Your disk copy of image was changed since last opened or saved (Mac OS)
Jan 3, 2012 12:33 PM
  Latest reply: Chris Cox, Oct 21, 2012 1:00 PM
Replies 1 2 3 4 5 6 Previous Next
    Oct 9, 2011 1:49 PM   in reply to caligula1
    I was getting this dialogue literally every time I saved a document, it was maddening. I began shutting down all external resources and programs one at a time and I did, indeed, narrow it down to Suitcase Fusion 3 (14.1.1).
    Detailed fix:
    1. Open Suitcase, go to the "Suitcase Fusion 3" menu item and select "Manage Plug-ins..."  Uncheck all plugins for Photoshop.
    2. Suitcase should remove the plugin, but, just to be sure, go into the Photoshop application folder and into Plug-ins/Automate and make sure Suitcase's font management plugin is not in there. If it is, delete it.
    3. Restart Photoshop (important! you won't see the change unless you do this).
    If you need fonts activated in Photoshop, after deleting the plugin you can go into "Suitcase Fusion 3" > "Preferences..." and add Photoshop to the "Auto-activate fonts for the following applications:" list. This seems to auto-activate fonts succesfully without the plugin. In fact, I have absolutely no idea why you need the plug-ins, I've removed them from all Adobe apps and added the apps to the auto-activate list instead and it seems to be working famously.
    Hope this helps some of you. And thanks to everyone who came before me in this thread for helping me solve the problem!
    FOLLOW UP
    It seems that if you don't have the plugins installed and you restart your computer, you'll need to open Suitcase once before programs will activate fonts. Minor inconvenience compared to those caused by the plugins, in my opinion.
    Nov 6, 2011 8:36 PM   in reply to joerivera
    Regarding the original post I get the same message sometimes when saving .psb files, nothing else, and my usual response is to do a save as and not worry about it.  I just googled this condition and came upon this thread to see if there's any reason to be concerned about it and I think I'll just leave well enough alone.  I use CS4 and don't have Suitcase.  Best, Dave
    Nov 8, 2011 10:57 AM   in reply to caligula1
    Just now decided to see what might be causing this warning (after recently upgrading to Lion). The solution posted on Aug 30 by lem0nayde nailed it for me. I did not thoroughly read all the posts, but many thanks to "lem" and to all who contributed, especially Chris, who took a lot of heat, mostly unwarranted. Adobe cannot check for everything, especially 3rd party software, though you would expect that they would be using Suitcase themselves or at least make it part of their testing because so many of their customers use it. Also, I am a single user on a single system, and there are probably a fair number of us, so if this "feature" is to warn that changes have been made to a file by a different user on the same network, I would hope that Adobe would either be able to detect when the warning is not relevant or allow a single user to opt out.
    Dec 21, 2011 4:59 PM   in reply to caligula1
    Just wanted to add that I have this problem too.
    I do not have Suitcase installed.
    I suspect this has something to do with Time Machine.
    Often, when I try to eject my Time Machine disk, it tells me the disk could not be ejected because Photoshop is using it—which it shouldn't be.
    Feb 5, 2012 11:44 PM   in reply to caligula1
    I to have been experiencing this problem for the last few months and can appreciate the frustration of those who have yet to resolve it.
    After reading the entire thread, I took the advice of lem0nayde (post 160) of removing the Extensis Photoshop plugin and magically the problem has gone!
    I currently have installed the most recent Suitcase Fusion 3 Version 14.2.0 (319) on OS 10.6.8 on a MacBook Pro that's independent from a network, so clearly there are still problems with even the most recent versions of Suitcase plugins - although based on the other contributors to the thread there are other circumstances that contribute to the error message occurring as well.
    For what it's worth, I have been using the Adobe suite of software since Photoshop 3, Illustrator 5 and then Pagemaker along side Quark before moving to InDesign (so about 16 years) and during that time I have always used Suitcase as my font management tool, and while it has been reasonably stable on the whole, it has probably been the most common third part plugin that has given me problems with other applications over that period of time - all be it infrequently - so for those trouble shooting in future, it's perhaps a good first place to start by disabling it first to see what happens.
    Best of luck to those who still haven't managed to nail it yet.
