Hello All,
I have virtual Centos 5.7 with FMS developer and FMG installed.
SElinux is disabled, firewall is down, registry is endabled in Server.xml.
But FMG core.00.log says :
2012-02-29::11:17:33.709 | INFO | 1073742997 RTMP 22662 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony |
2012-02-29::11:17:33.710 | INFO | 1073742997 RTMP 22662 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control |
2012-02-29::11:17:33.713 | DEBUG 1073742997 RTMP 22662 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details |
I tried flashPhone with url : rtmp://server-ip/telephony and it says NetConnection.Connect.Success.
But I am always to this screen.
I only can see phone with botton while page is reloading and then again redirected to login screen.
Can some help with this issue.
Ivan
The logs indicate that registry core is not really up.
1) Trivial step, was FMS restarted ?
2) Process manager on linux should show one FMSCore process after FMS start start even when no application is loaded.
3) Default conf of FMS 4.5 "already" contains a registry tag at near bottom of file. It should be enabled inplace; which is slightly different that earlier when <registry> tag was needed to be added.
Hello Pankaj Y,
I restarted FMS several times - no luck.
also indeed there was tag <registry> - I only change false to true
But problem is still here
Ivan
Error is likely to be in FMS:
Right after restart, do you see one preloaded fmscore process ?
Is there an error msg in FMS log files?
