Hello
I'm developing one continuous image for a large wall that will be seen from about 1-2 feet viewing distance. It has to be about 100 dpi.
My image is currently 21,600 x 8100 pixels at 8 bits CMYK. It may get bigger. I don't have to do much manipulation, but a lot of it is using brushes and the smudge tool.
2 issues:
1) I have a 12-core Mac Pro with 24GB RAM. The smudge tool is sloooooow when working on this image (like one smudge at max brush size takes 15-20 seconds to take effect).
2) IS there a "warp mesh" tool that I can use in place of the smudge tool?
Is there a way for me to edit a lower-resolution version of this image, then apply the changes I made to the high-res version? then I can use the smudge and brush tools and finessé my work without the machine bogging down, and the imagery will look correct. I'm looking for a way to use these tools more in real time while working with this big image.
Have you tried Filter > Liquify?
One could work with Smart Objects and later switch in higher resolution content, though that is little/no use for painting but rather for transformations for example.
Liquify is a solution, thanks for offering that, but it is also not working very well at all. When I try to use the reconstruct tool after making some warps, it just hangs and I have to force-quit Photoshop.
this is killing me.
If I had a mesh-distort tool that could provide a parametric distortion based on curves, this problem would be solved.
Additionally:
Why do you work in CMYK?
Are you working with CS5?
On performance in general:
http://kb2.adobe.com/cps/404/kb404439.html#main_Memory%20Usage
I'm working in CMYK because my comp is for print and the source image was provided in CMYK. I don't want to mess with the color settings.
I'm using CS 5.5 with all current updates. I have also already altered my performance settings.
I think I may have found a solution (I'm still in the middle of workign with it).
1) I make a low-resolution version of the image (like 1200px wide)
2) I make my edits to the image using Liquify
3) before committing the Liquify changes, I "Save Mesh" in the Liquify tool
4) I open my high-resolution image
5) I use liquify, but I do not use any brushes, but in stead load my saved mesh from the low-res
6) profit.
This appears to be working, buit I have not tested it with large brush sizes yet. The brush size in Liquify tops out at 1500px, which is still waaaay too small for the nice, smooth curve I have to create over a 10,000 pixel area. I'll post with results of my tests.
This appears to be the solution (at least, it is for me). I can apply my changes to the low-resolution proxy by saving the mesh and then applying that same mesh to the high-resolution image. The large brush sizes (in comparison to the image resolution) that I am afforded in the low-res version are brought across to the high-res because the changes are not applied as brush strokes, but rather as alterations to an overall mesh. the changes to the mesh are what is transferred when I export and import.
Applying the mesh is pretty slow, and it requires a few tweaks at the high-res level, but it gets me 95% of the way there. I think this is workable.
To recap - here are the steps:
6) profit.
thanks for the help folks!
--------------S
It seems Adobe hasn't come out with Photoshop CS6 quickly enough for you. They're advertising that Liquify will be both MUCH faster and allow HUGE brush sizes.
-Noel
