I am trying to embed 'GillSansStd' font for Samsung smart TV flash application. It looks good on local build and Samsung emulator. But when the application is deployed on Samsung smart TV, text gets blurred and distorted.
Does someone out there also facing/faced similar issue? Any help would be appreciated.
How distorted are we talking about?
TV's often use a filter on the image to make things look better. It is possible that this is causeing the problem. You may want to try the contrast and color settings on your TV to see if that makes it better.
When using text on TV there is 3 things you should remember.
1. Your app is most likely scaled up. Your TV probably uses a larger resolution than what your app is doing. It is common for TVs to give apps a smaller screen size and scale it up to increase performance (this doesn't apply to video).
2. Use LARGE font sizes. People reading your app are probably far away on a couch. Make sure that the font is nice and large (this may also make it look better).
3. Make sure your TextField is on a pixel boundry. Flash handles sub-pixels, but TV's often don't. Anti-aliasing is often quick and dirty (again for perfomance) so putting it on pixel boundries should help it look better.
Thanks John, for having a look at my problem and sharing your thoughts and suggestions.
Actually my problem is as follows:
I am developing flash application for 'Samsung Smart TV' in actionscript 2.0. Currently I am using text with font-embedding and font is '_sans'. Text presentation on local emulator and on Samsung TV is similar with normal quality.
Now I have to use "Gill sans std" font for all the text in my flash application. I tried by embedding the font in .fla file. Output displays nicely on local build and on Samsung emulator. But it gets blurred, when I deploy it on the 'Samsung smart TV'.
I have attached the screenshot of both the scenario's(one as in the emulator and one in Samsung smart TV) for comparison. Please check the text "Blacks Tutorialsq" in following screenshots.
Please feel free to share your thoughts on this.
Hello Sanjiv,
I had developed application in Flash builder 4.6 and I have created .airi file of application and rename .airi to zip and after unzipping I got .swf file in that unzipped folder.
Now I had created sample flash application in SamsungSmartTV SDK editor in this application I had give n path of unzipped folder's swf file and run the application on Emulator but in emulator Fonts of respecive .mxml file is not loaded properly.
Can u please help me why respective fontof MXML fiel is not loaded in the SWF file.
Thanks in advance.
Waitng for your reply.
Sachin
