Hi everybody,
I have a Virtual Machine with Windows Server 2008 R2 Standard with ColdFusion Standard version 9.0.0.251028 installed, with Apache Webserver. The problem is that while the site runs almost very well, the server is quite unusable because the JRun is always over 9x% of usage.
I've checked the log but there's no oversized file or other and there are not so much exceptions as I read in other posts as possible soutions.
What I can do to solve this matter?
How much memory is committed to Jrun? Are there any error warnings in log files ColdFusion9\runtime\logs\ coldfusion-event and coldfusion-out?
HTH, Carl.
Else you could try patching to bring CF to more current version updater1 and CHF2:
http://www.adobe.com/support/coldfusion/downloads_updates.html#cf9
Carl I am having a JRun Issue also. I just moved my sites to a 64bit server with twice the ram/cpu/etc, but my server is crashing move often. Do you think you could help me try to figure out what is going wrong?
Justin there are likely many things you can do to help yourself. From above post it is often a good idea to be well patched. Details in this post could provide some assistance resolving CF9 Java Jrun matters:
http://forums.adobe.com/message/4087777
HTH, Carl.
