Globally change the size of multiple imported PDF's in InDesign
Feb 29, 2012 2:29 PM
I just used a script to import a 1,299 page PDF document.  I wish to change the SIZE of all the PDF's that I have imported.
Do I have to go to each page (1,299) and manually change the size?
    Feb 29, 2012 2:33 PM   in reply to Ceencha
    Don't know waht script you used, but I recommend this one: InDesignSecrets » Blog Archive » Zanelli Releases MultiPageImporter for Importing both PDF and INDD Files
    It allows you to set the scaling when you run it, and it will be one heck of a lot faster to just run the script again on a new file than to go back and manually scale 1299 PDF pages. The other option might be to find a script that can  find the already plced pages and scale them, but I don't know of one that's already availble. You could ask over in InDesign Scripting
    Feb 29, 2012 3:27 PM   in reply to Peter Spier
    You can do this with layout adjustment. Switch it off, set the margins
    of all pages to be flush with the pdfs. Then switch it on. Check "allow
    graphics to resize". Now set the margins to whatever size you want your
    pdfs to be and they will resize.
    It will still take a while for InDesign to do this to 1000+ pages, but
    at least you can sit back and do nothing. But test the procedure on a
    dozen pages or so first to make sure you've got it right. Also, make
    sure that in the margins and columns dialog, switch preview off before
    you make any changes to the margins, otherwise you'll have to wait × 4
    for each change!
    Ariel
    Aug 13, 2012 1:33 PM   in reply to Ceencha
    What do you think is missing? The nin-point proxy is repalced by the dropdown, and there's now a rotation field added....
    Aug 14, 2012 10:57 AM   in reply to Ceencha
    Click the dropdown. You'll see nine choices that correspond to the nine points on the proxy in the other dialog and three more relative to spine.
Bookmarked By (1)
