RTMP Streaming from Adobe FMS does not work if SWF-Verfication with Referer Check is enabled
SWF-Verfication with Referer Check is a imported Feature for all legal VoD sites. Without this, there is no access control for publisher.
Reason: Referer is not send by Flash plugin
Steps to Reproduce: Install FF and try to view a legal video from major vod site
We have reproduced this an several machines with XP, Win7 32 + 64 and different Firefox Browsers Version > 9
Regards
If you want to report a reproducible bug, please do it here: https://bugbase.adobe.com/
State Open
Status Unverified
This is a very urgend bug.
The amost last reason to use flash player is streaming video.
We are delivering millions of streams a day to millions of user.
Unfortunately there are hundreds of thousands of users with this bad exprience.
Can you provide a link to an example where this occurs?
Yes, please post back with a sample URL and steps to reproduce.
Chris
I have the same problem, I get a black screen with "Connection failed". It works with all other browsers (IE, Opera, Chrome, Safari)
On the server (FMS 4.5), logs say : "unknown pageurl http://www.site.com, rejecting connection -"
Meaning well that what Edgar says is correct
I have the same issue with swf/html protection, i've got connection failed only on Firefox !!
When I use firefox10.0.2 and flash player 11.1.102.62 to access http://mytv.tvb.com/live/hdj#page-1, it shows "Failed to connect to the server, please try again". But, it's ok when I use Internet Explorer or Chome. There is no problem in firefox if I used the ealier version flash player.
Today I install the new newest flash player 11.2.202.228. My firefox is 11.0 now. Now, I can veiw all programmes in http://mytv.tvb.com/ with firefox. No problem now.
I suspect that it is related to JW Player, as with me it is working with the 5.2 player, but not with the 5.8 (After having disabled allowedHTMLdomains.txt, and kept allowedSWFdomains.txt unchanged)
Hello,
I'm using Windows 7 with Firefox and Seamonkey with Flash Player 11.1.102.55 and i can play
this video with jwplayer.
http://www.vallesvisio.cat/videos.php?fitxer=5658&autostart=1
When i upgrade to Flash Player 11.1.102.62, error "Stream not found:"
I downgrade Firefox to 8.0 and Seamonkey to 2.5 and i can play this video.
I downgrade Firefox 10.0.2 with Flash Player 11.1.102.55 and i can play this video.
With Google Chrome 17.0.963.56, Opera 11.61 1250, Safari 5.1.2 and Internet Explorer 9.0.8112.16421
and flash player 11.1.102.62 i can play ok this video.
I tested with Mac Os X Lion 10.7.3 and Seamonkey 2.7.2 and Firefox 10.0.2 with
Flash Player 11.1.102.62 and the same error.
The Jwplayer version is 5.9.2128
I downgrade Jwplayer to version 5.2.1151 and the same error success.
Can you test and resolve it?
Thanks.
Thank you guys for posting links. I've been able to reproduce this and will be entering an internal bug on this immediately. Could one of you please open a new bug report on this over at bugbase.adobe.com? Please post back with the URL so that others affected can add their comments and votes.
I'll link the bugs together once that is done.
Chris
The bug has already been reported and has quite a growing thread, through it is currently in "ToTest" status with reason "CannotReproduce" - I'm assuming that will change now that you have reproduced the issue. Here's the link to the bug:
https://bugbase.adobe.com/index.cfm?event=bug&id=3117684
Thanks so much, Chris!
Thanks for the link, I missed that from the thread above. I've added an internal bug (3126951) and linked the two together.
Chris
