CFSTAT shows zero's for all counters except AvgDB Time and minus one CP /Sec Now Hi.
When I run some CFM that does select from database I would expect counters to increment
for Pg/Sec(Hi), DB/Sec(Hi), ReqRun'g, AvgReq Time, Bytes In/Sec, Bytes Out/Sec.
EG:
C:\ColdFusion10\cfusion\bin>cfstat 1
Pg/Sec DB/Sec CP/Sec Reqs Reqs Reqs AvgQ AvgReq AvgDB Bytes Bytes
Now Hi Now Hi Now Hi Q'ed Run'g TO'ed Time Time Time In/Sec Out/Sec
0 0 0 0 -1 -1 0 0 0 0 0 0 0 0
0 0 0 0 -1 -1 0 0 0 0 0 530 0 0
Regards, Carl.
Hi Carl,
Is your ColdFusion server using built-in webserver or using an external webserver like apache or IIS ?
If you are using external webserver like apache or IIS you need to do the following for your cfstat to provide the stats -
In your ColdFusion Administrator under
Debugging & Logging > Debug Output Settings you will find a field to provide Connector Port.In this field you need to specify the the AJP port from server.xml present in <ColdFusion_Home>\runtime\conf (i.e C:\ColdFusion10\cfusion\runtime\conf on Windows)
You need to look for the block below
<Connector port="8012" protocol="AJP/1.3" redirectPort="8445" tomcatAuthentication="false"> </Connector>
in server.xml and specfiy port 8012 in the Connector Port field in the Administrator.
Please let us know if you are able to get the data after trying out this.
Asha
Adobe ColdFusion Team.
Hi Asha,
Environment = CF10 on Win7 using IIS as webserver.
As suggested take value from
C:\ColdFusion10\cfusion\runtime\conf\server.xml
for
<Connector port="8012" protocol="AJP/1.3" redirectPort="8445" tomcatAuthentication="false" />
Apply to
CF > Debugging & Logging > Debug Output Settings > Connector Port > Restart CF
CF10 Help does not include details above.
Part of CFSTAT works however some counters values do not seem to be correct. I will try get some more details in another post soon.
Thanks, Carl.
Sample CFSTAT counters for CF10 and CF8 running same CFM
0 0 0 0 -1 -1 3 3 0 0 4431 499 0 0
0 0 1 1 -1 -1 3 3 0 0 4431 584 0 0
1 1 0 1 -1 -1 3 3 0 0 7036 584 0 1253716
0 1 0 1 -1 -1 3 3 0 0 7036 584 0 0
c:\ColdFusion8\bin>cfstat 1
0 0 0 0 -1 -1 0 0 0 0 115 243 0 0
0 0 1 1 -1 -1 0 1 0 0 115 145 553 0
1 1 0 1 -1 -1 0 0 0 0 13034 145 0 1262753
0 1 0 1 -1 -1 0 0 0 0 13034 145 0 0
On CF10
Req Q'ed - increments tho I think should be zero. Should not be sufficient load to cause Queuing?
Req Run'g - increments does not return to zero when nothing is running?
Bytes In/Sec - always remains zero?
CF9 CFSTAT sample follows.
C:\ColdFusion9\bin>cfstat 1
0 0 0 0 -1 -1 0 1 0 0 0 0 3178 0
0 0 1 1 -1 -1 0 1 0 0 0 312 0 0
1 1 0 1 -1 -1 0 0 0 0 21347 312 0 1253716
0 1 0 1 -1 -1 0 0 0 0 -20 312 0 0
CF10 CFSTAT would seem to be broken or at least not working in a way that is useful for diagnosis of how resources are being consumed?
Hi Rupesh,
CFSTAT has been a tool available in CF for a long time. Certainly I can remember
using cfstat in macromedia CFmx and perhaps even allaire CF5.
CFSTAT provides some status of the running state of CF server. Not that cfstat is
the beginning and end tool when it comes to knowing what is going on. It has been
better than nothing and having no idea on what CF is doing.
While CF Monitor is very good you do not always have CF Monitor available if
particular CF licence is Standard.
Where do I see problems with CF10 CFSTAT:
Counter - Bytes In/Sec
CF Help - Bytes incoming per second
The number of bytes that ColdFusion read in the last second
With that counter showing zero one would think no CFM pages are being requested.
Counter - Req Q'ed
CF Help - Number of queued requests
The number of requests that are currently waiting for ColdFusion to process them.
Lower values, which you can achieve with efficient CFML, are better.
I am sure that CFM pages that I put thru CF10 are not enough to cause queuing.
This counter seems to mimic the value of counter Req Run'g. Ordinarily you
would not want to see any number in here other than zero.
Counter - Req Run'g
CF Help - Number of running requests
The number of requests that ColdFusion is currently actively processing.
This counter on CF10 is showing cumulative requests that is it is not returning to zero
when no CFM pages are running.
CF Help - Using the cfstat utility
The cfstat command-line utility provides real-time performance metrics for ColdFusion.
From the cfstat sample provide I propose some of the values provided are not real-time
except for the Avg*, Pg/Sec, DB/Sec and Bytes Out/Sec counters.
Regards, Carl.
