Memory leak found - coldfusion.util.key
Feb 22, 2012 1:11 AM
Tags: #memory_leak #cf10
Hey All,
I found this memory leak in CF9.01 and have confirmed it still exists in CF10.
To reproduce, create two .cfm files & hit them in an Apache JMeter test with two threads.  I'm using a brand new install of CF10 with inbuilt web server.  MemoryLeak.cfm will not acheive 100 requests (GC overhead limit exceeded), where as my NoMemoryLeak.cfm test is up to 500,000 tests and still going without the old gen increasing at all.
Obviously this is not real production code, but on a very large OO app that also uses lots of structs the test server needs rebooting every 2 weeks due to same problem.  We are on CF8 at the moment and want to spend AU$50,000 on a 9.01 upgrade with maintenance for a 10.0 upgrade but can't move because of this memory leak.
-- MemoryLeak.cfm
<cfset transient = structNew() />
<cfset base = getTickCount() />
<cfloop from="1" to="10000" index="index">
<cfset transient[hash("#base##index#")] = true >
</cfloop>
<cfoutput>
Done
</cfoutput>
-- NoMemoryLeak.cfm
<cfset transient[hash("#index#")] = true >
</cfloop>
<cfoutput>
Done
</cfoutput>
    Feb 22, 2012 6:56 AM   in reply to Davo112233
    Thanks for reporting this issue. Can you please log a bug in the bugtracker? This will help us track and investigate the issue.
    Feb 22, 2012 11:32 AM   in reply to hemant_k
    No worries.  Logged as Bug #3120864 for CF10.  - I logged similar bug for CF9.01 yesterday as #3119991  - the test casees for #3120864 make it easer to see the acutal bug.
    Dave
    Feb 22, 2012 5:27 PM   in reply to davidames
    +1
    Feb 23, 2012 2:42 PM   in reply to hemant_k
    Is there a way we can speed up getting a fix for this issue, even in CF9.01?  Would a paid support incident help?  Or can we pay for a fix for this issue?  This is a big problem for us.
    Dave
    Feb 23, 2012 3:35 PM   in reply to davidames
    Yes, I would recommend you to go through the support for this.
    Sent from my HTC
    Feb 23, 2012 5:04 PM   in reply to rupesh_kumar
    Will do. In the mean-time,
    A colleague  came up with a solution that involves sub-classing the ColdFusion.Util.Key class and calling keys.clear() We plan to do this via a scheduled task every night.  Do you see any obvious problems with this approach?
    Field f = Key.class.getDeclaredField("keys");
                f
    .setAccessible(true);
    ConcurrentHashMap chm = (ConcurrentHashMap)f.get(k);
                chm
    .clear();
    See: http://stackoverflow.com/questions/5898291/coldfusion-util-key-memory- leak-issue-with-structure-keys/9401913  for the full post/details
    dave
    Feb 28, 2012 9:48 PM   in reply to davidames
    Hi Dave,
    I see the CF10 bugbase has issue withdrawn. CF9 bugbase has fixed. Is there a hotfix for this to download and try on CF9 and CF10?
    Cheers, Carl.
    Feb 28, 2012 9:53 PM   in reply to carl type3
    Carl,
    I would request you to go through the support to request a hotfix for this.
    Thanks & Regards,
    Rupesh
