paraberto
circle around
Feb 28, 2012 2:15 AM
Tags: #photoshop_cs5 #circle
Hello,
How do I circle around another?
    Feb 28, 2012 2:22 AM   in reply to paraberto
    If you mean the small »circles« that are arranged around the big circle you could achieve that with a hard brush with the appropriate Spacing set in the Brush Panel.
    Or you could create a Path with two opposing small circles, copy/paste those, transform them (command-T) and then use Transform Again (command-shift-T) as many times as necessary. Edit: And then use the Path as a Vector Mask for a Solid Color Layer for example …
    Or you could create a circle Layer and use a Script.
    http://forums.adobe.com/message/4195530#4195530
    Feb 28, 2012 3:46 AM   in reply to paraberto
    Feb 29, 2012 12:46 AM   in reply to paraberto
    Paraberto, what do you need to mark it as CORRECT ANSWER instead of a helpful one?
    You have got, not one. but 3 ways of achieving that, with detailed instructions and pictures.