    Feb 22, 2012 2:38 PM   in reply to caligula1
    I started having this problem several months ago - after an OS update on snow leopard.  I've since uprgaded to Lion and re-installed my CS5.5 --- and the problem is still there.  I've given up troubleshooting at this point, and just click to save the file!
    Feb 22, 2012 3:17 PM   in reply to kellisswan
    Please read the previous replies.  Photoshop is just informing you of changes made to the file outside of Photoshop.
    Mar 5, 2012 1:57 PM   in reply to Chris Cox
    I have this problem too, I am on Lion OS X, I do not have time machine active or suitcase installed. I do use Dropbox, but it is not part of my PS workflow. Images are usually from lightroom being "editing in PS". Just posting for others in case this helps troubleshoot.
    Mar 8, 2012 9:16 AM   in reply to caligula1
    Just want to chime in that I too have been having this problem. I am using CS5.5 on OS X Lion 10.7.3. I started noticing the problem since installing Lion, so it's been about a year, and I finally looked it up and found this thread.
    Sometimes, I open a file, make one small change, save it, and get the error. Other times, it happens to files I have been working on for a longer time. Sometimes, when I am working, it happens every time I save as I work.
    Until reading this thread, I thought the issue was purely Lion-related. (Time Machine local backups also seem to be chewing up disk space, and I suspect there is a connection.) However, I see here that many people are having the problem on earlier versions of CS as well as OS X.
    I do not use Suitcase or Fusion. I do use Topaz plug-ins. I did change my scratch disk preferences a while back, and also suspect it could be something to do with that. The problem occurs when Bridge is open, and also when it isn't.
    My system is old and full of crud. I haven't done a clean install for years, thought I do try and clean it up from time to time.
    So... not very helpful, I know, but another voice saying, "Hey, there may be more of us than you think!"
    Mar 8, 2012 9:39 AM   in reply to Deedge
    If it's any help, I'm still on OS 10.6.8, CS4 and I don't run Time Machine, Suitcase or Extensis and I get the message occasionally, but only on the rare occasion when I'm saving large document files.  I don't know why some third party thing would only target those files so I'm not buying adobe's claim that it's not responsible.  But there isn't any real world problem, save as works, the files aren't broken or anything, it's just a minor nuisance.
    Dave
    Mar 12, 2012 3:45 PM   in reply to caligula1
    I know it's maddeninly unhelpful, but I have this problem as well. It happens most often when I'm working on a file that's 50MB or more, and most of the work I do in Photoshop CS5 easily swells past 100MB (large illustrations will do that to ya before you flatten them). I started noticing it after reformatting my hard drive this December, which had originally been partitioned into a Boot section and a User Data section. My scratch disk settings use my external hard drive as the primary and my internal hard drive as the secondary. I am running 10.6.8, Snow Leopard, no Suitcase or Fusion or anything. Time Machine is inactive. I have 4GB of ram. Whenever the message pops up, my computer begins to run slower as well, and for the past few weeks Photoshop has needed to be force quit because it freezes when I quit out of the application. Does anyone think reinstalling the program would help? This is my second install of this disc onto this machine, but when I got it reformatted, I missed a few programs during the uninstall. Will that impact my ability to reinstall?
    To everyone in this thread, it's little comfort, but you aren't alone. Maybe Adobe will figure this out soon.
    Mar 12, 2012 4:01 PM   in reply to JRJenny
    (A side comment first that these forums would benefit from being able to make a general reply, rather than to a specific post...unless I'm missing it somewhere.)
    Since my earlier post confirming that the "Suitcase fix" resolved the problem, it has cropped up again, but only rarely. Given the widespread nature of the problem affecting different users with different configurations, it appears that the Photoshop behavior described by Chris can be triggered by any number of scenarios. Adobe may not consider it to be a problem, and in fact may view it as a feature, even though for many users it is nothing but a nuisance. It appears to be something we have to live with until such time that Adobe either improves or fixes the "feature" and/or makes it something you can turn off.
    That's my pragmatic take on it at this point, with the real purpose of this post being to confirm that the Suitcase fix is not a complete fix, nor apparently even close to being one. It just removes one of the more common triggers.
