Alex DeJesus 430 posts
Jul 25, 2008
Anyone using Areca 1213-4i RAID controller?
Feb 23, 2012 11:11 PM
Tags: #areca #raid #matrox
I have the i7-2600K and the ASUS P8P67 Pro motherboard and still having a heck of a time getting good performance from my drives. Considering a 3rd party RAID controller. Currently have two RAID 0 (2 disks each SATA 6G) internally. One for capture storage and the other for previews/pagefile. One concern is the Matrox MX02 Mini is taking up the only available PCIe slot. And, is $360 a decent price?
    Feb 24, 2012 1:08 AM   in reply to Alex DeJesus
    First of all, I can't find the 1213-4i. I see the 1210, 1220, 1231, 1261 etc.
    A couple of drawbacks with the 12xx cards. It uses an older IOP33x processor, has only 256 MB cache, only supports SATA 300 and not SATA 600 and requires a PCIe slot, which reduces the speed of your video card even further. Your mobo has only 16 PCIe lanes available, the Matrox uses 1 lane, your video card uses 8 lanes currently instead of 16 lanes without the Matrox, and by adding the Areca will run only on 4 lanes. This is the major obstacle of the 1155 platform, not enough PCIe lanes, and testing has shown that the performance degradation of using only 8 lanes for the video card instead of 16 results in around 10 - 15% performance loss when using the MPEG2-DVD test in our benchmark. You can avoid further performance loss by removing the Matrox and adding the Areca, since then both cards can use 8 lanes.
    Feb 24, 2012 8:15 AM   in reply to Alex DeJesus
    Does your board have the Intel raid controller? If it does you have to enable it in the BIOS and the easiest way to set it up is using the Intel Matrix Storage Controller utility found on your MB disc or from the Intel website.
    Richard Knight
    Feb 24, 2012 8:34 AM   in reply to Richard M Knight
    Richard,
    The onboard Intel controller is not good in RAID 5: The performance degradation with that software RAID 5 is quite severe (at least two to three times slower than a single disk, and sometimes five or six times slower than the single disk) in the Disk I/O test in the PPBM5 benchmark. The onboard Intel controller is really only good in RAID 0 ("aid0"), RAID 1 or RAID 10.
    Feb 24, 2012 9:52 AM   in reply to RjL190365
    Having just set up a system with two RAID 0 arrays, one on the Intel X79 controller, the other on an on-board Marvell 88SE9172 controller, it seems to me that neither is up to much.  The PPBM5 disk in/out test takes virtually the same time on either array - 460 seconds.
    This has made me realise how the PPBM5 rank order is skewed in favour of RAID 5 arrays on external controllers, as anything less takes a disproportionate time on the disk in/out test.  The other tests are far less affected by inferior hardware.
    Feb 24, 2012 11:10 AM   in reply to Alan Craven
    Alan,
    Those extremely long disk I/O times indicate that you may have a problem with proper tuning. For example, you might have far too many background processes going on in your system.
    By the way, with my particular i7-2600K main rig with the P8P67 Pro motherboard, I consistently got just under 60 seconds in the Disk I/O test with one two-disk RAID 0 array (or one of the arrayed pairs) connected to the onboard Intel SATA controller. The overall total time in CS5.5 of around 230-ish seconds is clearly caused by my system's particular GTX 470, which resulted in a time of around 110-ish seconds in the MPEG-2 DVD test.
    Feb 24, 2012 11:14 AM   in reply to Alan Craven
    Alan,
    I agree with Randall. Those results are way off. Did you turn off indexing and compression on all of your disk volumes? Did you turn off all anti-somthing stuff? With 2 x raid0 you should be in the 60's range.
    Feb 24, 2012 11:50 AM   in reply to Harm Millaard
    Harm,
    In addition to what I stated above, even my budget i5-2400 auxiliary rig produces a result of around 80 seconds in the Disk I/O test in PPBM5. And that's with only 8GB of RAM installed in that system. I could shave some more time off of the MPEG-2 DVD result on that system by upgrading the total system RAM from 8GB to 16GB since the 153-second time is par for a non-Ti GTX 560 on an i5-2xxx system with such a relatively low amount of system RAM.
    Feb 24, 2012 12:11 PM   in reply to Alex DeJesus
    SSDs that are not in a RAID array are automatically run in AHCI mode with the Intel controller set to RAID.
    Feb 24, 2012 12:50 PM   in reply to RjL190365
    Randall, Harm,
    I have turned off everything On Bill Gehrke's list, plus everything on the old Edius list, plus some others on the Black Viper list.  The only downside from Harm's viewpoint is the Matrox MXO2 that is installed, but this is not used in PPBM5, so can it still slow things down as is alleged?
    On the other two tests the system matches the first X79 system in your chart.
    One thing puzzles me greatly about PPBM5 - everyone knows that you need to have two, or better three disks in addition to your OSD drive, yet PPBM5 has project file, assets, Preview files, media cache, and exports all on the same drive?  Or have I completely mis-understood the instructions?
    My own current project has project file on a single drive (D), captured video on the Intel RAID 0 (E), Media Cache and preview files on the Marvell RAID 0 (F) and export files on a single drive G.  The two AIDs are backed up to an external eSATA drive.
    The other thing that puzzles me is the set up of the RAID.  I enabled the RAID in BIOS, switching from the default ACHI, but when I arrived in Windows, it seemed that I still had to format the drive.  This makes me suspect that I actually have a software RAID, rather than the intended Intel/Marvell controller RAID.
    I think that this paragraph touches on where Percoplus is coming from in post 10.
