I've installed the CF10 beta with IIS 5.1 on Windows XP Pro. The CF10 Application Server service will not start.
Is there anything I can do? Or is this by design?
Thanks.
Carl,
Trying to start CF from the command line yielded this error message:
"This application failed to start because msvcr71.dll was not found. Re-installing the application may fix this problem."
I've even tried formatting the drive, reinstalling Windows and CF, but I still can't start the service.
Any other suggestions? I'm going to try to run it as a standalone server and hopefully that'll do it.
Thanks.
Same exact thing happened to me. I installed CF10 beta on a 32-bit Windows 7 Guest OS inside of MS Virtual PC 2007 sp1 and the CF application service would not start. I ran the cfstat.bat file directly from a command prompt and received the same exact warning: MSVCR71.dll could not be found. I did a Google search for MSVCR71.dll and it brought me to: http://www.addictivetips.com/windows-tips/fix-msvcp71-dll-and-msvcr71- dll-missing-error-in-windows-7/
I downloaded the dll and placed it in the Windows\System32 folder. I then went to services and started the CF Application server. I then completed setting up my CF10 beta installation without any additional issues.
I wanted to confirm that the same held true for Windows Server 2003 32 bit. I got the same error and placing the dll in the error message in the Windows\System32 folder worked. It started up just fine.
HTH someone.
