I'm new to AE and just running some simple tests with the motion tracker. I'm running into all kinds of trouble on something I think shouldn't be that big of a deal.
Here is an example - I've tried single and multiple black dots on a well-lit hand. Regarless of tracker settings, number of tracking points, or size of the tracker it ALWAYS loses the track quite significantly (see image below).
What am I doing wrong?
Much appreciated!
AE's Online Help has good instructions and good advice to follow when motion tracking. Since you're new, it wouldn't help much to write this stuff out in AE Lexicon, because you wouldn't understand it! There's a lot to the process, so you might as well have pictures to go along with words.
Here's an overview of the process.
Here's the workflow to follow.
Here's how to correct a motion track. Problems like yours above happen all the time.
The overview especially has some very helpful links. And take the time to read this stuff carefully, okay? It's easy to get lost when you're new. Read them in the order they appear.
And since you're new, this is also extremely helpful:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after- eff.html
Hi Dave,
Thanks, but I've been through that information. Perhaps I'm simply expecting too much of AE. While I'm relatively new to AE I've used a wide range of software packages for quite some time on a variety of platforms. Boujou can whip this off without any problem for example. I would have thought that a black dot (or several) on skintone would not be a problem for AE, so this drift (more like massive jump) is surprising. I guess I'll have to adjust my expectations.
Steve
Your tracking areas are most likely way too small. This looks like standard def video and it looks quite compressed. All of that noise, the compression artifacts, and the tiny tracking areas confuse the tracker because it's averaging the pixel information in the track area, not looking at a single point.
I'd try tracking the hand in Mocha. I'd also probably try tracking some different areas of the hand like the crevices near the thumb, the spaces between the fingers.
I'm sure it's your tracking dots. I've tracked hands before and it takes about a quarter of an inch in a dot or a triangle to get a track. There's just not enough contrast on the shot for AE to find anything to track. Here's what I'd track using position, rotation, scale. It should work as long as the fingers stay open. Notice the size of the tracked area and the details in the shot.
Those tiny black dots are just way too small. You need about 200 to 400 pixels of detail to get a good track. Your dots are only about 12 pixels. That's too small of a sample to get an average. Here's the dot viewed at the pixel level.
Imagine how that single dark pixel in the middle of the shot is going to dance around when the hand moves. Here's the same shot moved only 1/2 pixel.
You can see how different the data is. There's just no way that a tracker, any tracker, could hold an accurate sample on such a changing target.
Thanks, Rick.
It was the size of the dots. The points you suggested aren't practical because the fingers are in motion so those points aren't consistent. However, I worked out a larger tracking target and the track held at a much more respectable rate. Still needed some tweaking, but it's much better than it was.
Thanks to everyone for the input and suggestions.
Steve