    Could you enlighten us both here, please?  My feeling is that setting up the RAID in BIOS should be it, one should not have to format the drives in Windows.
    Percoplus,
    I hope you do not feel that I have Hijacked your thread - I think we are both in the same difficulty here.
    Feb 24, 2012 2:28 PM   in reply to Alan Craven
    I have just checked the Marvell Storage Utility.  the two drives are not shown as a virtual disk.  I think that both my supposed AIDs are actually just single volumes spanning the two disks, which explains their poor performance.  This is the situation described by RjL in post 11.
    Percoplus,
    I have gained more insight into this by using Google, which found me guides to setting up RAID on both the Intel and the Marvell controllers.
    Intel : http://ftp://asrock.cn/manual/raid/H67M-GE/IntelRapidStorage/English.p df
    Marvell : http://ftp://asrock.cn/manual/raid/X79%20Extreme9/MarvellSATA3/English .pdf
    My mistake asppears to have been to format the RAID arrays in Windows Disk Manager rather than  initialising the array.  I think this answers your queries in posts 10 and 12.
    With luck Harm , RjL, or someone else who knows what they are doing will come along and confirm  my suspicions.  At least I have my external backup, so that I can, like you, start afresh.
    Feb 25, 2012 4:05 AM   in reply to Alan Craven
    The links you provided do not work.
    Setting up a raid means you have to define the raid configuration in the BIOS first. Then after starting up Windows, you have to go to disk manager and format the disk. Take note of the following article too: Adobe Forums: How to access more than 2 TB of disk...
    Feb 25, 2012 4:29 AM   in reply to Harm Millaard
    Harm,
    I discovered the links problem too late, and of course I cannot edit. The initial http:// should not be there, it was added automatically by the forum software.
    The process you describe is what I did.  In the Intel RST guide it says that, in Disk Management you will be asked to initialise the disk before you can access it.  Having clicked OK, you should R click  on Disk ) and click "New Simple Volume" and then follow the instructions in the wizard.  That is not what I did.
    Thanks for the help.
    Feb 25, 2012 7:30 AM   in reply to Alan Craven
    Yes, do not know why but we have seen the effects from many users.
    Early PPBM test we did have it set up to allow some flexibilty in PPBM file locations, this caused major confusion from users so we simplified it to having all files in one location.   If you put all the files on the fastest disk or array it is a faster result than say a RAID project disk and exporting to a single disk drive.  If you really want to use a seperate drive or array you can CUT the output files and Paste them to the project location to make the script work.  Notice I said CUT as copy will end up changing the file created/modified times and will not work.
    Not true.you have to format after setting up in the BIOS
    Also be aware that you cannot easily go into the BIOS and switch back and forth between IDE, ACHI and RAID after installing the OS
    Feb 25, 2012 7:52 AM   in reply to Bill Gehrke
    Thanks Bill, for that.
    I can  see the point in having a standard arrangement of the files.
    I had discovered from the User Guides that I found, that you still had to format the volume.  I set the Intel controller, and one of the three Marvell controllers to RAID from the default AHCI before I started installing Windows.  I had read about the switch back and forth problem before I started the assembly.  There is a Microsoft document which describes how to extricate yourself from the non-booting system produced by changing the mode setting - KB922976
    I finally located a User Guide for Intel RST on their website.  This warns that you must not use the BIOS method to create RAID volumes after the OS is loaded.  You MUST use the RST software in Windows.  I created my AID 0 volume AFTER installing the OS on a SSD drive and getting Windows set up.  Unfortunately, not knowing any better, I created it using the BIOS.
    I have just finished deleting the AID 0 in the BIOS, and have re-created it using the Intel instructions, in Windows.  I am now copying across my backup of the volume.  Then I shall try again.
    Feb 25, 2012 10:07 AM   in reply to Alex DeJesus
    Simple
    Feb 25, 2012 11:46 AM   in reply to Alex DeJesus
    As Bill stated, "Simple". Any other choice of volume will completely defeat the Intel firmware raid, forcing the use of Microsoft's software RAID instead.
    Feb 25, 2012 12:34 PM   in reply to RjL190365
    You need to read the Intel Rapid Storage Technology User Guide, which will tell you all you need to know, and do.
    As would the ASrock Intel guide I mentioned in post 14.
    It is a great pity that the average Motherboard user guide goes no further than creating thew array in BIOS, leaving those who are not experts to flounder - myself included.
    Feb 28, 2012 6:07 PM   in reply to Alex DeJesus
    Have you run our PPBM5 benchmark?  This will tell us where your weak performance is located.  Encoding is not very disk dependent
    Feb 29, 2012 9:41 AM   in reply to Alex DeJesus
    The only thing additional that you could now do is overclock.  Harm did enter you Matrox score and, I am sure he will have the other one in the next day or so ( I found out it is Tax time in the  Netherlands at this time of year as t is here also).
    The non-Matrox score will be about 200 rank since that total score is 271.  If you look at the database and filter on Version 5.5 and then filter for i7-26xx processors you will be able to see that your total of 271 is quite good for that processor if it is not overclocked.
    Feb 29, 2012 2:09 PM   in reply to Alex DeJesus
    Matrox has a disastrous effect on the disk I/O test, as shown by every user of the Matrox MXO2. I have no idea what causes it, but it is a clear Matrox problem.
    Mar 3, 2012 6:20 PM   in reply to Alan Craven
    What is "Bill Gehrke's list"?
    Mar 3, 2012 11:32 PM   in reply to Steve H. Allen
