RDS error after installation
Feb 22, 2012 12:35 PM
Tags: #rds
Just installed CF 10 beta on Win 7 32bit and Apache 2.2.22. No errors detected on install or startup. RDS  selected to run in Admin.
Running files locally in FF, Deramweaver and CFB 2beta and everything looks like it is working fine.
However, trying to connect to RDS is not working.
In Dreamweaver 5.x, trying to connect gives the following..
"The server name or address could not be resolved. Possible reasons:
     1. The URL specified for this site's testing may be incorrect.
     2. The testing server may be incorrectly configured. e.g. CF may not be running"
CF files run fine inside and outside of DW. The URL is correct too.
In CFB 2 beta, I also get an error in RDS Configuration when hitting the test button.
'Unable to contact the RDS Server "localhost". This can be caused by incorrect configuration on either the client or the server.'
Please verify your connection ... blah blah blah.
The HTTP request to talk to your server returned with the following message: 'Could not initialize class com.adobe.rds.core.services.Messages'
Localhost is set up as local port 80, selected CF+Tomcat.
Document Root = c:\inetpub\wwwroot
Server Home = c:\coldfusion10\cfusion
I feel like I'm missing something, soI tried uninstalling CF10 and reinstalled CF9. Both DW and CFB correctly connected to RDS when I set it up. RDS Dataview and RDS Fileview both worked correctly. Uninstalling CF9 and reinstalling CF10 resulted in the same errors. RDS did not work.
What am I missing?
Doug
    Feb 22, 2012 9:04 PM   in reply to PegasusT4
    Hi Pegasus,
    Can you please confirm if RDS service check box in enabled in Administrator -> Security -> RDS
    Shilpi
    CF engineering Team
    Feb 23, 2012 9:55 AM   in reply to PegasusT4
    Doug,
    I tried again with CF10 with and without apache connector. I get the mentioned error if RDS service is disabled, (on RDS screen in Administrator). If the service is enabled, with RDS username and password, it is working in both CFBuilder and component browser. Is there any stack trace or error you see in error logs?
    Try toggling the RDS Service button once more and see if it works. Also your CF server, JRE used and apache all 32 bit, or there is a difference?
    If the issue still persist, i request you to please file an issue in https://bugbase.adobe.com/. We will look into this.
    Shilpi
    Feb 23, 2012 9:41 PM   in reply to PegasusT4
    Hi Doug,
    We are not able to repro in our installtion of standalone and plugin configuration. Can you please extract the RDS Core plugin(com.adobe.rds.core_*.jar) check for the class com.adobe.rds.core.services.Messages.class.
    Also check the password in your RDS settings at ColdFusion Administrator and ColdFusion builder server configuration dialog.  You can reset your RDS password, using passwordReset script located at <cf-home>/bin. This will eleminate possiblity of any configuration errors.
    Also check regstering the other remote server and try accessing the RDS for the same.
    Shilpi
    Feb 24, 2012 9:59 AM   in reply to PegasusT4
    Doug,
    In the CF builder installation directory, there will be plugins directory. In this there will be a file with .jar extension and name as com.adobe.rds.core_1.0.2.v20100601277104.jar. Note the numer after com.adobe.rds.core might be different.
    Now you can open this file with Winrar. There look for directories in the mentioned order -
    com -> adobe -> rds -> core -> services -> Message.class
    If the above mentioned class is present in the jar, we are good
    Shilpi
    Feb 24, 2012 3:37 PM   in reply to PegasusT4
    You can check RDS by using the URL http://<yoursite>/CFIDE/componentutils/packagelist.cfm
    This will ask for your RDS authentication. After entering username and password, see if the components list comes or not?
    Shilpi
    Feb 25, 2012 6:23 AM   in reply to PegasusT4
    Doug,
    This is really helpful. This might be able to point us to somewhere logical. Can you please log an issue for this at https://www.bugbase.adobe.com
    The stack trace is what is important here. We will look into this.
    Thanks once again,
    Shilpi
    Feb 27, 2012 6:45 PM   in reply to PegasusT4
    Thanks for confirming Doug.
    Mar 8, 2012 10:50 AM   in reply to PegasusT4
    Thank you for posting that Doug!!!!!!
    I was about to go crazy and you supplied the answer .. also I am on a 24+ hour working binge so I think I may need to go to bed soon .. LOL.
    Mar 9, 2012 3:13 AM   in reply to PegasusT4
    I have the same problem of PegasusT4, but my server is IIS7.
    Any idea?
    perico
    May 21, 2012 12:56 AM   in reply to PegasusT4
    Awesome fix guys, got me out a hole there !!
Bookmarked By (1)
