What are JDI features? They're "Just Do It" features: small features that don't take a lot of time to implement or test and seem like an obvious improvement.
Here is a list of the JDI features in Photoshop CS6, by category:
Automation
- Contact Sheet II has been restored as an Automate option
- PDF Presentation and Layer Comps to PDF have been restored as Automate options
Brushes
- Add ability to record brush strokes in actions with "Allow Tool Recording" option
- Brightness/contrast slider for textures when painting
- Brush projection for static tips
- Brush tip cursor reflects brush pose and jitter for round and captured tips
- HUD brush resize and hardness can now change opacity - [Control] + [Option] + click drag up/down with General>Preferences> "Vary Round Brush Hardness based on HUD vertical movement" unchecked
- Increase maximum brush size to 5000px
- Change color dynamics to per stroke instead of per tip (user option for old behavior)
Channels
- Enable Split Channels for documents with single layer (so you can split simple transparency)
Color Picker
- allow clipboard paste into hex field with # in contents (i.e. #aabbcc), or 0x (i.e. 0xAABBCC)
- allow shortcut hex values (i.e. #123)
Eyedropper
- Add ignore adjustment layers options bar item for the eyedropper
- New mode for eyedropper to select layers current and below
- Show the sample size popup for the various eyedropper tools (black point, white point, etc.)
File Formats
- Allow for reading more bit depths in TIFF files
- Give the user choices regarding how they want transparency treated in OpenEXR on file open and save
- Read BIGTIFF format (TIFF files over 4 Gig)
- Read common stereo image pair formats (JPS, MPO, PNS)
GPU
- Increased GPU stability by prequalifying GPUs on the fly before use
Grammar
- Grammar policed throughout app
- Use consistent grammar style in the title of dialog windows (no commands such as "Choose a color:")
Image Resizing
- Auto-select the best resample method based on the type of resize (bicubic-automatic)
Importing
- (Macintosh only) Import images from devices provides ImageKit scanning and camera acquisition support
Layers
- Add bicubic sharper & bicubic smoother options when free transforming layers (menu in options bar)
- Add dither options to Layer Styles for Gradient Overlay and Gradient Stroke
- Allow 00 or Shift 00 to work when setting layer/fill opacity (previously no way to get 0%)
- Allow changing color labels on multiple layers at once
- Allow changing of blend modes for multiple layers at once
- Allow locking of multiple selected layers
- CMD+J to duplicate selected layers and layer groups (in addition to layers)
- Layer tooltips to include layer name (if defined)
- New command to rasterize layer effect into layer, merging the selected layers into themselves (Rasterize Layer Style)
- Opt+click on toggle arrows (groups and effects)in layer panel should close all targets
- Reorder effects in the layers palette to match the Z-order style/blend mode (bottom most effects in terms of blending order, drop shadow is below the other effects)
- Show blend if/Blending Effects badge on layer if they are not default values
- Show correct opacity and blend mode values for hidden layers
- Tab goes to next layer on inline layer rename, SHIFT + TAB goes to previous
- When creating a shape layer, the layer name should not be like "Shape 1" but instead reflect the tool named such as "Rectangle 1"
Liquify
- Add option to load last mesh
- Increase maximum Liquify brush size to 15,000
- Resize Liquify brush with shortcuts: bracket keys [ ] now match same increments in Photoshop
- ctrl (win) / cmd (mac) switches to magnifying glass
- alt + right click + drag to change brush size (win)
- ctrl + alt + left click + drag to change brush size (mac)
Masks
- Enable Invert and Threshold adjustments for masks in 32-bit/channel
Plugins
- Hold SHIFT during startup to disable Optional and 3rd party plugins
Presets
- Add New Document presets for common devices (e.g. iPhone, iPad, etc.)
- Add new Gradient Map presets for traditional print toning and split-toning
- Sticky reorganization of tool presets (changes persist after relaunch)
- New HDR Pro presets from RC Concepcion and Scott Kelby
Printing
- Add "Edit" button for the description field in the print dialog
- Allow print dialog and print preview window to be resized
- Allow user to change the "preview well" background color in the print dialog
- Allow user to manually position the printed area on the page
- Hide color profiles that are inappropriate for currently selected printer when using "Photoshop Manages Color"
- Reintroduce "Print selected area", allow user to modify selection in print dialog
Save
- Add warning message that 16-bit images cannot display their file size in the Save as JPEG dialog
SDK
- Add ability to access tool name associated with the tool preset name via scripting
- Add the ability to return an array of guides in a document from the scripting SDK
Selections
- Make the marquee, lasso, and mask panel feather values support decimal places like the feather dialog
- Remember feather radius when showing dialog for selection from a path
Transform
- Don't hide smart object icon when transforming a layer
- Improve dragging of vector curves
- Rotate 90 with even x odd pixel dimension to not land on a half pixel position
- Preference to disable auto-rotate on open
Type
- Add command to insert "lorem ipsum" for type
- Added Gamma rendering parameter for better text rendering
UI
- [Windows] New/open document to context click on a document tab (has always been on Mac, now Windows too)
- Add "Don't show again" checkbox to Purge warnings
- Remove the app bar and reduce the drag/app bar over 30%
