I am trying to use the cfcontent string and the pdf I have also includes a Acrobat destination..when I enter the destination
test.pdf#4
it errors out..
Due to cf statements, I then enter
test.pdf##4
and then it says in the cfcontent error message
file not found
Is there a way to include this type of filename?
Leo
If you have a code question, it's always helpful to include your actual code, rather than describe it.
One thing you should bear in mind is that the FILE attribute of <cfcontent> references a file (on your file system), not a URI. So it's inappropriate to include URI-specific elements in that value.
The fragment part of a URI (the bit after the #) is only relevant ot he browser, so to hit that fragment, it needs to be in the address the browser requested. It's nothing to do with what you send ba
...Copy link to clipboard
The fragment part of a URI (the bit after the #) is only relevant ot he browser, so to hit that fragment, it needs to be in the address the browser requested. It's nothing to do with what you send back (you just send back the document).
You coudl conceivably use <cfheader> to tell the browser to fetch the URI with the fragment, and then from that URI return the PDF file. The browser should then - if it suuprts PDF fragments - work out what to do.
Adam
Thanks for the feedback Adam..you have answered my question..did not make the correlation with the brower request vs file request.
Will also include code in the future.
Leo