    Mar 19, 2012 8:51 PM   in reply to caligula1
    Marian Driscoll & Chris Cox should take the same amount of time they have spent replying to all these posts and DO SOMETHING about this problem. Instead Ms. Driscoll likes to quote people's posts and make fun of them. I have been having this same problem since I upgraded my OS to 10.7 I hate this error! I run into it 10-20 times a day. It is up to Adobe to fix this problem! Do something please. I am not running a font suitcase or dropbox. FIX THIS!
    Mar 19, 2012 8:53 PM   in reply to LonnieSlowrider
    Adobe has done everything we can.  Every single time we've looking into this, we've found a cause outside of Photoshop.
    Not once have we found that this was caused by Photoshop.
    Unless you come up with a reproducable case that involves only Photoshop changing the files -- then there is nothing Adobe can do about this problem.
    The files are being changed outside of Photoshop, and the user needs to know that when saving to avoid losing work.
    Photoshop is doing the right thing here in telling you about an external change to your file.
    Something else on your system is doing something wrong by changing the file when you do not expect it to be changed.
    Mar 19, 2012 10:41 PM   in reply to LonnieSlowrider
    I think you have to trust that it is in Adobe's best interest to make the end users experience a positive one. Not addressing bugs in software works against that which ultimately leaves a bad taste in users mouths that negatively impacts Adobe's brand and product.
    If you look at several of Chris's posts, they have made an effort to try and reproduce the problem (eg see post 142) and so far haven't been able to where Photoshop has caused the error. You have to assume in good faith that if Photoshop was causing an error, Adobe would in good faith take responsibility and say "Yes, that's a problem, we are fixing it and we will update the software soon" because it's in their best interest to do so in order to create a positive experience for their end user.
    I can understand Adobes logic - if they can't find an error caused by Photoshop after faithfully testing and trying to reproduce the problem - and some people still have it - the next logical place is to look outside of Photoshop to see what might be causing the issue.
    My experience is that I started getting this error when I upgraded Suitcase. I removed the Plugin from Photoshop and haven't had the error since - and I use Photoshop daily. However I totally appreciate the frustration of those who continue to have this problem - it's annoying!
    I'm no mac expert but for those who have upgraded their OS or are experiencing disk related write errors, perhaps look at using a disk tool to check disk permissions and disk integrity first before posting to make sure none of those are at fault. I usually use Apple's 'Disk Utility' after booting from an external MacOS DVD to check permissions  - but others might be able to suggest a better practical piece of software for this task?
    Some people have also indicated RAM might be an issue for them as well. A google search indicates that Memtest is a solid programme for testing that - which I have never used - but again, others may be able to suggest other software for this task.
    Failing that - perhaps Apple has introduced something in OS 10.6 and 10.7 that violates file permissions that needs resolving? How can we explore that avenue to see if there is not an issue there? I assume Chris that you have already explored this avenue as part of Photoshop testing procedures? What outcomes have you found please?
    Does anybody else have suggestions for ways we might be able to test external influences for the cause? Chris - can you help with this? Are you able to bring your testing  experience to the table please. It might help alleviate some frustrated users and most certainly would bring a positive reflection on yourself and Adobe if you can help out at this level thanks. All help is appreciated and I'm sure would be rewarded in positive feedback to yourself and Adobe.
    Mar 19, 2012 11:04 PM   in reply to Planet Frog
    Short of borrowing someone's system who sees this regularly and debugging it there, I'm not sure what else we can do.
    (and we've done that in the past - which is how we found some of the known third party culprits)
    Mar 20, 2012 12:05 AM   in reply to LonnieSlowrider
    And what is Marian supposed to do? Have I missed her having become an Adobe employee?
    And you seem to have failed to understand what Mr.Cox has graciously taken the time to state – just because you think Adobe is at fault that may not be the case.
    That you are having this problem since upgrading the OS might have served as a clue in that regard …
    Mar 20, 2012 1:58 AM   in reply to Chris Cox
    I'd say the best you can do Chris is post any results from your findings that may be helpful.
    But also, from a practical point of view, if you have any further suggestions in terms of 3rd part utilities that might help others isolate and resolve some of the more common issues before they post - such as network tools, disk utilities or whatever, those things could help?
    The other thing I'd request is that if during debugging you do see that it is a MacOS related issue - can you say so please as this will help re-focus direction towards meeting a resolve from that end of things. Some of your earlier posts suggested you saw OS activities that seemed like they shouldn't be happening (post 64) and the number of folks posting that say they experienced the issue after upgrading to Mac OS 10.6 or 10.7 supports possible OS issues, so if it is confirmed - it dictates the next course of action. Saves people reinstalling a fresh system only to find the same thing happens again as some have already done.
