5: Install failed
ERROR: DW050:  - Required Common Fonts Installation: Install failed
ERROR: DW050:  - AdobeColorVideoProfilesAE CS5.5: Install failed
ERROR: DW050:  - AmericanEnglishSpeechAnalysisModels: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Player for Embedding x64 3.1: Install failed
ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050:  - HIL Help Search: Install failed
ERROR: DW050:  - Microsoft_VC80_MFC_x86: Install failed
ERROR: DW050:  - Adobe Player for Embedding 3.1: Install failed
ERROR: DW050:  - CS5.5 Master Collection: Install failed
ERROR: DW050:  - Adobe Audition: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Flash Catalyst CS5.5: Install failed
ERROR: DW050:  - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: DW050:  - Adobe Flash CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - SiteCatalyst NetAverages CS5.5: Install failed
ERROR: DW050:  - Adobe Contribute CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe InDesign CS5.5 Application Base Files2: Install failed
ERROR: DW050:  - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul: Install failed
ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
ERROR: DW050:  - AdobeColorNA CS5.5: Install failed
ERROR: DW050:  - AdobeJRE: Install failed
ERROR: DW050:  - Adobe Player for Embedding 3.2: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - AdobeColorVideoProfilesCS CS5.5: Install failed
ERROR: DW050:  - Adobe Bridge CS5.1: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Support: Install failed
ERROR: DW050:  - Adobe Dreamweaver Widget Browser: Install failed
ERROR: DW050:  - Adobe Encore CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
ERROR: DW050:  - Adobe Content Viewer: Install failed
PLEASE SOMEBODY HELPS!!!!
    Feb 10, 2012 12:22 AM   in reply to rodniels
    Did you try to manually install MSVC?
    Mylenium
    Feb 10, 2012 4:00 AM   in reply to rodniels
    The following document lists some common reasons and solutions to resolve the error.
    http://kb2.adobe.com/cps/843/cpsid_84332.html
    Let us know if Mylenium's solution, or any of these help.
    Feb 10, 2012 8:00 AM   in reply to rodniels
    Hi, please follow the below steps and check whether it will resolve your issue.
    1. Please install Microsoft_VC90_CRT_x86, by navigating to the Payloads folder from where you were installing the product.
    2. Check whether you have installed Microsoft .NET Framework 4 and Microsoft Visual C++ 2010 Redistributable Package (x64), if it is 64 bit or Microsoft Visual C++ 2010 Redistributable Package (x86) if it is a 32 bit computer.
         You can check whetehr it is installed or not in Control Panel > Add or Remove Programs(Windows XP) or Uninstall Program (Windows 7) and check whether above mentioned software are listed, if not please download and install it.
    3. Please open services.msc, by opening Run window (you can open Run window, by pressing Windows key + R key on keyboard) and typing services.msc in the Run window and hit enter.
         You will get a new Services window, please search for Windows Installer in the Services window, and check whether it is started, if not please double click on the Windows Installer and click on Start button.
         Please do the same for Windows Modules Installer in the Services window.
    4. Now, please try to install the product, if you are still getting the error, please continue the troubleshooting steps from the 5th step.
    5. Open Command Prompt, by opening Run window and typing cmd and then hit enter.
         a) In Command Prompt window, Type sfc /SCANNOW and press Enter.
         b) When the system scan completes, type msiexec /unreg in the Command Prompt window, and press Enter.
         c) After that, type msiexec /regserver into the Command Prompt window, and press Enter.
          d) Now, reinstall the product.
    6. If the issue is still not resolved, create a new admin account and install the product from new admin account.
    Feb 21, 2012 11:38 AM   in reply to rodniels
    Please check the below link and see whether it will resolve your issue:
    http://forums.techarena.in/windows-update/865434.htm
    Apr 12, 2012 6:10 PM   in reply to rodniels
    I don't know, if it's still relevant. I had the same problem. After days or weeks trying I installed WindowsServer. At the same time I downgraded to an older sevicepack. Then I could install it. I thought it has been the WindowsServer. I didn't install it, when I was installing the Internet Explorer. so here you can download it. It's in the IE-package:
    for 64bit systems:
    http://www.microsoft.com/download/en/details.aspx?id=23332
    Hope it works for you too,
    greetings from Germany (so sorry, if my english is not well),
    iIrRm
    Apr 12, 2012 9:54 PM   in reply to rodniels
    Its hard to say that but it seems to me that its an issue with your Win 7 as you are getting error:1935 even while installing Microsoft_VC90_CRT_x86, which is a microsoft component.
    Looks like the .Net Framework and Visual C++ components have been messed up due to some reason.
    Try repairing your win 7. Rather its called "Inplace Upgrade" in win 7 and check if that helps as repair might fix those 2 components.
