Slicing an image
Feb 26, 2012 10:20 AM
For a project I am working on, I would be like to be able to slice a photograph up into a number of smaller segments. I can explain what I want to do best in terms of what this would look like if I were working with a physcial print.  Let's say the print is 8 X 10 inches.  I'd like to take that print and cut it up into 16 half inch strips along the 8 inch side, and then cut those horizontally into 20 half inch little squares.  It would sort of resemble a jigsaw puzzle but of course all the side would be straight.  Is there a convenient way to do this in photoshop? I'd want to be able to remove these and rearrange them in PS or perhaps paste each segment into inDesign or Quark.
Thanks.
  • Noel Carboni
    Dec 23, 2006
    Feb 26, 2012 11:00 AM   in reply to ericgraig
    Have you looked into Photoshop's Slice feature?  Generally speaking, it's oriented toward web publishing, where a web page is comprised of multiple parts that make up a whole, and you would use Save For Web & Devices to save the document as multiple images, each of which contains a part of the whole.  Not sure if this matches up to what you're wanting to do.
    Another approach might be to select portions of your image, then use Cut/Paste to put those parts on different layers.
    -Noel
    Feb 26, 2012 6:39 PM   in reply to ericgraig
    Depends on what you specifically have in mind. Tiled printing can be easily done from a PDF and/ or set up accordingly in ID. Just the same, if you plan additional layout work in ID or Quark, then there's no need to bother at all to slice the files - placing the same single image and positioning it differently inside multiple frames is a basic workflow and I'm sure with some automation/ a script in ID you could do this 500 times a day without ever having to do it manually....
    Mylenium
  • Noel Carboni
    Dec 23, 2006
    Feb 28, 2012 8:52 AM   in reply to ericgraig
    What's your intent with the pieces?  Are you going to be printing them separately?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Feb 28, 2012 9:06 AM   in reply to ericgraig
    Can you not just draw white rectangles over them, much as you've done above?  I'm just not seeing the problem.
    -Noel
    Feb 28, 2012 9:49 AM   in reply to ericgraig
    You can do this with a script ...
    #target photoshop
    function main(){
    var dlg=
    "dialog{text:'Script Interface',bounds:[100,100,380,290],"+
    "panel0:Panel{bounds:[10,10,270,180] , text:'' ,properties:{borderStyle:'etched',su1PanelCoordinates:true},"+
    "title:StaticText{bounds:[60,10,220,40] , text:'Tile Picture' ,properties:{scrolling:undefined,multiline:undefined}},"+
    "panel1:Panel{bounds:[10,40,250,130] , text:'' ,properties:{borderStyle:'etched',su1PanelCoordinates:true},"+
    "statictext1:StaticText{bounds:[10,10,111,30] , text:'Accross' ,properties:{scrolling:undefined,multiline:undefined}},"+
    "statictext2:StaticText{bounds:[140,10,230,27] , text:'Down' ,properties:{scrolling:undefined,multiline:undefined}},"+
    "across:DropDownList{bounds:[10,30,100,50]},"+
    "down:DropDownList{bounds:[140,30,230,50]}},"+
    "button0:Button{bounds:[10,140,110,160] , text:'Ok' },"+
    "button1:Button{bounds:[150,140,250,160] , text:'Cancel' }}};"
    var win = new Window(dlg,'Tile Picture');
    if(version.substr(0,version.indexOf('.'))>9){
    win.panel0.title.graphics.font = ScriptUI.newFont("Arial","BOLD",20);
    g = win.graphics;
    var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [1.00, 1.00, 1.00, 1]);
    g.backgroundColor = myBrush;
    var myPen =g.newPen (g.PenType.SOLID_COLOR, [1.00, 0.00, 0.00, 1],lineWidth=1);
    win.center();
      for(var i=1;i<41;i++){
       win.panel0.panel1.across.add ('item', i);
       win.panel0.panel1.down.add ('item', i);
    win.panel0.panel1.across.selection=0;
    win.panel0.panel1.down.selection=0;
    var done = false;
        while (!done) {
          var x = win.show();
          if (x == 0 || x == 2) {
            win.canceled = true;
            done = true;
          } else if (x == 1) {
            done = true;
    if(!documents.length)return;
    var startRulerUnits = preferences.rulerUnits;
    preferences.rulerUnits = Units.PIXELS;
    doc = app.activeDocument;
    app.displayDialogs = DialogModes.NO;
    var tilesAcross = parseInt(win.panel0.panel1.across.selection.index)+1;
    var tilesDown =parseInt(win.panel0.panel1.down.selection.index)+1;
    var tileWidth = parseInt(doc.width/tilesAcross);
    var tileHeight = parseInt(doc.height/tilesDown);
    ProcessFiles(tilesDown,tilesAcross,tileWidth,tileHeight);
    app.preferences.rulerUnits = startRulerUnits;
    main();
    function ProcessFiles(Down,Across,offsetX,offsetY){
    activeDocument.flatten();
    TLX = 0; TLY = 0; TRX = offsetX; TRY = 0;
    BRX = offsetX; BRY = offsetY; BLX = 0; BLY = offsetY;
     for(var a = 0; a < Down; a++){
      for(var i = 0;i <Across; i++){
                        doc.activeLayer = doc.artLayers.getByName("Background");
        doc.selection.select([[TLX,TLY],[TRX,TRY],[BRX,BRY],[BLX,BLY]], SelectionType.REPLACE, 0, false);
                        executeAction(charIDToTypeID( "CpTL" ), undefined, DialogModes.NO );
        doc.selection.deselect();
    TLX = offsetX * (i+1) ; TRX  = TLX + offsetX; BRX = TRX; BLX = TLX;
    TLX = 0; TLY = offsetY * (a +1); TRX = offsetX; TRY = offsetY * (a +1);
    BRX = offsetX; BRY = TRY + offsetY; BLX = 0; BLY = (offsetY * (a +1)+offsetY);
    Feb 28, 2012 10:37 AM   in reply to ericgraig
    You can use File - Scripts - Export Layers to Files
    or my own...
    http://www.scriptsrus.talktalk.net/Layer%20Saver.htm