    What else do you want/need from us users that might help find the cause?
    Mar 20, 2012 3:36 AM   in reply to LonnieSlowrider
    And now here I am making fun of your silliness for failing to fully read and comprehend this discussion and the many other discussions that have appeared on this forum regarding OS X's silly way of meddling with files.
    How is it that you did not encounter this error prior to 10.7? Why is it that others experienced it on earlier systems? Is this because Chris and others are entirely correct in saying that the problem involves unique settings to your system?
    Why do you assume it is Adobe's fault now that you have upgraded Apple's software? It is this kind of detachment from reason that makes Adobe's job that much harder in trying to help you troubleshoot your problem.
    Mar 20, 2012 3:49 AM   in reply to Marian Driscoll
    Are you asking the person to process information even if it is at odds with their preconceived notions?
    Mar 20, 2012 4:02 AM   in reply to c.pfaffenbichler
    Yes. I am the world's biggest fool for assuming that others might think intelligently.
    lizard.jpgAt least in the US, schools no longer teach the scientific method. There's not enough time in the day after teaching about Jesus riding dinosaurs.
    Mar 20, 2012 5:07 AM   in reply to Marian Driscoll
    I have to ask … did you do the montage or are there really publications of that kind somewhere out there?
    Mar 20, 2012 9:28 AM   in reply to c.pfaffenbichler
    It is not my own work. We US hillbillies sell t-shirts with Jesus riding a T-Rex.
    http://www.zazzle.com/jesus+riding+a+dinosaur+tshirts
    We even devote entire museums to lunacy:
    https://krishashok.wordpress.com/2010/08/18/kentucky-fried-creation/
    Mar 20, 2012 6:20 AM   in reply to caligula1
    I get a similar message, not in Photoshop or in Lion (I'm still on Snow Leopard), but it is entirely Adobe generated, reproducible and may possibly have a related cause, so I'll relate it FWIW.
    I get the message (somthing to the effect of 'file has been modified by an external application' etc) in Lightroom after using Photoshop Elements as an external editor to edit the file - in one particular circumstance.
    Normally there is no problem, the two programs talk to each other properly and the file is saved in Lightroom OK, with no message.
    The problem arises when I quit Photoshop Elements while the photo in question is open and unsaved. I then am prompted to save, which I do, and Elements immediately closes. But apparently there isn't time for it to talk to Lightroom with all the info, and that's when I get the message when I return to LR. I usually accept the changed file if I can decipher which version the one I was just editing was.
    I have a relatively old computer (2006 iMac) and wouldn't be surprised if the speed of writing to disk had something to do with this, so am not looking for a solution or "helpful advice" for my problem here! I'm just chipping in in case other people may be using Lightroom or hitting close/quit then save.
    Mar 20, 2012 6:27 AM   in reply to mac gabe
    I can recreate the problem if I alter the metadata in Bridge, for example "starring" an image, but I wouldn't consider this a problem, it's doing what it should be doing.
    for those people that see this problem often and it's a problem, can you simply "save as" the file that you have open in PS and then inspect both files? other than the obvious changes to the modification dates/time, image changes etc, wouldn't this point you in a direction to see what has changed?
    Mar 20, 2012 6:58 AM   in reply to - JM -
    The file change can be as subtle as a preview icon being added in Finder.
    Mar 20, 2012 7:12 AM   in reply to Marian Driscoll
    That's exactly the problem. It's routine, innocuous stuff like that that is 'at fault.' the kind of stuff that scores of good software developers have been able to work around. The kind of stuff that keeps track of your backups and shows you a current snapshot of your work, the kind of stuff that actually enhances a user's experience.
    Heaven forbid you would try to use Photoshop in a professional setting where you have to share files with other people... If they look at a folder containing a file you have open, Finder touches the file to generate a preview and you get that error. There still exists no stable solution for users sharing files. Adobe abandoned their pathetic excuse of a solution known as Version Cue, so now their support is laughably non-existent.
    Personally, I'm going to have my retouching staff experiment with different file formats-- tiff has numerous advantages over PSD-- perhaps it will yield fewer errors. Anyone gone down that road?
