Some Questions on CF10 > Server Update > Updates
Feb 20, 2012 2:55 PM
The "CF10 feature PDF" says:
Server update... The updates can include hot fixes and security hot fixes for ColdFusion 10.
Will traditional "CF updaters" be a separate process apart from hotfix, cumulative hotfix and security update eg  ColdFusion 9 Update 1 (9.0.1)?
Will the update type be specific and say-
Update Type: cumulative or hotfix or security?
Previously patch order had a bearing on the wellbeing of CF. For instance one would elect to install say updater1 followed by cumulative hotfix  then subsequent security patch eg CF9.0.1, CHF1, APSBxx-xx. Will CF10 updater manage patch order or prerequisites not allowing incorrect update order?
Thanks, Carl.
    Feb 20, 2012 4:27 PM   in reply to carl type3
    Carl, we will check this and get back to you on this.
    Feb 20, 2012 10:40 PM   in reply to carl type3
    Hi Carl,
    Form ColdFusion 10 onwards, all updates will be cumulative. This means that all fixes of previously relased hotfix be included in any new hotfix which comes later.
    Also the previous process of deploying jar files in through Server Manager won't be relevant with ColdFusion 10 as now hotfix jar will be full installer(unlike previous hotfixes which required copying them to lib/updates folder in CF server).
    Regarding the error with current hotfix, we are in prcess of updating new test hotfix which will be compatible with the beta release. If you have installed he current one, you can unistall it with uninstaller placed under <CF-HOME>/cfusion/hf-updates/<hotfix name> folder or through Admin (under Installed updates tab on updates page).
    thanks,
    Sandeep Paliwal
    Adobe ColdFusion team
    Feb 21, 2012 10:56 PM   in reply to carl type3
    Hi Carl,
    We have updated test hotfix compatible with ColdFusion 10 Beta.
    If you have installed the previously available hotfix, make sure you uninstall it, else latest one be shown as available one for download in CF Admin.
    thanks,
    Sandeep Paliwal
    Feb 21, 2012 10:58 PM   in reply to Sandeeppaliwal
    Thanks Carl for pointing this out.
    We will update Server manager docs to reflect the new change.
    Please feel free to log a bug for this.
    thanks,
    Sandeep Paliwal
    Feb 21, 2012 11:48 PM   in reply to carl type3
    Currently there is issue with update uninstaller which does not restart CF server post uninstall.
    We are aware of the bug, and it should be fixed going forward.
    thanks,
    Sandeep Paliwal
    Feb 23, 2012 1:43 AM   in reply to carl type3
    Thats great to hear.
    Thanks a lot for your feedback on this.
    -Sandeep Paliwal
Incoming Links
