Ubuntu 11.10 32 bit
Firefox 10.0.2 32 bit
Flash 11.1 r102
I have a Acer Aspire One netbook
As soon I hit "play" on a flash movie, flash player crashes
I have tried to disable hardware acceleration to eliminate that possibility, but the check box does not respond to input
I read that the flash player system controls do not respond when there are scrollbars around the screen (as there are on a small netbook screen) so I zoomed out to get rid of the scrollbars, but the systems setting menu is still unresponsive when I try to disable hardware acceleration
Thanks Carl, but as I mentioned:
eg. when I right slick on a player, the setting menu opens up, but the "Enable hardware" check box does not respond to a mouse click and remains on I also tried tabbing around the settings menu and using the return key to select/ de-select but that doesn't work either
Hi Carl,
I am unable to disable hardware acceleration with your method, and yes the flash player still crashes
I think the video adaptor is a Intel GMA 945GMS
I can't find what video driver version it is - Ubuntu system information says "none" and I don't know how to find out otherwise on CLI
Try updating your video driver:
Have you tried 11.2 RC? http://labs.adobe.com/downloads/flashplayer11-2.html
If the does not help, clean install back to 10.3: How do I do a clean install of Flash Player?
Hardware Acceleration is not supported on Linux. See: http://forums.adobe.com/thread/911321
