Issue with having grouped radio button
Feb 29, 2012 7:13 AM
Tags: #indesign #plug-in
Hi, all,
i have issue with creating grouped radio button, here i included the code which i use. can any one help me.
resource BscPnlPanelWidget(kSDKDefPanelResourceID + index_enUS)
    __FILE__, __LINE__,
    kBscPnlPanelWidgetID,
    kPMRsrcID_None,
    kBindNone,
    0, 0, 800, 300,
    kTrue, kTrue,
    kBscPnlPanelTitleKey,
        GroupPanelWidget
        kBscGroupWidgetID,
        kPMRsrcID_None,
        kBindNone,
        Frame(0, 60, 150, 115),
        kTrue,
        kTrue,
        kBscTabWidgetID,
        ClusterPanelWidget
        kBscClusterWidgetID,
        kPMRsrcID_None,
        kBindNone,
        Frame( 0, 0, 60, 70),
        kTrue,
        kTrue,
        "Select Type",
            RadioButtonWidget
            kBscRadioButton1WidgetID,
            kSysRadioButtonPMRsrcId,
            kBindNone,
            Frame(2, 10, 50, 30),
            kTrue, kTrue,
            "Type 1",
            RadioButtonWidget
            kBscRadioButton2WidgetID,
            kBindNone,
            Frame( 2, 32, 50, 52),
            kTrue, kTrue,
            "Type 2",
    Feb 29, 2012 3:05 PM   in reply to suren_tringer
    Where is the kBscTabWidgetID referenced by the group as border widget?
    Include a FittedStaticTextWidget as first item in the widget list, same level as that ClusterPanelWidget.
    Dirk
    Feb 29, 2012 3:17 PM   in reply to Dirk Becker
    Btw, please include some indicator of the actual problem with your message.
    "I have issue" and "can anyone help" just leaves too much guesswork.
    It could mean anything like
    - you just experience compile time errors (which?)
    - you don't see the widgets in the running plugin
    - you crash InDesign on your Mac (provide stack trace?)
    - you crash InDesign on your Windows machine (get a Mac!)
    - you see assertion failures in the debug build (again which?)
    - anything else, you got the idea.
    Dirk
    Mar 2, 2012 7:57 AM   in reply to suren_tringer
    Your quoted .fr fragment only has one occurence of kBscTabWidgetID.
    For a deeper understanding of the resource language, try to follow the declarations ( e.g. starting in Widgets.fh ) and comment every line / data item.
    An example of the relevant entry, formatted my way:
    GroupPanelWidget (
        // GroupPanelWidget : CControlView
        kBscGroupWidgetID,                      // WidgetId
        kPMRsrcID_None,                         // RsrcId
        kBindNone,                              // Frame Binding
        Frame(                                  //  Frame
            0, 60,                              //  left,top
            150, 115 )                          //  right,bottom
        kTrue,                                  // Visible
        kTrue,                                  // Enabled
        // GroupPanelWidget : GroupPanelAttributes
        kBscTabWidgetID,                        // widget id of border widget
        // GroupPanelWidget : CPanelControlData
    Then use the interface ID of e.g. GroupPanelAttributes to locate the matching .h interface header:
    class IGroupPanelAttributes : public IPMUnknown
    public:
      // ----- Query -----
              enum { kDefaultIID = IID_IGROUPPANELATTRIBUTES };
      /** Get the widget id of the widget to use in the top left border of the GroupPanel.
                                  The widget can have sub-widgets.  If GetBorderWidgetID returns 0,
                                  a simple framed border will be drawn.
                        @return the widget id
              virtual WidgetID          GetBorderWidgetID() const = 0;
    This will give you more details on the meaning of the values in the resource.
    Dirk
    Mar 2, 2012 7:59 AM   in reply to suren_tringer
    Btw, the FittedStaticTextWidget should of course use that kBscTabWidgetID as ID.
    Dirk
