How do I display the selected object in the current view?
Feb 26, 2012 9:42 AM
I have an illustrator file with several hundred layers and objects. If I select an object for targeting in the Layers panel, is there a way that I can get the object to be displayed in the center of the workspace. I currently have to zoom in and pan the document to see the object.
Likewise, if I select an object in the document, is there a way to have that object appear in the center of the Layers panel? I currently have to scroll the Layers panel to find the parent layer, and then drill down through the child layers until I find my selected object.
    Feb 26, 2012 9:54 AM   in reply to SteveIsHere
    1. That's a feature request that has often been mentioned here. There may be scripts which do it.
    2. See the Locate Object command in the Layers palette menu.
    Feb 26, 2012 10:36 AM   in reply to SteveIsHere
    It should directly jump to the text object inside the layer.
    Doesn't that work for you?
    Feb 26, 2012 11:51 AM   in reply to SteveIsHere
    I see what you mean.
    As for the missing Zoom to Selection command, there is a prime example for AI's splendid workaround capabilities. Usually, one may expect to get a straightforward command inside the View menu or elsewhere.
    But that approach is, of course, far too uncomplicated for the trailblazer AI. Just for a moment, imagine there were no scripting capabilities in AI. What could you do to cobble together a provisional Zoom to Selection command?
    Crafty AI users would dive into the realm of AI actions and do the following for example:
    1. Create a new action in the Actions palette.
    2. Select any object(s) on the artboard.
    3. Insert Menu Item command: Object > Slice > Create from Selection
    4. Insert Menu Item command: Object > Slice > Release
    5. Insert Menu Item command: Object > Artboards > Convert to Artboards
    6. Insert Menu Item command: Fit Artboard in Window
    7. Stop recording the action.
    8. Assign a shortcut to the action (F2, for example).
    Delete the temporary artboards.
    Heart-stopping.
