cnitski
CS5 - Adding Notes
Feb 24, 2012 9:13 AM
I just recently found out about the "Adding Notes" feature in CS5.  I was able to add notes.  However, when I saved the photo as a jpeg, and then re-opened it - the notes were not there.
Am I doing something wrong or will notes only re-appear when the photo file is saved to a psd or tif?
  • Noel Carboni
    Dec 23, 2006
    Feb 24, 2012 9:20 AM   in reply to cnitski
    Apparently Notes cannot be saved in the Metadata of a JPEG file, though I hadn't noticed that before.
    See that the Notes setting has a warning icon by it in the Save As dialog when trying to save the JPEG.  That's Photoshop telling you it can't perform that function for the given file type.
    -Noel
    Feb 24, 2012 9:49 AM   in reply to cnitski
    Are you on a Mac?
    You can do: Command + i  and place your comments in the "Spotlight Comments" window.
    Feb 24, 2012 9:57 AM   in reply to RenéG
    RenéG wrote:
    …place your comments in the "Spotlight Comments" window…
    …which should really be called "Finder Comments" window, as it used to be.  Spotlight is not needed to add or to read such comments.  The Comments window is available even when Spotlight is disabled permanently.
    Feb 24, 2012 10:12 AM   in reply to cnitski
    cnitski wrote:
    I hit command + I in photoshop and it just inverted the picture.  I see that I must add the comments via Finder on the iMac (which I do have).
    Yes, via the Finder. Glad you figured that out.
    Feb 24, 2012 12:04 PM   in reply to cnitski
    What about using File>File Info>Description tab?
    Feb 24, 2012 12:16 PM   in reply to cnitski
    cnitski wrote:
    R Kelly ... AWESOME ... that works.
    Be careful with that one. If you use "Save for Web & Devices" to create your JPEG, be certain to check "Include XMP" otherwise those comments will get erased when you save your JPEGs.
    Feb 24, 2012 12:19 PM   in reply to cnitski
    You can somewhat save your steps by turning on the History Log under Photoshop>Preferences>General.
    Then if you choose metadata, the history is listed under File>Info>History.
  • Noel Carboni
    Dec 23, 2006
    Feb 24, 2012 12:34 PM   in reply to cnitski
    cnitski wrote:
    It would nice if I could electronically pick up the history
    Try this on for size:
    1.  In Photoshop, click Edit - Preferences - General.
    2.  Check the box for [  ] History Log.
    3.  Choose the Save Log Items To: (  ) Metadata radio button.
    4.  Set Edit Log Items to Detailed.
    Voila, all your editing steps are now saved in the metadata of the file.
    Edit:  R_Kelly, you beat me to it!
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Feb 24, 2012 1:13 PM   in reply to cnitski
    Yes, JPEG images will carry the history log information in the metadata.
    Be mindful of the side effects of storing the editing history in the metadata, though... It's not hard to imagine accumulating many kbytes of metadata because of having done a lot of editing, then having all that extra metadata cause an image that's intended to be small for web display to be much a larger file on disk than you want it to be.
    -Noel