    //iPhone
    Mar 20, 2012 7:14 AM   in reply to Marian Driscoll
    I understand, but why not rule out what they can, if we make too many assumptions we will only know, what we already know.... back to your original request for scientific method of observation. The following is likely to be flawed and not capture all possibilities but it's an attempt.
    1. create 2 identical PSD files
    2. work on the original
    3. if you haven't saved the file since you have created the duplicate file and you get a "file has changed..." message, do a "save-as".
    this should yield 3 files, your original, the duplicate and the save-as version.... compare everything
    Mar 20, 2012 7:33 AM   in reply to james_mckenzie
    james_mckenzie wrote:
    That's exactly the problem. It's routine, innocuous stuff like that that is 'at fault.' the kind of stuff that scores of good software developers have been able to work around...
    Adobe did demonstrate the ability to work around this in regards to Windows when they stopped shipping the DLL that handled PSD previews in Explorer. This happened several versions back. While there were different reasons involved, it illustrates a difference in how Explorer and Finder handle image previews within the OS. It is not so easy to tell Finder to stop making previews. People like to see those icons.
    And to further critique Apple's Finder nonsense... Check out this illustration of the Finder going wonky with filesizes. There is only so much a developer can work around.
    http://forums.adobe.com/message/3638147#3638147
    Mar 20, 2012 7:36 AM   in reply to Marian Driscoll
    We actually do agree on something-- people do like those icons. They're a crucial part of a good user experience. But I think your approach is all wrong-- which is exactly what I've been trying to illustrate. The answer is not to have photoshop prevent Finder from making previews-- that's a lose/lose. The answer is to accept the fact that other programs, in fact core services WILL touch those files. And move FORWARD. Good developers will adapt to that. Adobe's monopoly in this market has made them somewhat big and lazy, and it's turning them into bad software developers.
    //iPhone
    Mar 20, 2012 8:05 AM   in reply to james_mckenzie
    ...The answer is to accept the fact that other programs, in fact core services WILL touch those files. And move FORWARD....
    There is the engineering problem. We pass graphics files between multiple programs. A PSD file will be linked and updated through integration with InDesign... or Illustrator... or After Effects. A PSD file will be linked and updated as a smart object even within Photoshop. We absolutely need these checks to alert us when a linked file has been changed. So it is an engineering problem to turn off (or develop some workaround to) this alert prompt. The prompt is useful. The choice in the one platform that is affected by this may not be so useful.
  • Noel Carboni
    Dec 23, 2006
    Mar 20, 2012 4:46 PM   in reply to Marian Driscoll
    Who deemed it okay for an operating system to modify a user's files?
    I was in a discussion just the other day about how Windows now feels it's okay to delete icons off the user's desktop if it feels they're broken.  Trouble is, broken right now, at this moment, doesn't equal not broken when the laptop was plugged-into the corporate net, or whatever.
    It's just the next step toward us becoming slaves to computers.
    -Noel
    Mar 20, 2012 8:32 PM   in reply to Noel Carboni
    The OS has no business interfering with content.  If that's what's happening that'd be pretty disappointing, but somehow it doesn't surprise me.  With this love on the market has for apple they probably think they can't do any wrong. Still, users shouldn't be expected to have to figure this out, how hard can this be to solve?
    Dave
    Mar 21, 2012 3:56 AM   in reply to drstudio
    I'd have to agree with you there. If the MacOS is modifying files for whatever purposes that's causing a change to the actual file - then really the MacOS needs to be functioning impartially towards files with the creation of any data associated to the file, not embedding it. In which case that would be one explanation as to why Photoshop gives the warning that the file has been modified. And rightfully so.
    Chris - in the testing you mentioned (post 176) are you able to isolate that as a possible cause? If so, we are in a position to present fact to Apple so they can look at alternative methods in terms of how files are managed within the OS.
    As a flip side to that - Marian's Link in post 189 would suggest that the OS lies about document size values in which case the actual file is supposedly not modified (at least that's how I read it). Is it possible that Photoshop is currently picking upon MacOS finder data that can essentially be ignored so as to give a true representation of the file size and creation date?
    One thing I'd say about your post Marian is that the way it was presented suggested that the Finder is somewhat 'random' in what if does and does not add file size to. sometimes it behaves, some times it doesn't. That being the case it may explain why some users get the error and others don't (for whatever reason that might be??!!). Just a theory though. we need facts really to be able to move forward on this issue. Chis, can you help please?
