Fergus812
Hyperlinks
Nov 6, 2009 8:03 AM
Hello everybody,
I have seen the very nice connet cards produced from Presenter 7 - and I've two questions:
a) I can't seem to get the hyperlinks/web links in ppt working in the presenter 7 published version - I'm sure it's something simple, as it seems everything else woks?
b) does anyone know of any quick guides on putting a connet card together?
    Calculating status...
    Feb 28, 2012 12:24 PM   in reply to Fergus812
    Just spoke with technical support and they tell me that Presenter does not have the capability to handle hyperlinks to other documents/websites.  You can do this in Captivate, however.
  • Jorma Jennings
    Jul 5, 2007
    Feb 28, 2012 2:20 PM   in reply to JPericich
    Presenter does have the capability to handle hyperlinks, but they must either be a URL call (http://...) or a call to another location in the presentation. Hyperlinks to document will not work as local file path calls are not supported.
    PPT likes to put drop shadows on hyperlinks and Presenter will drop the link if there is a drop shadow on it, so be sure to double check that if a link isn't working.
    Feb 28, 2012 2:23 PM   in reply to Jorma Jennings
    Actually, we tested it with the tech support person and was initially told that Presenter does not do hyperlinks.  Then they called me back and had me change the Global Flash Security Settings to allow access.  Once that was done my hyperlinks work now.
  • Jorma Jennings
    Jul 5, 2007
    Feb 28, 2012 2:24 PM   in reply to JPericich
    Gotta love when tech support tells you the wrong answer first !
    Feb 28, 2012 2:26 PM   in reply to Jorma Jennings
    Yeah, especially when I probably spent 4 hours or more trying different suggestions by everyone and trying to do further research.  It should be documented better.
  • Jorma Jennings
    Jul 5, 2007
    Feb 28, 2012 3:17 PM   in reply to JPericich
    Ah, playing flash content locally opens all kinds of new issues, since it is intended to be delivered over the web, and it gets angry when you play it locally and attempt to link to the web. That makes sense. If you published the presentation to a webserver (Connect or otherwise), then you would likely not see the link disabled. FYI
