Just_Be
Set up project questions
Feb 22, 2012 2:10 AM
Hi
I have made different movies
But I have troubles to set up a project:
1) Audiorate: I can't choose for an audiorate of 16 Khz, and this might be a reason why I can't edit video's with audio
2) Framesize. I see black area's on the side, in VIEW panel, something I don't see in source panel. I thought it had
    to do with the framesize I choose but I am not sure.
These are the specs I have found:
* .Mov file
* Frame width = 1920
* Frame height = 1080
* Frame rate = 23 fr/sec
Audio
* Audio sample rate = 16 Khz
* Bitrate = 24 kHz
Then there are two specs Datarate: 18529 kbps and total bit-something-rate = 18914 kbps.
    Feb 22, 2012 7:55 AM   in reply to Just_Be
    The easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    Feb 22, 2012 9:06 AM   in reply to Just_Be
    Isn't weird that I can see and play movie in source panel but not edit it?
    Not really, as the Source Monitor is a simple player, and is accessing the file from the HDD. The Program Monitor displays the Sequence/Timeline, prepared for editing - much more involved.
    I think that John T's link will help you easily set up your Sequence for editing.
    Good luck,
    Hunt
    Feb 22, 2012 12:15 PM   in reply to Just_Be
    Glad that the video in John T's link was useful.
    As for Audio, did you let the Audio Conform 100%, before dragging it to the Timeline? This ARTICLE will give more details.
    Does the Audio play from the Timeline just fine?
    If you Alt-click on the Audio Stream in that Clip, and do a Render/Replace, can you then edit that resulting WAV?
    Good luck,
    Hunt
    Feb 22, 2012 12:43 PM   in reply to Just_Be
    Yes, dragging the AV file (once Conforming has completed 100%) to the New Icon should create a matching Sequence (which we see as a Timeline), and place your Clip onto it.
    If the Audio plays completely from the Timeline, then you should be able to edit it. In the Timeline/Sequence, the program should be referencing the CFA (Conformed Audio file), and what you see on the Audio Track will be the Waveform Display file, the PEK.
    If you still have problems with editing the Audio Stream in that Clip, I would explore Render/Replace, which will convert your Audio Stream to PCM/WAV.
    Good luck,
    Hunt
