If you got update error 1067 when updating Reader, I'd like to hear more so we can find a solution.
I recommend you try installing again using the direct download link noted in this document under "Try a different download link":
http://kb2.adobe.com/cps/836/cpsid_83641.html#main_Try_a_different_dow nload_link
Please let me know if this helps. We haven't been able to reproduce this error.
Thanks so much!
I got the error when applying the update the reader was asking for.
The explanation page told me to download a new exe and install and post to this thread if it worked, which it did. I chose the english version of 10.1.2.
I just worked through this error on my Dad's computer. He has XP Home SP 3, Adobe Acrobat 4 and Reader 9.4.7 were already installed. He has been getting to 1067 error for some time and just clicking through it. I manually un-installed Acrobat 4, but left the shared files in web/common alone. I did not touch Reader 9.4.7. I downloaded the alternate installer for Adobe 10.1.2 for English and ran it. It did complain, eventually, about 9.4.7 still having a file in use, but I'd left the previous dialog from the 9.4.7 updater failure open. I closed that 9.4.7 failure dialog and hit 'retry', and the installer proceeded onward and seems to have completed successfully.
This machine has 1 gig of RAM and approx 4G of free disk space on C:.
I've been getting this error for a while at every startup/restart and didn't bother to try the direct download, which did work, I manually downloaded 10.1.2, so probably won't have the error again until you update it again after I run the new install.
OS: Windows XP Professional Version 2002 SP3
Reader version: 9.4.7
Pop-up box:
[logo] Update failed
The process terminated unexpectedly.
Error: 1067
Available disk space: 81.9 GB
memory: 3 GB
Hi, I was getting the 1067 Error, after Adobe told me it wanted to install the newer software. That happened about 3 times before I noticed the 'find out more info' link, that brought me here. I downloaded the newer install file, and it installed fine. I'm (still) running Windows 2000 SP4. I had received the 1067 Error, and something like "unexpected failure" to install message, previously. I have 7.20 GB of space available on C:, after installing the newer V9.5.0 s/w. My laptop has 523,248 KB of RAM, according to System Properties. I'm not sure what version of Reader I had before the install of V9.5.0, I think it might have been 9.4.7, but not sure.
