Padding has no effect in image in TLF
Dec 19, 2011 8:52 PM
My Code:
var tl:String = "<p>Hello, <img paddingTop='10' paddingBottom='10'  src='https://imgssl.constantcontact.com/letters/images/v8_your_image_100x10 0.gif' align='right'></img></p>";
htmlFlowReference.textFlow = TextConverter.importToFlow(tl, TextConverter.TEXT_FIELD_HTML_FORMAT);
Please suggest what i doing wrong....
    Dec 19, 2011 11:42 PM   in reply to dineshmgkvp
    paddingTop and paddingBottom can work with TextConverter.TEXT_FIELD_HTML_FORMAT.
    HTML importer in TLF is a little bit simple.
    Mar 1, 2012 5:19 AM   in reply to Jin-Huang
    The paddingTop and paddingBottom don't seem to work when importing from an external XML source. Is there any reason why?
    Mar 1, 2012 6:05 PM   in reply to F.Bowman
    Did you try to import the internal XML with same content? I cannot imagine it's because XML is external.
    Paste your code scrap here. I will try to help you.
    Mar 2, 2012 3:52 AM   in reply to Jin-Huang
    This is a sample of the code I'm using.
    External XML File:
    <?xml version="1.0" encoding="utf-8"?>
    <TextFlow xmlns="http://ns.adobe.com/textLayout/2008" whiteSpaceCollapse="preserve">
         <div>
              <p>
                   <span>To change password perform the following steps:</span>
                   <br/><br/>
                   <span>1. Click on the eSubmit Plus menu option on the main navigation bar.</span><br/>
                   <span>2. Select Preferences from the drop down list as shown in figure 3.</span><br/>
                   <span>3. Enter your old password, enter your new password and verify the new password in the text area as seen in figure 4.</span><br/>
                   <span>4. Click the Save button to save the new password.</span>
                   <br/>
                   <img width="494" height="285" source="images/help/account_01.png"/>
                   <br/>
                   <img width="397" height="269" source="images/help/account_02.png"/>
              </p>
         </div>
    </TextFlow>
    Other external XML file:
    <TextFlow xmlns="http://ns.adobe.com/textLayout/2008" whiteSpaceCollapse="preserve" fontSize="11">
              <div>
                        <p>To log into the system, please do the following:</p>
                        <p/>
                        <p><img width="510" height="325" source="images/help/login_01.png"/></p>
                        <p/>
                        <p>Once your logon is successful you will be taken to the logon screen.</p>
                        <p/>
                        <p><img width="475" height="293" source="images/help/login_02.png"/></p>
              </div>
    </TextFlow>
    Flex Code:
    init() fires on creationComplete().
    [Bindable] private var helpSource:TextFlow;
    private function init():void
         helpSource = TextFlowUtil.importFromXML(helpIndexSource);
    <fx:Declarations>
         <fx:XML id="helpIndexSource" source="xml/helpIndex.xml"/>
    </fx:Declarations>
    <s:RichEditableText id="helpIndexDisplay" x="10" y="10" width="220" height="530" editable="false" textFlow="{helpSource}"/>
    Mar 4, 2012 7:08 PM   in reply to F.Bowman
    I confirmed the bug. But it's a Flex bug. Please file it on https://bugs.adobe.com/flex/
