Namdesigner
Creating a custom .AHS file
Feb 28, 2012 1:11 PM
Tags: #custom #help #cs5.5 #shapes #photoshop_cs5 #halftone #adobe_photoshop_5.0 #halftone_image #custom_halftone #custom_shapes
Hi, I would like to create a halftone image using a custom shape in the "Halftone Screen" dialog box. i.e. using a custom shape I created instead of the standard "round" "diamond" etc. Basically what I want to know is - if it is possible - how does one create a custom .AHS file containing a custom shape you created so as to create a halftone image.
    Feb 28, 2012 1:20 PM   in reply to Namdesigner
    Feb 28, 2012 1:32 PM   in reply to Namdesigner
    Use the load button to load your custom shape.
  • Noel Carboni
    Dec 23, 2006
    Feb 28, 2012 1:33 PM   in reply to Namdesigner
    Hm, interesting...  You used to be able to save .ahs files from within the Options section of the Print with Preview dialog, but I don't see that capability with the current Photoshop (CS5).  I never noticed that it vanished.
    This is from Photoshop CS3:
    -Noel
  • PECourtejoie
    Jan 11, 2006
    Feb 28, 2012 3:46 PM   in reply to Noel Carboni
    Noel, it's been removed because of postscripts issues: http://forums.adobe.com/message/3438135#3438135
    Feb 28, 2012 7:06 PM   in reply to Namdesigner
    Not exactly what you asked for, but here is a very brief description of how to get a custom halftoned grayscale image; do not know if you are interested in grayscale.
    Convert your image to grayscale (if needed)
    Make a seamless repeating pattern of the design you want and name and save it.
    Click on Image>mode>bit map
    Set (experiment) Output resolution
    Set Method to custom pattern & choose your newly named pattern.
    Here is a quick example using  some pattern that ships with Photoshop. Don't know if this is useful to you, but it is fun to play with.
    Paulo
