Hey everyone,
Hope you guys can help me out. Im so fed up with my situation.
I have older 720 x 576 video avi clips that I wanna use.
I use the same source fps to render it, same size(best settings) and after it's rendered, the video doesn't look that smooth. It looks like its slower almost. If I watch original movie it's do much smoother and faster looking in a way.
Can somebody tell me the exact settings I must have to render it as smooth as possible.
720 x 576 25fps avi
Thanx guys:)
Werner
You need to read up on compression and CoDecs plus you might still wanna double-check footage interpretation vs. comp framerate vs. render settings vs. output module settings. Even if you get some of that right, there may be a problem elsewhere. Some CoDecs will always enforce specific frame rates to comply with certain specs...
Mylenium
thanx so much for answering my question. appreciate it.
i saw that only certain render formats have option where you can choose codecs. is that what you mean by codecs? the only thing i have is copy the source 25fps, 720 x 576 and rendered it as avi.
i want to import the footage that i render in after effects to premiere sometimes. dont know what format is the best.
thanx again for all the help
werner.
Hi again,
Thanx again for the reply. I started checking codecs out.
My files are MOD files from a JVC camera. After effects can read them.
I watched a vid on codecs and I rendered it as AVI with dv ntsci codec and it looked ok but
it shot the fps to 29 from 25 and the audio is out of sync. I tried other codecs but they don't look as. Hope you can help.
Kind regards.
Werner
your best bet is render as uncompressed AVI or QuickTime, then convert the file to mp4 with Adobe Media Encoder.
Also, for best results you need to keep your settings consistent throughout the entire flow (have the same FPS, frame size, field order for: footage interpretation, composition settings, output module and final conversion from Media Encoder).
I'm not really sure what you mean by "smooth", but this could be an explanation.
I don't ever use the feature, but I'm pretty sure there's a preset for rendering to youtube in the latest version of AE, and I can't check because I'm about fives miles away from my AE machine at the moment.
Hi, thank you for responding. My videos look like are not real time. I read it's to do with codecs but I followed instructions to render as h.264 and avi with dv pal codec but there is still some issues. If I watch original video and then rendered one, I see a huge difference in playback. Frame rate looks slower although I rendered the same as the source.
Thank you again for answering.
Werner
My video is 25 fps and 720 x 567 1.09
.AVI
