Inkfast
Attempting query update from array
Feb 29, 2012 1:41 PM
I'm attempting to update a table from an array by looping it over but having no luck. There doesn't seem to be much info out there on how to do this, everything I've found is related to looping queries into arrays (the reverse obviously). It's seems like it should be simple enough the test array is;
(sel, optiontype_ID)
[1] [1] Blue
[1] [2] 65
[2] [1] White
[2] [2] 73
And my attempt.....
<cfloop index="x" from="1" to="#arrayLen(arr1[sel])#">
<cfloop index="y" from="1" to="#arrayLen(arr1[optiontype_ID])#">
<cfquery datasource="#request.dsn#" username="#request.dsnUsername#" password="#request.dsnPassword#">
update tbl_skuoptions
set option_name = '#arr1[sel]#'
where option_Type_ID = '#arr1[optiontype_ID]#'
</cfquery>
</cfloop>
</cfloop>
Any ideas or even a slap upside the head from Dan would be appreciated.
David
    Feb 29, 2012 2:34 PM   in reply to Inkfast
    What exactly happens when you run that code?
    Feb 29, 2012 3:41 PM   in reply to Inkfast
    Looping through 2D arrays is such a pain it's rare that I ever attempt it.  Queries are much easier to deal with.  On that note, from where did the data for your array come in the first place?
    Feb 29, 2012 3:55 PM   in reply to Inkfast
    How are the form fields named?
    Feb 29, 2012 4:47 PM   in reply to Inkfast
    You have to be doing something to build your array.  At the stage when you populate each row, couldn't you update your db instead?
    Feb 29, 2012 5:08 PM   in reply to Inkfast
    Try something like this:
    <cfloop from = "1" to = "#ListLen(form.sel)#" index = "idx">
    update query goes here
    </cfloop>
    Mar 1, 2012 9:52 AM   in reply to Dan Bracuk
    It seems like the core of your problem with your implementation has to do with how you are implementing your loop.  You can use the "Array" attribute of <cfloop> to loop over your array and have your index be the CF contents of each array position (rather than having to do everything by position reference as you attempted to do in your example)
    <cfloop array="#arr1#" index="arrInner">
    set option_name = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arrInner[1]#">
    where option_Type_ID = <cfqueryparam cfsqltype="cf_sql_integer" value="#arrInner[2]#">
    </cfloop>
    I threw in some <cfqueryparam> goodness as well.  Of course, this assumes that array positions 1 & 2 of your inner array are simple data types.
