Hi All,
I am creating a .dll object from ColdFusion but I am getting the following error message.
"Class GenerateSQLReport not found in the specified assembly list. The assembly that contains the class must be provided to the assembly attribute."
The Process I have followed:
- Updated the ColdFusion 9.0.1
- Uninstall the .NET Integration Service
- Install the .NET Integration Service for 9.0.1
- Run the code.
My Code is : "<cfobject type="dotnet" name="MDBDTable" class="GenerateSQLReport" assembly="#expandPath('./GenerateSQLReportDLL.dll')#">"
I got the following StackStrace:
______________________________________________________________________ ______________________________________________________________________ ____________________________
coldfusion.runtime.dotnet.Assembly$DotNetClassNotFoundException: Class GenerateSQLReport not found in the specified assembly list.
at coldfusion.runtime.dotnet.Assembly.generateProxy(Assembly.java:272)
at coldfusion.runtime.dotnet.Assembly.loadClass(Assembly.java:248)
at coldfusion.runtime.dotnet.Assembly.loadClass(Assembly.java:223)
at coldfusion.runtime.dotnet.DotNetProxyFactory.getProxy(DotNetProxyFact ory.java:78)
at coldfusion.runtime.ProxyFactory.getProxy(ProxyFactory.java:65)
at coldfusion.runtime.CFPage.createObjectProxy(CFPage.java:4949)
at coldfusion.tagext.lang.ObjectTag.doStartTag(ObjectTag.java:427)
at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2722)
at cfDotNetDll2ecfm375138657.runPage(D:\Projects_Upendra\CodeForTesting\ DotNetDll.cfm:2)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:363 )
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:87)
at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:7 4)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePers istenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:53)
at coldfusion.CfmServlet.service(CfmServlet.java:200)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:8 9)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringS ervletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46 )
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java: 286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java: 543)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.ja va:203)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPoo l.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.j ava:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool. java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Please help.
I was not able to call a dll .
After reinstalling the .NET Service I can able to create a dll object.(I have used this http://tutorial11.learncf.com/ ).
But, when I create a sample dll with the following code it throws the previous error.
.NET Code
using System;
public class HelloWorldProc {
public HelloWorldProc()
public string HelloWorld()
return "HelloWorldProc:HelloWorld called and returns Hello world!";
I don't know .NET very well. If I am missing something please suggest.
The CF code must include the full path to the class, including any namespace. When you create a C# project in Visual studio it typically uses the project name as the "default namespace". So if your project is named "MyProject" the full path would be:
<cfobject type="dotnet" class="MyProject.HelloWorldProc" ...>
Message was edited by: -==cfSearching==-
