i captured video on my old desktop (digiVCap) , i have Premiere 1.5, but wanted to use my new latop w/i7 cores to edit
i couldn't get v1.5 to install so found premiere elements & have v10 installed
i downloaded & installed the matrox codecs after installing premiere elements
premiere elements loads my videos and plays audio only
do i need to uninstall/reinstall to pick up the codecs (or a reboot)??
mark
the videos play fine on the laptop using divx (even before installing the matrox codecs)
Wait. What? You're getting video from a camcorder with an IEEE-1394 connection?
Then why are you using a digitizer at all? Video captured over a FireWirec connection (miniDV or HDV) should be captured by Premiere Elements through an IEEE-1394 and it will be editable as is.
Why are you getting this Matrox device in the mix? It's at the root of your problems!
i bought this system years ago
i haven't done any editing in a while so i thought i better grab the video off my tapes before they deteriorate
i have a matrox RT.X100 card & Premiere 1.5 and that was what i always captured
since my laptop has more power than my old desktop i was hoping to edit on there, once i had captured the video
a lot has improved since then, & i have lightroom 3 and thought i would get the elements 10 (for photoshop editing of lightroom photos) and get p-elements 10 for doing the videos
i don't have a 1394 interface on this laptop, but i'm sure my older 1 does
so i should just capture using e10?
mark
I highly recommend against using a capture card or a cheap digitizer like Pinnacle's Dazzle. You'll only run into the same issues as you've had with the Maxtor video.
As the FAQs to the right of this forum suggest, your best solutions are the Canopus AVDC and (if you can still find them) the ADS Pyro AV Link.
Does your laptop have an ExpressCard Slot, or a PCMCIA Slot?
I have used the SIIG IEEE-1394A for PCMCIA, and it worked fine.
For my IEEE-1394B (FW-800), I use the StarTec ExpressCard, but this is their IEEE-1394A ExpressCard.
Those are NOT the cheapest of each type of card, which start at around US $ 14.00.
Good luck,
Hunt
Does Windows see the camera?
When plugged-in, and you turn it on, do you hear the "bing-bong," and see a Windows pop-up, saying that the camera has been recognized?
If not, go to Control Panel>System>Hardware>Device Manager, and look for the camera. Any warning, or error messages?
Good luck,
Hunt
Mark,
Great news!
Yes, the Capture module is only in PrE (or PrPro, if one had that program). Glad that all is working well, especially as troubleshooting FW problems can take some time - checking cables, connectors on camera/computer and then the FW card/chip, and its driver, etc.
Happy editing,
Hunt
It goes away
How can I remove the watermark from projects created with the trial version of the program?
Cheers,
Neale
Insanity is hereditary, you get it from your children