    Mar 21, 2012 8:55 AM   in reply to Planet Frog
    We haven't seen MacOS change the dates on files -- but then we haven't reproduced the problem ourselves without the presence of third party software causing the changes.
    We suspect that some configuration of the OS might do that, but we haven't seen it.
    Photoshop doesn't read Finder data, but calls the lower level file access APIs to get file information.  If those aren't correct then something is really, really busted.
    Yes, if there was something that triggers the OS to get out of sync on file information - that could possibly explain the problem. We do know that MacOS 10.6 and above have problems with inode structure management that leads to disk corruption and crashing on some systems (usually fixed with Disk Utility) -- but we don't know the full details, so can't tie that directly to this.
    Really, we need a reproduceable case to figure out what's going on.
    Mar 22, 2012 1:27 PM   in reply to caligula1
    Hello,
    just wanted to chime in and say I've encountered this annoying behavior since a few weeks. I can't imagine what has caused this bug, no spectacular changes to my system (at least none that I'm aware of). This thread hasn't been very enlightening for me so far… I'm using CS5 and Snow Leo, no extensions, no Suitcase, Dropbox, Spotify, whatever else has come up as possible error sources.
    What I ask myself now: could these messages be a sign of a damaged or dying hard drive? Because my hard drive seems to "working" more than necessary (by that I mean the reading/writing noise) and I believe I always get the message while the HD is busy. Oh, and also when the interval between saving the document is rather short, like less than 2 minutes or so.
    Mar 22, 2012 2:00 PM   in reply to AnnaStesia1632
    Anna, your experience summarizes exactly what I've been experiencing.The behavior has started despite major changes to my system.
    However, I doubt the hard drive is damaged or dying, because a) it would affect more than Photoshop, and b) other people would report hard drives dying in this thread.
    On the other hand, a busy HD does back up what Chris has been claiming on this thread: That some other program is overwriting the PS files.
    I tried intentionally re-creating the error this week, but have been unable to do so. If I can make time to try again, I will post results on this thread.
    Mar 22, 2012 3:53 PM   in reply to AnnaStesia1632
    Anna, if your hard rive is working overtime, it would be wise to run Apples Disk Utility as soon as possible in case the drive is failing.
    My experience is there are usually 2 main reasons a drive starts working overtime when you're using Photoshop;
    The first is if you use your main boot drive also as a Scratch Disk for photoshop (the same one the operating system is installed on) and the drive starts getting full, or the data on the drive starts getting spread all over the place - then photoshop has to work the drive really hard to find places it can read and write to. It also makes the system a lot more vulnerable to producing disk related errors.
    The second is the drive is starting to fail and needs replacing!
    My experience also is a drive can be failing and you may not even know it. A while back I ran Apples Disk Utility across one of my drives that I use often that appeared to be working fine, and it was actually starting to fail, so you don't necessarily know it's happening till something big goes wrong because some drives have built in error correction that hides it. It can start with small sector errors on the disk that can turn into a big disaster over a period of time! The worst part is if you have been backing up to time machine and the errors started a long time back, Time Machine duplicates the errors to backup, so it's best to store time machine drives when they get full instead of letting old files get over written if you can afford to. I have a removable drive case so I just pull out the old drive and put in a new one. HD's are getting cheaper now so it's become more affordable.
    The thing with Photoshop is it is a very disk intensive program because often you can be working with big files and Photoshop is scratching data to the Hard drive a lot - so it's probably one of the fist programs that can show errors at a disk level. And for the same reason you may not see the errors in any other software because other programs often don't use the disk as much.
    It's also a very good practice to have a complete separate hard drive partition set aside purely for Photoshop to use to read and write to while it's working (a 'scratch disk') as it reduces load on the system and gives both much stronger system and performance stability.
    If you have never used apples Disk Utility before, reply to the post and I'll give you instructions.
    If you don't have a separate partition set up at the mo, say so and I'll give some advice to get it done easily.
    Also - can you remember installing ANY new software or plugins in the last few weeks before the error started. Think hard because it could give us a clue if that is the cause. Or alternatively - did you do anything at a system level that was a big adjustment?
Actions
