Hi everyone,
We use f4vpp to process MP4 files after they are recorded by FMS. A couple of times now we have noticed that the output of f4vpp stops at exactly 2GB.
Have others here seem this same problem? Is this a limitation of f4vpp? Is it a bug or dependent on our system perhaps?
In case it matters: we use f4vpp on linux.
I hope someone can shed some light on this soon as this is really inconvenient. Thanks in advance for any help.
Allright, good to know that it is still on your radar
Some additional info: I have just tested postprocessing a 2.7 GB file on a Windows 7 machine and that does work. Apparently the problem lies in the Linux executable. For a moment I though that it might be the filesystem but then off course that file system also contains the original file so it can handle 2GB+ files.
Yes i had been in discussion with Developers but i fell sick and could not get back to you. As per them there should not be any differnece between Windows and Linux executables. I would have liked to try it myself - does it happen with nay file greater than 2GB on linux or only this specific file - is it possible for you to host it somewhere from where i can download it.
Sorry to hear that, hope you are feeling better now.
It is consistent for all files above 2GB on that sytem.
Some info: It is a 64-bit Debian Squeeze system. To support the 32-bit executable f4vpp we have had to install ia32-libs. We have however run the tool on a 32-bit Debian Lenny previously where we had the same problem.
If you wish I could supply you with a 2GB+ file that has actually been a problem for us. As said though, it is consistent for any file above 2GB (in our situation at least).
use ffmpeg, it is a lossless conversion to .mp4 or .f4v.. Alternatively you can set diskmanagement and segmentduration to null in Application.xml to create 1 .mp4 or .f4f file eliminating the need to package all of segments into 1 file. You can t hen also use ffmpeg on the 1 segment file to convert to .mp4 or .f4v losslessly as well to remove keyframe interval metadata.
